Hello all!
I have RB750 (ROS 5.7) and i found some bug. When I disable ether1 and after enable it, all other interface temporarily go to down and after few seconds go up.
Here ouput from log:
--- Here I disable ether1
11:32:40 system,info device changed by admin
--- Here I enable ether1
11:32:41 interface,info ether2 link down
11:32:41 interface,info ether3 link down
11:32:41 interface,info ether1 link down
11:32:41 interface,info ether5 link down
11:32:42 interface,info ether2 link up (speed 100M, full duplex)
11:32:42 interface,info ether3 link up (speed 100M, full duplex)
11:32:42 interface,info ether5 link up (speed 100M, full duplex)
11:32:43 interface,info ether1 link up (speed 100M, full duplex)
And interface configuration:
set 0 arp=enabled auto-negotiation=yes comment=ISP1 disabled=no full-duplex=yes l2mtu=1600 \
mac-address=00:0C:42:B7:FF:26 mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"to ADSL modem" disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:B7:FF:27 \
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
full-duplex=yes l2mtu=1598 mac-address=00:0C:42:B7:FF:28 master-port=none mtu=1500 \
name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
full-duplex=yes l2mtu=1598 mac-address=00:0C:42:B7:FF:29 master-port=none mtu=1500 \
name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
full-duplex=yes l2mtu=1598 mac-address=00:0C:42:B7:FF:2A master-port=none mtu=1500 \
name=ether5 speed=100Mbps
[admin@MikroTik] > /interface ethernet monitor ether2 without-paging
status: link-ok
auto-negotiation: done
rate: 100Mbps
full-duplex: yes
status: no-link
rate: 10Mbps
full-duplex: no
status: link-ok
rate: 100Mbps
full-duplex: yes
When I try disable/enable other interface is all ok.
Can somebody please explain me the reason why it happens.
Also i try reset configuration and on clean router it’s happens all the same
Thanks!
