Hello, i’ve succesfully setup a mirkrotik ikev2 certificate vpn server. All works fine from my linux machine and my android phone. Now i need to goes in production where i’ll have two kind of clients:
internal office users which can reach the whole subnet: 192.168.100.0/24
external users (customers) which i want to restrick to just one specific internal ip, our windows server: 192.168.100.x
how do you suggest to proceed? i cannot create at the same time multiple ikev2 peer on mikrotik (i tought to add two peer and set different mode-config with different dhcp-pool).
Define rules based on client certificate is impossible too…
so in the last i tought to define two different split tunnel network and set clients on one split tunnel on fixed software client configuration and use firewall/route to join one split to the other… but it’s a caos!
Any better idea?
We are working on this feature in 6.44 versions. You will be able to specify a different mode-config configuration for different clients based on remote-id matcher.
I am testing this option on 6.44 but I can’t get it to work with Windows integrated IKEv2 client. I guess there are just two viable options for IKEv2 road warriors authentication methods:
rsa signature
eap radius
Basic problem of rsa signature with Windows clients is that you have to set Windows client authentication to Use machine certificates. And then it picks one (I don’t how it decides). As long as you have only one personal certificate in machine store, you are OK. If you have more, you are in trouble. Another problem of using machine certificates on Windows is that you can’t set server identity. This makes it impossible to use two different identities with server (my) identity set as fqdn. The following works fine with strongswan client on android. I have two profiles and one puts me into pool set by one mode-config and the other to the one set by the other mode-config.
But on Windows (with only one certificate imported in machine store) I get “IKE authentication credentials are unacceptable” message. And in router log I get ipsec error “identity not found for peer: DER DN: mycert.vpn.xxxxxx.yy”.
If I disable one identity and set my-id to auto then Windows connects.
If I set the my-id of disabled identity to auto and try to enable it I get the error "Couldn’t change IPsec Identity - a matching identity already exists.
The problem of using RADIUS and multiple identities is even less understandable to me because you actually have only one set of conditions to validate a user. But I admit I am not very experienced in working with RADIUS and maybe I am totally missing something.
Like with PPP, where attribute MIKROTIK_GROUP will change security group in PPP ?
Remote Id for choosing Mode Config is nice but when the network is Active Directories based, admin wants to manage this kind of thing on Active Directory side not on VPN client defining remote id that user can possibly change or provide to somebody else.
This has also been bugging me for a while. I’d like to move all L2TP/IPSec connections to authenticate with IKE2 however there doesn’t appear to be any RADIUS attributes that can be set that configures the mode-config on the IPSec Identities
Using remote_id as a solution to choose mode_config is from my perspective not safe enough.
There is already EAP-RADIUS usable for ike2 auth, then admin wants to manage which mode-config will be chosen from radius side not on the client using remote_id
+1 for mode-config RADIUS attribute
With this attib, IKEv2 VPN sessions would be manage similar to PPP (attribute MIKROTIK_GROUP) . Of course support for Filter-Id will be nice too
