I’ve read a lot of pages with people talking about this, but none of the suggestions have worked. The tunnel connects fine, but after about 25 min the connection stops working and after 30 min I get “IPsec-SA expired before finishing rekey” in the logs.
30min is default SA lifetime on Mikrotik, then rekeying happens, which fail in your case.
On IPsec proposals you have not maching pfs-group settings on client&server (which is exactly relevant for rekeying).
I had them matching and still had the issue. When googling the issue I ran across other people with similar problems with the suggestion to set the pfs-group to none on the client.
The pfs setting issue is normally related only to the Windows embedded VPN client (and there, none at Mikrotik side is the only possibility); for an IPsec tunnel between two Mikrotiks, any pfs choice common for both peers normally works.
So I can only speculate - if there is transparent routing between the two peers (no NAT on either side), but there is a firewall between them, and you have disabled the DPD functionality, it is possible that the UDP control session is silent throughout the lifetime of the SA, so when it comes to rekeying, the pinhole for the control session at the firewall is already closed (whilst the ESP protocol used by the SA itself gets through as the SA keeps carrying traffic). This explanation is only relevant if the SA renegotiation is started by the responder peer, as if the initial packet from the initiator is able to create the pinhole in the external firewall, the rekey request packet from the initiator must be as well.
You haven’t stated your RouterOS versions, this may be an issue too. I have tens of IPsec connections, and in the past, there used to be a randomly appearing issue with rekeying in IKEv2 mode where the rekeying succeeded but resulted in different ephemeral keys at both ends so the recipient could not decipher the received transport packets, but this has been fixed at least a year ago.
Thank you for the detailed response sindy. I don’t understand ipsec quite well enough to figure this out myself, so I appreciate your help.
The setup is a little messy, but I’ll try to explain it.
The “Server” Router is currently running v6.45.8 (It was running the latest, but I just downgraded it just in case it was a bug)
The "Client Routers, of which there are over a dozen are running v6.45.7.
The “Server” Router is behind another Router with udp ports forwarded from 501, 4501 (wan) to 500, 4500 (MikroTik).
The “Clients” are all also behind various routers and are setup to connect to port 4501 on the Server IP. I’m actually not sure how to use port 501(500) since there’s only one place to enter a port number on the peer, or even if its needed. I read in another thread that Mikrotik is setup to use 4500 for everything using ikev2.
Okay. Unless one of the intermediate routers has an extremely short timeout, my assumption that it’s a firewall issue is likely wrong.
So before diving any deeper, please try one simple thing - run a ping with a 1 second periodicity through the tunnel as soon as the connection establishes, and let it run until the first SA expires; if in this case the rekeying succeeds, the intermediate firewalls are the cause, otherwise it must be something else. The result will be the basis for choice of the subsequent analytic steps. Also, once the initial pair of SAs is up, check whether the dst-address and src-address in the output of /ip ipsec installed-sa print are just IP addresses or whether the port number is also printed - this indicates whether UDP encapsulation is in use (if ports are printed, it should be the case) or the IPsec somehow managed to choose plain ESP (if only IP addresses are printed).
I’ll have to test one from the very second it establishes, but looking at the “uptime” on “active peers” I tested 6 of them over 20min old and without exception all pings cut out anywhere from 24m 2s to 24m 30s. Looking at their SA’s, their soft lifetimes all seem to be in the same range. So it’s cutting out as soon as it passes the soft lifetime.
As far as the ip/ports for the SA’s. Looking at one pair of SA’s from the Server side:
Pair 1:
Src Address: Public ip of client
Port: 4500
Dst Address: Wan ip of server (which is the private ip given to it by the main router)
Port: 4500
Pair 2:
Src Address: Wan ip of server (which is the private ip given to it by the main router)
Port: 4500
Dst Address: Public ip of client
Port: 4500
Looking at the SA’s from the Client side:
Pair 1:
Port: 4500
Dst Address: Public ip of server
Port: 4501
Pair 2:
Src Address: Public ip of server
Port: 4501
Port: 4500
On several tunnels I’ve noticed that the client side port is 1024. These also cut off exactly after their soft lifetimes. But in all cases the port is printed as well when looking at /ip ipsec installed-sa print .
I should note that one the server side router which the server Mikrotik sits behind “udp” and “tcp” are forwarded from 4501 to 4500. There is no option for any other type of packet.
OK, so you have already done that test. It’s not necessary to do it right from the very start, because the transport packets and the control packets use the same UDP stream as the /ip ipsec installed-sa print has shown. And it also means that the firewall hypothesis is wrong, except if highly theoretically the firewall was IPsec aware and was handling the control session’s packets and the transport packets within that single stream selectively.
Forwarding TCP is enough.
So after all, it does look like an IPsec issue within RouterOS. Before diving into analysis of logs, please make sure that you use the same (single and common for both peers!) value as the dh-group in the relevant /ip ipsec profile item and as pfs-group in the relevant /ip ipsec proposal item used at both ends, try again and report the result. I hazily remember @emils to explain that these two parameters were related. But still, having none as pfs-group at both ends should work as well.
Also, can you show your complete /ip ipsec export hide-sensitive from both the “server” and the “client”? Maybe there is some mistake in the dependencies (proposal<-policy(template<-policy group)<-identity->peer->profile)? Double-check that the hide-sensitive has hidden any pre-shared secrets if used, and feel free to edit domain names, my-id, remote-id values possibly identifying you, they are not important for the purpose. Same for the public IP address(es) of course.
Note: As you can see the client side also has another active VPN, you can ignore it, but I thought I should include it in case its relevant. That one connects to another place with a Fortigate Router and it works just fine. The tunnel I’m concerned with on the client side is “MGMT” not “VPN”.
On the client, you manually specify a policy linked to the peer, and in the policy, you specify the proposal. Everything OK.
However, on the server, the identity says generate-policy=port-strict. That’s fine, but what’s missing is a policy-template-group specification. Since it is missing, /ip ipsec policy group default is used when searching for a template to generate the actual policy; in that group, there is a single policy template, “from anything to anything”, which refers to /ip ipsec proposal default. And that proposal has pfs-group=modp1024. So regardless whether you set the pfs-group in your “MGMT” proposals at both ends to none or to modp2048, it will always differ from the modp1024 set in the default proposal.
So to fix it, do the following at server side: /ip ipsec policy group add name=MGMT
/ip ipsec policy add template=yes group=MGMT proposal=MGMT
/ip ipsec identity set [find peer=MGMT] policy-template-group=MGMT
As you can see, the namespaces of the various configuration subtrees are separate, so the proposal named MGMT is not automatically used for dynamically created policies for identities linked to peer named MGMT or to profile named MGMT.
Thank you SO much for walking through that with me so patiently! That solved it. And now I know why there’s a groups option in ipsec that I always skipped over : )
Perfect. Now as you’ve said you have seen other topics dealing with the same issue, can you still find them again? I was trying to find something, but have only found cases where Mikrotik was only at one end of the connection, so the solution there may be completely different (plus they are quite old and Mikrotik’s IPsec has evolved quite a lot in past two years while I keep track about it).
