IKEv2 connection problem
Hi there!
I’m about to break my brain because I rechecked everything several times, and the same configuration with the same certificate and password works fine through a smartphone.
I have a remote Linux server with Strongswan installed (222.222.222.222).Its configuration:
ipsec.conf
config setup
        charondebug="ike 2, knl 2, cfg 2, net 2, esp 2, dmn 2, mgr 2"
        strictcrlpolicy=no
        uniqueids=no
conn ikev2-vpn
    auto=add
    compress=no
    type=tunnel
    keyexchange=ikev2
    fragmentation=yes
    forceencaps=yes
    dpdaction=clear
    dpddelay=300s
    rekey=no
    left=%any
    leftid=222.222.222.222
    leftcert=server-cert.pem
    leftsendcert=always
    leftsubnet=0.0.0.0/0
    right=%any
    rightid=%any
    rightauth=eap-mschapv2
    rightsourceip=10.33.3.0/24
    rightdns=1.1.1.1,1.1.1.2
    rightsendcert=never
    eap_identity=%identity
ipsec.secrets
: RSA "server-key.pem"
mikrouser : EAP "MyBestPasswordEver111"
ca-cert.pem is installed in Mikrotik as lux-cert
Here is the Mikrotik (111.111.111.111) configuration
/ip ipsec mode-config
add connection-mark=ipsec name=ikev2-modeconf responder=no src-address-list=toVPNclient use-responder-dns=no
/ip ipsec policy group
add name=ikev2-group
/ip ipsec profile
add dh-group=modp2048,modp1536 enc-algorithm=aes-256 hash-algorithm=sha256 name=ikev2-profile
/ip ipsec peer
add address=222.222.222.222/32 exchange-mode=ike2 name=LuxPeer profile=ikev2-profile
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=1h name=ikev2-proposal pfs-group=none
/ip ipsec identity
add auth-method=eap certificate=lux-cert eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=ikev2-modeconf peer=LuxPeer policy-template-group=ikev2-group username=mikrouser
/ip ipsec policy
add dst-address=0.0.0.0/0 group=ikev2-group proposal=ikev2-proposal src-address=0.0.0.0/0 template=yes
This is what happens when you try to connect.
# 2023-12-10 19:21:12 by RouterOS 7.12.1
19:21:18 ipsec,debug 0.0.0.0[500] used as isakmp port (fd=10)
19:21:18 ipsec,debug 0.0.0.0[4500] used as isakmp port with NAT-T (fd=12)
19:21:18 ipsec,debug ::[500] used as isakmp port (fd=13)
19:21:18 ipsec,debug ::[4500] used as isakmp port (fd=14)
19:21:18 ipsec ike2 starting for: 222.222.222.222
19:21:19 ipsec adding payload: SA
19:21:19 ipsec,debug => (size 0x30)
19:21:19 ipsec,debug 00000030 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005
19:21:19 ipsec,debug 03000008 0300000c 00000008 0400000e
19:21:19 ipsec adding payload: KE
19:21:19 ipsec,debug => (first 0x100 of 0x108)
19:21:19 ipsec,debug 00000108 000e0000 f8beb191 6281d269 3f2d84b3 846fea33 07ecca39 54924d17
19:21:19 ipsec,debug 0a9cbd68 70a57de5 9c157970 35e00cdb e4e348f1 27b59b11 8982ae11 23b82624
19:21:19 ipsec adding payload: NONCE
19:21:19 ipsec,debug => (size 0x1c)
19:21:19 ipsec,debug 0000001c 83c23efc 98302f15 709846c7 4ab5b64c 545697fd 15c032e5
19:21:19 ipsec adding notify: NAT_DETECTION_SOURCE_IP
19:21:19 ipsec,debug 0000001c 00004004 f1b64c00 f60cbf41 a627c1b6 cd9ae147 04915c6c
19:21:19 ipsec adding notify: NAT_DETECTION_DESTINATION_IP
19:21:19 ipsec,debug 0000001c 00004005 8ae051e3 f8925ddd d9f17d8e b89cb150 1572a325
19:21:19 ipsec adding notify: IKEV2_FRAGMENTATION_SUPPORTED
19:21:19 ipsec,debug => (size 0x8)
19:21:19 ipsec,debug 00000008 0000402e
19:21:19 ipsec <- ike2 request, exchange: SA_INIT:0 222.222.222.222[4500] 0347fd4f5bd66dc9:0000000000000000
19:21:19 ipsec,debug ===== sending 432 bytes from 111.111.111.111[4500] to 222.222.222.222[4500]
19:21:19 ipsec,debug 1 times of 436 bytes message will be sent to 222.222.222.222[4500]
19:21:19 ipsec,debug ===== received 456 bytes from 222.222.222.222[4500] to 111.111.111.111[4500]
19:21:19 ipsec -> ike2 reply, exchange: SA_INIT:0 222.222.222.222[4500] 0347fd4f5bd66dc9:da2065f6dc10f5d7
19:21:19 ipsec ike2 initialize recv
19:21:19 ipsec payload seen: SA (48 bytes)
19:21:19 ipsec payload seen: KE (264 bytes)
19:21:19 ipsec payload seen: NONCE (36 bytes)
19:21:19 ipsec payload seen: NOTIFY (28 bytes)
19:21:19 ipsec payload seen: NOTIFY (8 bytes)
19:21:19 ipsec processing payload: NONCE
19:21:19 ipsec processing payload: SA
19:21:19 ipsec IKE Protocol: IKE
19:21:19 ipsec  proposal #1
19:21:19 ipsec   enc: aes256-cbc
19:21:19 ipsec   prf: hmac-sha256
19:21:19 ipsec   auth: sha256
19:21:19 ipsec   dh: modp2048
19:21:19 ipsec matched proposal:
19:21:19 ipsec processing payload: KE
19:21:19 ipsec,debug => shared secret (size 0x100)
19:21:19 ipsec,debug 350493d5 151edc19 3ef64702 dd8a1a7c bd8822eb 90575d31 01a0eed7 630d3d2b
19:21:19 ipsec,debug 77e60c36 aeaeeb60 ad01ff3e 5750818d fd08f461 5184cbb3 dd684c7f d9ed4a12
19:21:19 ipsec,debug => skeyseed (size 0x20)
19:21:19 ipsec,debug 3397c63d 6c141905 bb96d5d0 bfed73ca abc2b0a9 3e4f5b2b ae633f62 da0daff3
19:21:19 ipsec,debug => keymat (size 0x20)
19:21:19 ipsec,debug 27d064e8 2c3989de 44e5f2f5 dbfeee72 821e11fb 8b6d3bfd b93b01fc c595681f
19:21:19 ipsec,debug => SK_ai (size 0x20)
19:21:19 ipsec,debug ac66f4c7 da29948c f528574f 41188f8a df7c0862 9ea1becc bacad847 f0920872
19:21:19 ipsec,debug => SK_ar (size 0x20)
19:21:19 ipsec,debug 025a82db 8757989f 82f00620 7882dd74 53d24951 bbf3cb49 deae69f9 f7dab823
19:21:19 ipsec,debug => SK_ei (size 0x20)
19:21:19 ipsec,debug 471ed9c2 92080983 13b6d1a9 4eeea1d4 4fd74735 b505b0d0 27e47ad0 4b235079
19:21:19 ipsec,debug => SK_er (size 0x20)
19:21:19 ipsec,debug 21fff0dc aa59f5ae b5b8faf2 5f9be772 b3129175 2cff0139 7b342c64 6787c694
19:21:19 ipsec,debug => SK_pi (size 0x20)
19:21:19 ipsec,debug 591a2d41 bfadab36 d8e695fa af65b0d1 7caab715 60492d5e 5e9f8e09 a345d904
19:21:19 ipsec,debug => SK_pr (size 0x20)
19:21:19 ipsec,debug ab068716 aceefd8f b8cc9c86 22c9fe42 f2f2af78 a857bbbe a09fd88f 70ce0a25
19:21:19 ipsec,info new ike2 SA (I): LuxPeer 111.111.111.111[4500]-222.222.222.222[4500] spi:0347fd4f5bd66dc9:da2065f6dc10f5d7
19:21:19 ipsec processing payloads: NOTIFY
19:21:19 ipsec   notify: NAT_DETECTION_SOURCE_IP
19:21:19 ipsec   notify: NAT_DETECTION_DESTINATION_IP
19:21:19 ipsec   notify: IKEV2_FRAGMENTATION_SUPPORTED
19:21:19 ipsec   notify: CHILDLESS_IKEV2_SUPPORTED
19:21:19 ipsec   notify: MULTIPLE_AUTH_SUPPORTED
19:21:19 ipsec (NAT-T) REMOTE LOCAL
19:21:19 ipsec KA list add: 111.111.111.111[4500]->222.222.222.222[4500]
19:21:19 ipsec fragmentation negotiated
19:21:19 ipsec init child continue
19:21:19 ipsec offering proto: ESP
19:21:19 ipsec ID_I (DER DN): CN=VPN root CA
19:21:19 ipsec adding payload: ID_I
19:21:19 ipsec,debug => (size 0x20)
19:21:19 ipsec,debug 00000020 09000000 30163114 30120603 55040313 0b56504e 20726f6f 74204341
19:21:19 ipsec Certificate:
19:21:19 ipsec   serialNr:  6a:4b:4****:e1
19:21:19 ipsec   issuer:    <CN=VPN root CA>
19:21:19 ipsec   subject:   <CN=VPN root CA>
19:21:19 ipsec   notBefore: Wed Aug  9 11:36:28 2023
19:21:19 ipsec   notAfter:  Sat Aug  6 11:36:28 2033
19:21:19 ipsec   selfSigned:1
19:21:19 ipsec   extensions:
19:21:19 ipsec     key usage: key-cert-sign, crl-sign
19:21:19 ipsec     basic constraints: isCa: TRUE
19:21:19 ipsec     subject key id:  *******************:11:28:6c:b3:d8:b8*
19:21:19 ipsec   signed with: SHA384+RSA
19:21:19 ipsec [RSA-PUBLIC]
19:21:19 ipsec modulus: eab2ce4f850398**************************7a32a31c52da0a38
19:21:19 ipsec 5878c1f849184a359fb21
19:21:19 ipsec publicExponent: 10001
19:21:19 ipsec adding payload: CERT
19:21:19 ipsec,debug => (first 0x100 of 0x4f9)
19:21:19 ipsec,debug 000004f9 04308204 f0308202 d8a00302 01020208 6a4b4abc 305a58e1 300d0609
19:21:19 ipsec,debug 3f072e26 c6f573e3 fe834ddd b5fde13f 58bb4fe2 c7f9a693 dae1470f 43b0af7e
19:21:19 ipsec adding notify: INITIAL_CONTACT
19:21:19 ipsec,debug 00000008 00004000
19:21:19 ipsec,debug => (size 0x2c)
19:21:19 ipsec,debug 0000002c 00000028 01030403 0793040b 0300000c 0100000c 800e0100 03000008
19:21:19 ipsec,debug 0300000c 00000008 05000000
19:21:19 ipsec initiator selector: 0.0.0.0/0
19:21:19 ipsec adding payload: TS_I
19:21:19 ipsec,debug => (size 0x18)
19:21:19 ipsec,debug 00000018 01000000 07000010 0000ffff 00000000 ffffffff
19:21:19 ipsec responder selector: 0.0.0.0/0
19:21:19 ipsec adding payload: TS_R
19:21:19 ipsec preparing internal IPv4 address
19:21:19 ipsec preparing internal IPv4 netmask
19:21:19 ipsec preparing internal IPv6 subnet
19:21:19 ipsec preparing internal IPv4 DNS
19:21:19 ipsec preparing internal DNS domain
19:21:19 ipsec adding payload: CONFIG
19:21:19 ipsec,debug 00000030 01000000 00010004 00000000 00020004 00000000 000d0008 00000000
19:21:19 ipsec,debug 00000000 00030004 00000000 00190000
19:21:19 ipsec <- ike2 request, exchange: AUTH:1 222.222.222.222[4500] 0347fd4f5bd66dc9:da2065f6dc10f5d7
19:21:19 ipsec fragmenting into 2 chunks
19:21:19 ipsec adding payload: SKF
19:21:19 ipsec,debug => (first 0x100 of 0x4c8)
19:21:19 ipsec,debug 230004c8 00010002 9acaa592 acc965c7 6bd43146 25b77e34 a8799d2c 4b854349
19:21:19 ipsec,debug a9daa26d da72c37e 517e46e3 9ef7afc2 33b584d6 2f7c3f22 04c16264 9957a2f6
19:21:19 ipsec,debug => (first 0x100 of 0x2d8)
19:21:19 ipsec,debug 000002d8 00020002 9acaa592 acc965c7 6bd43146 25b77e34 73871fce 5eeee769
19:21:19 ipsec,debug 7e57e373 c3595605 4d05aa68 86139eab 2f7e2794 00cd8edd 89b57024 e5c969dd
19:21:19 ipsec,debug ===== sending 1252 bytes from 111.111.111.111[4500] to 222.222.222.222[4500]
19:21:19 ipsec,debug 1 times of 1256 bytes message will be sent to 222.222.222.222[4500]
19:21:19 ipsec,debug ===== sending 756 bytes from 111.111.111.111[4500] to 222.222.222.222[4500]
19:21:19 ipsec,debug 1 times of 760 bytes message will be sent to 222.222.222.222[4500]
19:21:22 ipsec,debug ===== received 80 bytes from 222.222.222.222[4500] to 111.111.111.111[4500]
19:21:22 ipsec -> ike2 reply, exchange: AUTH:1 222.222.222.222[4500] 0347fd4f5bd66dc9:da2065f6dc10f5d7
19:21:22 ipsec payload seen: ENC (52 bytes)
19:21:22 ipsec processing payload: ENC
19:21:22 ipsec,debug => iv (size 0x10)
19:21:22 ipsec,debug 8ccd152b e2a89fcd f78fdec5 f7f0d290
19:21:22 ipsec,debug decrypted packet
19:21:22 ipsec payload seen: NOTIFY (8 bytes)
19:21:22 ipsec processing payloads: NOTIFY
19:21:22 ipsec   notify: AUTHENTICATION_FAILED
19:21:22 ipsec,error got fatal error: AUTHENTICATION_FAILED
19:21:22 ipsec,info killing ike2 SA: LuxPeer 111.111.111.111[4500]-222.222.222.222[4500] spi:0347fd4f5bd66dc9:da2065f6dc10f5d7
19:21:22 ipsec KA remove: 111.111.111.111[4500]->222.222.222.222[4500]
19:21:22 ipsec,debug KA tree dump: 111.111.111.111[4500]->222.222.222.222[4500] (in_use=1)
19:21:22 ipsec,debug KA removing this one...
I carefully copied my login and password several times. Everything looks fine, but every time I try to connect I get
What could be the reason?
What does Linux say, exactly before log: ubuntu: 12[TLS] sending fatal TLS alert ‘handshake failure’
it’s not Ubuntu but Almalinux, anyway here is the full log of any connection attempt
Dec 12 09:22:41 charon[16594]: 04[NET] received packet: from 111.111.111.111[5772] to 222.222.222.222[4500]
Dec 12 09:22:41 strongswan[16594]: 03[MGR] checkin of IKE_SA successful
Dec 12 09:22:41 strongswan[16594]: 04[NET] received packet: from 111.111.111.111[5772] to 222.222.222.222[4500]
Dec 12 09:22:41 strongswan[16594]: 08[MGR] checkout IKEv2 SA by message with SPIs e00b34b8afd2fc6a_i 6dc4d9862f0b494f_r
Dec 12 09:22:41 strongswan[16594]: 08[MGR] IKE_SA (unnamed)[31] successfully checked out
Dec 12 09:22:41 strongswan[16594]: 08[NET] received packet: from 111.111.111.111[5772] to 222.222.222.222[4500] (1220 bytes)
Dec 12 09:22:41 strongswan[16594]: 04[NET] waiting for data on sockets
Dec 12 09:22:41 strongswan[16594]: 10[MGR] checkout IKEv2 SA by message with SPIs e00b34b8afd2fc6a_i 6dc4d9862f0b494f_r
Dec 12 09:22:41 strongswan[16594]: 08[ENC] parsed IKE_AUTH request 1 [ EF(1/2) ]
Dec 12 09:22:41 strongswan[16594]: 08[ENC] received fragment #1 of 2, waiting for complete IKE message
Dec 12 09:22:41 strongswan[16594]: 08[MGR] checkin IKEv2 SA (unnamed)[31] with SPIs e00b34b8afd2fc6a_i 6dc4d9862f0b494f_r
Dec 12 09:22:41 strongswan[16594]: 08[MGR] checkin of IKE_SA successful
Dec 12 09:22:41 strongswan[16594]: 10[MGR] IKE_SA (unnamed)[31] successfully checked out
Dec 12 09:22:41 strongswan[16594]: 10[NET] received packet: from 111.111.111.111[5772] to 222.222.222.222[4500] (564 bytes)
Dec 12 09:22:41 strongswan[16594]: 10[ENC] parsed IKE_AUTH request 1 [ EF(2/2) ]
Dec 12 09:22:41 strongswan[16594]: 10[ENC] received fragment #2 of 2, reassembled fragmented IKE message (1520 bytes)
Dec 12 09:22:41 strongswan[16594]: 10[ENC] unknown attribute type INTERNAL_DNS_DOMAIN
Dec 12 09:22:41 strongswan[16594]: 10[ENC] parsed IKE_AUTH request 1 [ IDi CERT N(INIT_CONTACT) SA TSi TSr CPRQ(ADDR MASK SUBNET DNS DOMAIN) ]
Dec 12 09:22:41 strongswan[16594]: 10[IKE] received end entity cert "CN=VPN root CA"
Dec 12 09:22:41 strongswan[16594]: 10[CFG] looking for peer configs matching 222.222.222.222[%any]...111.111.111.111[CN=VPN root CA]
Dec 12 09:22:41 strongswan[16594]: 10[CFG]   candidate "ikev2-vpn", match: 1/1/28 (me/other/ike)
Dec 12 09:22:41 strongswan[16594]: 10[CFG] selected peer config 'ikev2-vpn'
Dec 12 09:22:41 strongswan[16594]: 10[IKE] initiating EAP_IDENTITY method (id 0x00)
Dec 12 09:22:41 strongswan[16594]: 10[IKE] processing INTERNAL_IP4_ADDRESS attribute
Dec 12 09:22:41 strongswan[16594]: 10[IKE] processing INTERNAL_IP4_NETMASK attribute
Dec 12 09:22:41 strongswan[16594]: 10[IKE] processing INTERNAL_IP4_SUBNET attribute
Dec 12 09:22:41 strongswan[16594]: 10[IKE] processing INTERNAL_IP4_DNS attribute
Dec 12 09:22:41 strongswan[16594]: 10[IKE] processing INTERNAL_DNS_DOMAIN attribute
Dec 12 09:22:41 strongswan[16594]: 10[IKE] authentication of '222.222.222.222' (myself) with RSA signature failed
Dec 12 09:22:41 strongswan[16594]: 10[ENC] generating IKE_AUTH response 1 [ N(AUTH_FAILED) ]
Dec 12 09:22:41 strongswan[16594]: 10[NET] sending packet: from 222.222.222.222[4500] to 111.111.111.111[5772] (80 bytes)
Dec 12 09:22:41 strongswan[16594]: 10[MGR] checkin and destroy IKE_SA ikev2-vpn[31]
Dec 12 09:22:41 charon[16594]: 06[MGR] checkout IKEv2 SA by message with SPIs 1b469cb9aada5b73_i 0000000000000000_r
Dec 12 09:22:41 strongswan[16594]: 05[NET] sending packet: from 222.222.222.222[4500] to 111.111.111.111[5772]
Dec 12 09:22:41 strongswan[16594]: 10[IKE] IKE_SA ikev2-vpn[31] state change: CONNECTING => DESTROYING
Dec 12 09:22:41 strongswan[16594]: 10[MGR] checkin and destroy of IKE_SA successful
Dec 12 09:22:41 strongswan[16594]: 06[MGR] checkout IKEv2 SA by message with SPIs 1b469cb9aada5b73_i 0000000000000000_r
Dec 12 09:22:41 strongswan[16594]: 06[MGR] created IKE_SA (unnamed)[32]
Dec 12 09:22:41 strongswan[16594]: 06[NET] received packet: from 111.111.111.111[5772] to 222.222.222.222[4500] (440 bytes)
Dec 12 09:22:41 strongswan[16594]: 06[ENC] parsed IKE_SA_INIT request 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) ]
Dec 12 09:22:41 strongswan[16594]: 06[CFG] looking for an IKEv2 config for 222.222.222.222...111.111.111.111
Dec 12 09:22:41 strongswan[16594]: 06[CFG]   candidate: %any...%any, prio 28
Dec 12 09:22:41 strongswan[16594]: 06[CFG] found matching ike config: %any...%any with prio 28
Dec 12 09:22:41 strongswan[16594]: 06[IKE] local endpoint changed from 0.0.0.0[500] to 222.222.222.222[4500]
Dec 12 09:22:41 strongswan[16594]: 06[IKE] remote endpoint changed from 0.0.0.0 to 111.111.111.111[5772]
Dec 12 09:22:41 strongswan[16594]: 06[IKE] 111.111.111.111 is initiating an IKE_SA
Dec 12 09:22:41 strongswan[16594]: 06[IKE] IKE_SA (unnamed)[32] state change: CREATED => CONNECTING
Dec 12 09:22:41 strongswan[16594]: 06[CFG] selecting proposal:
Dec 12 09:22:41 strongswan[16594]: 06[CFG]   no acceptable ENCRYPTION_ALGORITHM found
Dec 12 09:22:41 strongswan[16594]: 06[CFG]   no acceptable INTEGRITY_ALGORITHM found
Dec 12 09:22:41 strongswan[16594]: 06[CFG]   no acceptable KEY_EXCHANGE_METHOD found
Dec 12 09:22:41 strongswan[16594]: 06[CFG]   proposal matches
Dec 12 09:22:41 strongswan[16594]: 06[CFG] received proposals: IKE:AES_CBC_256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_2048/MODP_1536
Dec 12 09:22:41 charon[16594]: 06[MGR] created IKE_SA (unnamed)[32]
Dec 12 09:22:41 charon[16594]: 06[NET] received packet: from 111.111.111.111[5772] to 222.222.222.222[4500] (440 bytes)
Dec 12 09:22:41 charon[16594]: 06[ENC] parsed IKE_SA_INIT request 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) ]
Dec 12 09:22:41 charon[16594]: 06[CFG] looking for an IKEv2 config for 222.222.222.222...111.111.111.111
Dec 12 09:22:41 charon[16594]: 06[CFG]   candidate: %any...%any, prio 28
Dec 12 09:22:41 charon[16594]: 06[CFG] found matching ike config: %any...%any with prio 28
Dec 12 09:22:41 charon[16594]: 06[IKE] local endpoint changed from 0.0.0.0[500] to 222.222.222.222[4500]
Dec 12 09:22:41 charon[16594]: 06[IKE] remote endpoint changed from 0.0.0.0 to 111.111.111.111[5772]
Dec 12 09:22:41 charon[16594]: 06[IKE] 111.111.111.111 is initiating an IKE_SA
Dec 12 09:22:41 charon[16594]: 06[IKE] IKE_SA (unnamed)[32] state change: CREATED => CONNECTING
Dec 12 09:22:41 charon[16594]: 06[CFG] selecting proposal:
Dec 12 09:22:41 charon[16594]: 06[CFG]   no acceptable ENCRYPTION_ALGORITHM found
Dec 12 09:22:41 charon[16594]: 06[CFG]   no acceptable INTEGRITY_ALGORITHM found
Dec 12 09:22:41 charon[16594]: 06[CFG]   no acceptable KEY_EXCHANGE_METHOD found
Dec 12 09:22:41 charon[16594]: 06[CFG]   proposal matches
Dec 12 09:22:41 charon[16594]: 06[CFG] received proposals: IKE:AES_CBC_256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_2048/MODP_1536
Dec 12 09:22:41 charon[16594]: 06[CFG] configured proposals: IKE:AES_CBC_128/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/ECP_256, IKE:AES_CBC_256/HMAC_SHA2_384_192/PRF_HMAC_SHA2_384/ECP_384, IKE:AES_CBC_128/HMAC_SHA2_>
Dec 12 09:22:41 charon[16594]: 06[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_2048
Dec 12 09:22:41 charon[16594]: 06[IKE] remote host is behind NAT
Dec 12 09:22:41 charon[16594]: 06[ENC] generating IKE_SA_INIT response 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) N(CHDLESS_SUP) N(MULT_AUTH) ]
Dec 12 09:22:41 charon[16594]: 06[NET] sending packet: from 222.222.222.222[4500] to 111.111.111.111[5772] (456 bytes)
Dec 12 09:22:41 charon[16594]: 05[NET] sending packet: from 222.222.222.222[4500] to 111.111.111.111[5772]
Dec 12 09:22:41 charon[16594]: 06[MGR] checkin IKEv2 SA (unnamed)[32] with SPIs 1b469cb9aada5b73_i 54e0ee2650c8ae3d_r
Dec 12 09:22:41 charon[16594]: 06[MGR] checkin of IKE_SA successful
Dec 12 09:22:41 charon[16594]: 04[NET] waiting for data on sockets
Dec 12 09:22:41 charon[16594]: 12[MGR] checkout IKEv2 SA by message with SPIs 1b469cb9aada5b73_i 54e0ee2650c8ae3d_r
Dec 12 09:22:41 charon[16594]: 12[MGR] IKE_SA (unnamed)[32] successfully checked out
Dec 12 09:22:41 charon[16594]: 12[NET] received packet: from 111.111.111.111[5772] to 222.222.222.222[4500] (1188 bytes)
Dec 12 09:22:41 charon[16594]: 09[MGR] checkout IKEv2 SA by message with SPIs 1b469cb9aada5b73_i 54e0ee2650c8ae3d_r
Dec 12 09:22:41 charon[16594]: 12[ENC] parsed IKE_AUTH request 1 [ EF(1/2) ]
Dec 12 09:22:41 charon[16594]: 12[ENC] received fragment #1 of 2, waiting for complete IKE message
Dec 12 09:22:41 charon[16594]: 12[MGR] checkin IKEv2 SA (unnamed)[32] with SPIs 1b469cb9aada5b73_i 54e0ee2650c8ae3d_r
Dec 12 09:22:41 charon[16594]: 12[MGR] checkin of IKE_SA successful
Dec 12 09:22:41 charon[16594]: 09[MGR] IKE_SA (unnamed)[32] successfully checked out
Dec 12 09:22:41 charon[16594]: 09[NET] received packet: from 111.111.111.111[5772] to 222.222.222.222[4500] (756 bytes)
Dec 12 09:22:41 charon[16594]: 09[ENC] parsed IKE_AUTH request 1 [ EF(2/2) ]
Dec 12 09:22:41 charon[16594]: 09[ENC] received fragment #2 of 2, reassembled fragmented IKE message (1520 bytes)
Dec 12 09:22:41 charon[16594]: 09[ENC] unknown attribute type INTERNAL_DNS_DOMAIN
Dec 12 09:22:41 charon[16594]: 09[ENC] parsed IKE_AUTH request 1 [ IDi CERT N(INIT_CONTACT) SA TSi TSr CPRQ(ADDR MASK SUBNET DNS DOMAIN) ]
Dec 12 09:22:41 charon[16594]: 09[IKE] received end entity cert "CN=VPN root CA"
Dec 12 09:22:41 charon[16594]: 09[CFG] looking for peer configs matching 222.222.222.222[%any]...111.111.111.111[CN=VPN root CA]
Dec 12 09:22:41 charon[16594]: 09[CFG]   candidate "ikev2-vpn", match: 1/1/28 (me/other/ike)
Dec 12 09:22:41 charon[16594]: 09[CFG] selected peer config 'ikev2-vpn'
Dec 12 09:22:41 charon[16594]: 09[IKE] initiating EAP_IDENTITY method (id 0x00)
Dec 12 09:22:41 charon[16594]: 09[IKE] processing INTERNAL_IP4_ADDRESS attribute
Dec 12 09:22:41 charon[16594]: 09[IKE] processing INTERNAL_IP4_NETMASK attribute
Dec 12 09:22:41 charon[16594]: 09[IKE] processing INTERNAL_IP4_SUBNET attribute
Dec 12 09:22:41 charon[16594]: 09[IKE] processing INTERNAL_IP4_DNS attribute
Dec 12 09:22:41 charon[16594]: 09[IKE] processing INTERNAL_DNS_DOMAIN attribute
Dec 12 09:22:41 charon[16594]: 09[IKE] authentication of '222.222.222.222' (myself) with RSA signature failed
Dec 12 09:22:41 charon[16594]: 09[ENC] generating IKE_AUTH response 1 [ N(AUTH_FAILED) ]
Dec 12 09:22:41 charon[16594]: 09[NET] sending packet: from 222.222.222.222[4500] to 111.111.111.111[5772] (80 bytes)
Dec 12 09:22:41 charon[16594]: 09[MGR] checkin and destroy IKE_SA ikev2-vpn[32]
Dec 12 09:22:41 charon[16594]: 09[IKE] IKE_SA ikev2-vpn[32] state change: CONNECTING => DESTROYING
Dec 12 09:22:41 charon[16594]: 09[MGR] checkin and destroy of IKE_SA successful
