Mikrotik support and me, are trying to debug the “reboot kernel failure” that routerboard 133c (at least for me) show in the logs after every reboot.
This -bug- are present from ros 3.10, and the last 3.11 don’t resolve the problem.
After an exchange of mail with mikrotik support, we need some other user with rb133c and ros 3.11 installed to verify if also in his routerboard logs, there are a “kernel failure” message after every reboot.
Some one can help us testing this, simply installing (or just try to reboot if already installed) ROS 3.11, and checking if there is a “kernel failure” in logs?
If so, it would be appreciated to post also the configuration of the router.
Not only on 133C. Generally I prefer 2.9.51 which is more stable and predictable. Unfortuntelly we have to use 3.11 on a few 411/433, excluding all extra features which is generally not important for us 3.x is crap. In my opinion if you don’t have to use 3.x than don’t.
we have changed back to 2.9.51 on all off the 1xx boards we are running.
it seems that they cannot handle the load and are allways close to 100% load and then reboot. but on all other boards 3.x is running ok …
we had slight troubels with some rb 532 upgraded from 2.9.s versions - but after reset config and a clean new config they run fine now
