this is my network
until a few days ago everything was fine, but after a responder reboot not all initiators establish the VPN, at each reboot different initiators connect, sometimes 4, sometimes 6, the rest remain in no phase 2. I can see this messages in the initiators log
may/04 00:14:50 ipsec ike2 starting for: xxx.xxx.xxx.xxx
may/04 00:14:53 ipsec adding notify: IKEV2_FRAGMENTATION_SUPPORTED
may/04 00:14:53 ipsec adding notify: NAT_DETECTION_DESTINATION_IP
may/04 00:14:53 ipsec adding notify: NAT_DETECTION_SOURCE_IP
may/04 00:14:53 ipsec adding payload: NONCE
may/04 00:14:53 ipsec adding payload: KE
may/04 00:14:53 ipsec adding payload: SA
may/04 00:14:53 ipsec <- ike2 request, exchange: SA_INIT:0 xxx.xxx.xxx.xxx[4500] 25deef602c73f383:0000000000000000
may/04 00:14:53 ipsec -> ike2 reply, exchange: SA_INIT:0 xxx.xxx.xxx.xxx[4500] 25deef602c73f383:0000000000000000
may/04 00:14:53 ipsec payload seen: NOTIFY
may/04 00:14:53 ipsec first payload is NOTIFY
may/04 00:14:53 ipsec processing payloads: NOTIFY
may/04 00:14:53 ipsec notify: COOKIE
may/04 00:14:53 ipsec adding notify: COOKIE
may/04 00:14:54 firewall,info input: in:ether1-WAN out:(unknown 0), src-mac e4:ab:89:a6:6d:d9, proto UDP, xxx.xxx.xxx.xxx:4500->192.168.1.254:4500, prio 1->0, len 88
may/04 00:14:58 ipsec <- ike2 init retransmit request, exchange: SA_INIT:0 xxx.xxx.xxx.xxx[4500] 25deef602c73f383:0000000000000000
may/04 00:15:03 ipsec <- ike2 init retransmit request, exchange: SA_INIT:0 xxx.xxx.xxx.xxx[4500] 25deef602c73f383:0000000000000000
may/04 00:15:08 ipsec <- ike2 init retransmit request, exchange: SA_INIT:0 xxx.xxx.xxx.xxx[4500] 25deef602c73f383:0000000000000000
may/04 00:15:13 ipsec ike2 init timeout request, exchange: SA_INIT:0 xxx.xxx.xxx.xxx[4500] 25deef602c73f383:0000000000000000
xxx.xxx.xxx.xxx = responder public IP
Here you can see the responder log
responder log.txt (54.2 KB)
This is the responder config:
/ip ipsec peer
add exchange-mode=ike2 name=IKE2-peers passive=yes profile=IKE2-profile send-initial-contact=no
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256 name=IKE2-profile
/ip ipsec identity
add auth-method=digital-signature certificate=VDC generate-policy=port-strict match-by=certificate mode-config=IKE2-configs peer=IKE2-peers policy-template-group=IKE2-group remote-certificate=Offices
/ip ipsec mode-config
add address-pool=IKE2-pool name=IKE2-configs system-dns=no
/ip ipsec policy group
add name=IKE2-group
/ip ipsec policy
add group=IKE2-group proposal=IKE2-proposal template=yes
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=1d name=IKE2-proposal pfs-group=modp2048
The configuration in the initiators is fine, before the reboot all of them connected without problems, I have still checked them. I have also restored a backup on the responder before the problem occurred with no luck.
I don’t know what else to look at or do
Please help
