We want to try new IGP routes aggregation in BGP, but with no success. If we look at “/routing bgp advertisements print” routes are agregated OK here (only 3x /24 per peer). But on peering routers there are ALL routes … both agregates and original … (about 250x /32 + 1x /27 + 3x /24)
Our configuration is:
/routing bgp instance
set default as=65408 client-to-client-reflection=no comment="" disabled=no ignore-as-path-len=no name=default out-filter=bgp-networks redistribute-connected=yes redistribute-ospf=yes redistribute-other-bgp=no redistribute-rip=no redistribute-static=yes router-id=\
10.0.18.8
/routing bgp aggregate
add advertise-filter="" attribute-filter="" comment="" disabled=no include-igp=yes inherit-attributes=yes instance=default prefix=172.30.1.0/24 summary-only=yes suppress-filter=""
add advertise-filter="" attribute-filter="" comment="" disabled=no include-igp=yes inherit-attributes=yes instance=default prefix=172.30.101.0/24 summary-only=yes suppress-filter=""
add advertise-filter="" attribute-filter="" comment="" disabled=no include-igp=yes inherit-attributes=yes instance=default prefix=172.30.2.0/24 summary-only=yes suppress-filter=""
/routing bgp peer
add address-families=ip comment="" default-originate=if-installed disabled=no hold-time=3m in-filter="" instance=default multihop=no name=roudnice-esus nexthop-choice=force-self out-filter=to-esus remote-address=XXX remote-as=65400 remove-private-as=no \
route-reflect=no tcp-md5-key="" ttl=255
add address-families=ip comment="" default-originate=if-installed disabled=no hold-time=3m in-filter="" instance=default multihop=no name=benecko-lugos nexthop-choice=force-self out-filter=to-benecko remote-address=XXX remote-as=65424 remove-private-as=no \
add address-families=ip comment="" default-originate=if-installed disabled=no hold-time=3m in-filter=from-tamesis instance=default multihop=no name=bratrouchov-tamesis nexthop-choice=force-self out-filter=to-tamesis remote-address=XXX remote-as=65432 \
remove-private-as=no route-reflect=no tcp-md5-key="" ttl=255
Is it some BUG or bad configuration ?
Thank you
