i have read but i don’t understand much about networking, i am a simple consumer who uses the mikrotik sxt modem outside. i tried to configure surfshark vpn as per guide. but once connected to the vpnthe connection has slowed down. now i installed the developement version on the router and for now everything works fine.
The titile stated that the connection are killed because of the short TTL of the DNS resolve. You have problem that your VPN connection is slowing down and that is a different problem.
/ip firewall mangle add action=change-mss chain=forward new-mss=1360 protocol=tcp tcp-flags=syn tcp-mss=1453-65535
Might be being slow on a Sunday, but why is there a difference between the new MSS of 1360 and 1453 for the old MSS?
There is a better way than this just limiting to a MTU of 1360
Where have you been all this time? ![]()
Any feedback with the latest beta version? The issue should be resolved there.
Fixing MSS for forward packages
/ip firewall mangle
add action=change-mss chain=forward new-mss=1360 protocol=tcp tcp-flags=syn tcp-mss=1453-65535There is a better way than this just limiting to a MTU of 1360
http://forum.mikrotik.com/t/mtu-troubles-using-ikev2-providers-like-nordvpn-work-around/135154/34
hello, does this change solve the problem?Thank you
No when I look at the subject of this thread. There is a workaround wich can be used till the fix by Mikrotik trickels down to the other versions.
The topic linked to is tackling a different problem of ROS not able return a icmp 3-4 to the correct client when using IKEv2.
I installed version 6.48beta 40, and the connection is stable, there are some slowdowns and blocking of the navigation but I can’t understand why, I don’t understand much about this os and networking. maybe it was better to buy a router for ordinary people. now I just have to tinker and try.
I wanted to ask what these errors are: out-state-mode-errors: 692
in-errors: 0
in-buffer-errors: 0
in-header-errors: 0
in-no-states: 0
in-state-protocol-errors: 0
in-state-mode-errors: 0
in-state-sequence-errors: 0
in-state-expired: 0
in-state-mismatches: 0
in-state-invalid: 0
in-template-mismatches: 0
in-no-policies: 0
in-policy-blocked: 0
in-policy-errors: 0
out-errors: 0
out-bundle-errors: 0
out-bundle-check-errors: 0
out-no-states: 0
out-state-protocol-errors: 0
out-state-sequence-errors: 0
out-state-expired: 0
out-policy-blocked: 0
out-policy-dead: 0
out-policy-errors: 0
I accidentally deleted the fasttracking function from the IP Firewall settings, is it something you need or can I do less? thanks for the answers, sorry for my ignorance
“ordinary people” and IPsec do not fit together well regardless the router manufacturer. IPsec is very flexible in many aspects, and flexibility comes with complexity of setup.
It depends on the CPU power of your router and the bandwidth of your uplink. Fasttracking is a way to simplify the processing of the packets in the firewall, to spend less CPU per an average packet. So if /tool profile shows more than, say, 20 % CPU usage while a normal traffic load is experienced, putting that rule back may help a lot. But due to the order of actions in the firewall, fasttracking also prevents IPsec from working properly in particular setups, as it bypasses also matching of the packets by the IPsec policies’ traffic selectors. So to restrict fasttracking to non-IPsec traffic, you need the “action=accept ipsec-policy=in,ipsec” and “action=accept ipsec-policy=out,ipsec” rules before the action=fasttrack-connection connection-state=established,related one in chain=forward of /ip firewall filter. Without them, the non-IPsec traffic will be handled faster, but IPsec traffic will be handled much slower (because only one in many packets of the fasttracked connections is not fasttracked and thus can hit the policies’ traffic selectors and be delivered via the IPsec tunnel).
The only information is here, but it’s not really useful. So if the tunnel does work otherwise, these errors may be caused e.g. by slow establishment of the tunnel.
6.48beta40 works for me (eliminates ~5 second drop of surfshark peer connection)
Thanks!
Hi all,
I was having two problems relateds with surfshark and mikrotik:
1 - IPsec connection dropping every 5-20 seconds; Fixed it updating the OS firmware to 6.48beta40 version!
2 - After that, the performance was too slow and web pages doesn’t loading; Fixed it disabling the fasttracking command at firewall panel;
Testing at PC it’s looks good…web navigation, youtube videos, and all…at least now =) . Trying to use at Samsung Smart TV and LG Smart TV, I had some streaming problem that doesn’t allow to reproduce videos at youtube, netflix, amazon video or iptv services (spotify looks good, web browsing too)…I tried to use differents DNS (by DHCP server > network), 208.67.222.222 / 162.252.172.57 / 8.8.8.8 / blank…but nothing has changed…need some help, please!
# oct/11/2020 23:25:24 by RouterOS 6.48beta40
# software id = HGAG-UTY7
# model = RB750Gr3
/ip ipsec mode-config
add name=SSVPN responder=no src-address-list=local
/ip ipsec policy group
add name=SSVPN
/ip ipsec profile
add name=SSVPN
/ip ipsec peer
add address=us-ltm.prod.surfshark.com exchange-mode=ike2 name=SSVPN profile=\
SSVPN
/ip ipsec proposal
add name=SSVPN pfs-group=none
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=\
162.252.172.57,149.154.159.92 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=192.168.88.0/24 list=local
established,related,untracked
invalid
in-interface-list=!LAN
connection-state=established,related disabled=yes
connection-state=invalid
/ip ipsec identity
add auth-method=eap certificate=surfshark_ikev2.crt_0 disabled=yes \
eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=SSVPN \
peer=SSVPN policy-template-group=SSVPN username=[my_username]
/ip ipsec policy
add dst-address=0.0.0.0/0 group=SSVPN proposal=SSVPN src-address=0.0.0.0/0 \
template=yes
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
