IKEV2 - problem to connect - identity not found for peer
i set IKEv2 vpn server on mikrotik RB2011. But i cant connect with window or with mac.
Everytme i got error "Identity not foun for peer: FQDN:client.vpn.ikev2
Do you know where is my mistake? Thank you for help
jun/24/2020 08:34:53 by RouterOS 6.46.4
software id = 8DG7-UNSH
model = 2011UiAS
serial number = B9180AC59CAC
/ip ipsec mode-config
add address-pool=VPN-IKEv2-POOL address-prefix-length=32 name="VPN IKEv2"
split-include=0.0.0.0/0 static-dns=x.x.x.x,8.8.8.8 system-dns=no
/ip ipsec policy group
add name="IKEv2 Group policy"
/ip ipsec profile
add dh-group=modp2048,modp1536,modp1024 enc-algorithm=aes-256,aes-192,aes-128
hash-algorithm=sha256 name="IKEv2 Profile"
/ip ipsec peer
add exchange-mode=ike2 local-address=x.x.x.x name=IKEv2 passive=yes
profile="IKEv2 Profile"
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1 enc-algorithms="aes-256-cbc,aes-256-ctr,a
es-256-gcm,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm"
lifetime=8h name=ikev2-proposal pfs-group=none
/ip ipsec identity
add auth-method=digital-signature certificate=vpn.ikev2 generate-policy=
port-strict match-by=certificate mode-config="VPN IKEv2" my-id=
address:x.x.x.x peer=IKEv2 policy-template-group="IKEv2 Group policy"
remote-certificate=client.vpn.ikev2 remote-id=user-fqdn:client.vpn.ikev2
/ip ipsec policy
add dst-address=192.168.100.0/24 group="IKEv2 Group policy" proposal=
ikev2-proposal src-address=0.0.0.0/0 template=yes
