IKEv2 site to site established but no traffic
I’m relatively new in the mikrotik space. I managed to connect a LANCOM 1781EW+ via IPsec/IKEv2 PSK with a Mikrotik Routerboard RB2011UiAS-2HnD (v7.1.1). The Mikrotik is the initiator.
But now about my problem: The connection is established but there is no traffic going through. The lancom side should be fine, so there has to be a mistake in my mikrotik configuration.
If you have an idea and/or need more information, please leave an answer. I’m going crazy because i can’t find the problem.
Kind regards
Vincent
hello,
could you export your config on both sides of the tunnel?
remove any public IP or sensitive data before publishing it here.
