Hello
Can yo guys help me out I cant find out whats wrong
[admin@MikroTik] > export
# dec/12/2019 10:47:20 by RouterOS 6.46
# software id = FYEW-70D6
# model = 2011UiAS
# serial number = 4CA90474CE9F
add name=bridge1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
password=****** use-peer-dns=yes user=******
add name=WAN
add name=LAN
/ip ipsec policy group
add name=ike2-policies
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256,aes-128 lifetime=8h
add dh-group=modp2048 enc-algorithm=aes-128 name=ike1-site2
add dh-group=modp1024 lifetime=8h name=ike2
/ip ipsec peer
add address=PublicIP/32 name=ike1-site2 profile=ike1-site2
add exchange-mode=ike2 name=ike2 passive=yes profile=ike2
/ip ipsec proposal
add enc-algorithms=aes-128-cbc name=ike1-site2 pfs-group=modp2048
add enc-algorithms=aes-128-cbc,3des lifetime=8h name=ike2 pfs-group=none
add name=dhcp ranges=10.10.10.99-10.10.10.200
add name=ike2-pool ranges=192.168.77.2-192.168.77.254
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
/ip ipsec mode-config
add address-pool=ike2-pool address-prefix-length=32 name=ike2-conf \
split-include=10.10.10.0/24 static-dns=10.10.10.1 system-dns=no
/tool user-manager customer
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=sfp1
add address=10.10.10.1/24 interface=ether2 network=10.10.10.0
/ip dhcp-client
add interface=ether1
/ip dhcp-server lease
add address=10.10.10.101 client-id=1:f4:6d:4:cd:e:55 mac-address=\
F4:6D:04:CD:0E:55 server=dhcp1
add address=10.10.10.105 client-id=1:74:ea:3a:ca:49:9b mac-address=\
74:EA:3A:CA:49:9B server=dhcp1
add address=10.10.10.103 client-id=1:8:60:6e:86:14:89 mac-address=\
08:60:6E:86:14:89 server=dhcp1
add address=10.10.10.102 client-id=1:50:46:5d:6b:4f:72 mac-address=\
50:46:5D:6B:4F:72 server=dhcp1
add address=10.10.10.100 client-id=1:0:23:63:35:70:41 comment=DVR-16 \
mac-address=00:23:63:35:70:41 server=dhcp1
add address=10.10.10.99 client-id=1:0:23:63:35:6a:d6 comment=DVR-08 \
mac-address=00:23:63:35:6A:D6 server=dhcp1
add address=10.10.10.106 client-id=1:14:dd:a9:7:ee:1f mac-address=\
14:DD:A9:07:EE:1F server=dhcp1
add address=10.10.10.104 client-id=1:1c:b7:2c:1:ac:13 mac-address=\
1C:B7:2C:01:AC:13 server=dhcp1
add address=10.10.10.0/24 dns-server=10.10.10.20 domain=ds.local gateway=\
10.10.10.1 netmask=24 ntp-server=10.10.10.1 wins-server=10.10.10.20
set allow-remote-requests=yes servers=8.8.8.8
add action=accept chain=forward connection-state=established,related \
dst-address=10.10.11.0/24 src-address=10.10.10.0/24
dst-address=10.10.10.0/24 src-address=10.10.11.0/24
add action=fasttrack-connection chain=forward connection-state=\
established,related
add action=accept chain=srcnat dst-address=10.10.11.0/24 src-address=\
10.10.10.0/24
add action=dst-nat chain=dstnat dst-address=Public IP dst-port=80 protocol=\
tcp to-addresses=10.10.10.20 to-ports=80
add action=dst-nat chain=dstnat dst-address=Public IP dst-port=1030 \
protocol=tcp to-addresses=10.10.10.30 to-ports=3389
add action=dst-nat chain=dstnat dst-address=Public IP dst-port=1020 \
protocol=tcp to-addresses=10.10.10.100 to-ports=3389
add action=dst-nat chain=dstnat dst-address=Public IP dst-port=9000 \
protocol=tcp to-addresses=10.10.10.101 to-ports=9000
add action=dst-nat chain=dstnat dst-address=Public IP dst-port=9001 \
protocol=tcp to-addresses=10.10.10.102 to-ports=9000
/ip firewall raw
add action=notrack chain=prerouting dst-address=10.10.11.0/24 src-address=\
10.10.10.0/24
add action=notrack chain=prerouting dst-address=10.10.10.0/24 src-address=\
10.10.11.0/24
/ip ipsec identity
add peer=ike1-site2 secret=f6d8181622a772da497461e9c5d81438
add auth-method=digital-signature certificate=ca generate-policy=port-strict \
mode-config=ike2-conf peer=ike2 policy-template-group=ike2-policies
/ip ipsec policy
add dst-address=10.10.11.0/24 peer=ike1-site2 sa-dst-address=PublicIP \
sa-src-address=Public IP src-address=10.10.10.0/24 tunnel=yes
add dst-address=192.168.77.0/24 group=ike2-policies proposal=ike2 src-address=\
0.0.0.0/0 template=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=****
set api disabled=yes
set winbox port=****
set api-ssl disabled=yes
/lcd
set backlight-timeout=never color-scheme=light default-screen=interfaces \
read-only-mode=yes touch-screen=disabled
/lcd pin
set pin-number=****
/lcd interface
set sfp1 disabled=yes
set ether1 disabled=yes
set ether3 disabled=yes
/system clock
set time-zone-name=Asia/Tehran
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set pppoe-out1 disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set sfp1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
set ether6 disabled=yes display-time=5s
set ether7 disabled=yes display-time=5s
set ether8 disabled=yes display-time=5s
set ether9 disabled=yes display-time=5s
set ether10 disabled=yes display-time=5s
/system logging
add topics=ipsec,!debug
/system ntp client
set enabled=yes primary-ntp=37.156.28.13 secondary-ntp=209.58.185.100
/system ntp server
set enabled=yes multicast=yes
/system routerboard settings
set auto-upgrade=yes
/tool user-manager database
set db-path=disk/user-manager
[admin@MikroTik] >
IPSec Log
10:34:02 system,info ipsec identity changed by admin
10:34:05 ipsec -> ike2 request, exchange: SA_INIT:0 PublicIP[1] cfcc11f25b502f05:000000000000
0000
10:34:05 ipsec ike2 respond
10:34:05 ipsec payload seen: SA
10:34:05 ipsec payload seen: KE
10:34:05 ipsec payload seen: NONCE
10:34:05 ipsec payload seen: NOTIFY
10:34:05 ipsec processing payload: NONCE
10:34:05 ipsec processing payload: SA
10:34:05 ipsec IKE Protocol: IKE
10:34:05 ipsec proposal #1
10:34:05 ipsec enc: aes256-cbc
10:34:05 ipsec prf: hmac-sha256
10:34:05 ipsec auth: sha256
10:34:05 ipsec dh: modp2048
10:34:05 ipsec proposal #2
10:34:05 ipsec dh: ecp256
10:34:05 ipsec proposal #3
10:34:05 ipsec dh: modp1536
10:34:05 ipsec proposal #4
10:34:05 ipsec enc: aes128-cbc
10:34:05 ipsec prf: hmac-sha1
10:34:05 ipsec auth: sha1
10:34:05 ipsec dh: modp1024
10:34:05 ipsec proposal #5
10:34:05 ipsec enc: 3des-cbc
10:34:05 ipsec matched proposal:
10:34:05 ipsec processing payload: KE
10:34:05 ipsec DH group number mismatch: 2 != 14
10:34:05 ipsec adding notify: INVALID_KE_PAYLOAD
0000
10:34:05 ipsec adding payload: SA
10:34:05 ipsec adding payload: KE
10:34:05 ipsec adding payload: NONCE
10:34:05 ipsec adding notify: NAT_DETECTION_SOURCE_IP
10:34:05 ipsec adding notify: NAT_DETECTION_DESTINATION_IP
10:34:05 ipsec adding payload: CERTREQ
10:34:05 ipsec <- ike2 reply, exchange: SA_INIT:0 PublicIP[1] cfcc11f25b502f05:c9b3a0c456e278
0e
10:34:05 ipsec,info new ike2 SA (R): PublicIP[500]-PublicIP[1] spi:c9b3a0c456e2780e:cfcc
11f25b502f05
10:34:05 ipsec processing payloads: VID (none found)
10:34:05 ipsec processing payloads: NOTIFY
10:34:05 ipsec notify: REDIRECT_SUPPORTED
10:34:05 ipsec notify: NAT_DETECTION_SOURCE_IP
10:34:05 ipsec notify: NAT_DETECTION_DESTINATION_IP
10:34:05 ipsec notify: IKEV2_FRAGMENTATION_SUPPORTED
10:34:05 ipsec (NAT-T) REMOTE
10:34:05 ipsec KA list add: PublicIP[4500]->PublicIP[1]
10:34:35 ipsec child negitiation timeout in state 0
10:34:35 ipsec,info killing ike2 SA: PublicIP[4500]-PublicIP[1] spi:c9b3a0c456e2780e:cfc
c11f25b502f05
10:34:35 ipsec KA remove: PublicIP[4500]->PublicIP[1]
