Hi, I need some guidance
I have a HeadQuarters router, RB750Gr3 (hardware encryption for ipsec)
config was prepared by few persons, I cant get things to work correctly
We have 3 branch offices + partner “acme” company.
- branches uses SSTP to connect using routing (for some reason IPsec tunnels are disconnected within few hours and unable to reconnect)
- amce connects using IPsec
- VPN clients are connecting with IKEv2 VPN
- wifi routers provisioned with CAPsMAN
- additional router for special puroses is connecting through EOiP inside SSTP tunnel (dynamic IP address possible)
IP pools:
- 192.168.1.0 HQ
- 192.168.2.0 192.168.3.0 192.168.4.0 branch offices
- 192.168.19.0 192.168.20.0 192.168.21.0 acme
- 192.168.99.0 - required VPN pool
- 172.16… wifi guests
- 10.0.0.0 admin network (currently same interface, same switch, the plan is to separate)
- 10.0.2.0 10.0.3.0 10.0.4.0 SSTP tunnels
issues:
- duplicated IP address required on bridge and eth2 port (if disabled for ethernet port, then router cant connect to network)
- I’m stuck to create rule to NAT packets from VPN pool (99) to IPsec acme tunnels
- local-proxy-arp and vpn pool from LAN pool solves the problem of VPN to IPsec connection (2), but, all the traffic goes through the router (very bad, as we have 2 switches with LACP configured for few servers, storage, etc… BAD!!)
i have no idea what to fix, tried lot of advices, with no success
# oct/19/2020 02:15:20 by RouterOS 6.47.3
# software id = 0RS9-BIGP
# model = RB750Gr3
# serial number = ********************
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2412,2437,2462 name=2ghz reselect-interval=1h
add admin-mac=00:00:00:00:00:AA arp=local-proxy-arp auto-mac=no name=bridge1-cap-lan
add name=bridge2-guest
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether5 ] comment="CAPsMAN + PoE WiFi mAPs"
/interface eoip
add local-address=10.10.10.1 mac-address=00:00:00:00:00:BB name=eoip-tunnel1 remote-address=10.10.10.2 tunnel-id=0
/caps-man datapath
add bridge=bridge1-cap-lan name=datapath1-lan
add bridge=bridge2-guest client-to-client-forwarding=no name=datapath2-guest
/caps-man rates
add basic=12Mbps name=GN-only supported=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
/caps-man security
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h name=security3-contoso passphrase=********************
add authentication-types=wpa2-eap disable-pmkid=yes eap-methods=passthrough eap-radius-accounting=yes encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h name=security1-eap
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h name=security2-guest passphrase=********************
/caps-man configuration
add channel=2ghz country=poland datapath=datapath1-lan mode=ap name=2ghz-contoso rates=GN-only security=security3-contoso ssid=contoso
add channel=2ghz country=poland datapath=datapath2-guest mode=ap name=2ghz-guest rates=GN-only security=security2-guest ssid=contoso-GUEST
add channel=2ghz country=poland datapath=datapath1-lan mode=ap name=2ghz-eap rates=GN-only security=security1-eap ssid=contoso-EAP
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
/ip ipsec policy group
add name=ike2-policies
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048,modp1536,modp1024 enc-algorithm=aes-256 hash-algorithm=sha256 lifetime=1h
add dh-group=modp1024 dpd-interval=disable-dpd enc-algorithm=3des hash-algorithm=md5 lifetime=38m20s name=acme
add dh-group=modp1024 dpd-interval=disable-dpd enc-algorithm=3des hash-algorithm=md5 lifetime=38m20s name=contoso
add dh-group=modp2048,modp1536,modp1024 enc-algorithm=aes-256 hash-algorithm=sha256 name=ike2
/ip ipsec peer
add address=aa.cc.mm.ee/32 local-address=xxx.xxx.xxx.xx3 name=acme profile=acme
add exchange-mode=ike2 name=ike2 passive=yes profile=ike2
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 pfs-group=none
add auth-algorithms=md5 enc-algorithms=3des lifetime=8h name=acme
add auth-algorithms=md5 enc-algorithms=3des lifetime=8h name=contoso
add auth-algorithms=sha256,sha1 name=ike2 pfs-group=none
add name=dhcp ranges=192.168.1.100-192.168.1.199
add name=vpn ranges=192.168.1.50-192.168.1.49
add name=dhcp-guest ranges=172.16.0.20-172.16.0.100
add name=admin ranges=10.0.0.245-10.0.0.254
add name=ike2-pool ranges=192.168.99.100-192.168.99.200
add address-pool=dhcp-guest disabled=no interface=bridge2-guest lease-time=8h name=dhcp2-guest
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=bridge1-cap-lan lease-time=8h name=dhcp1
/ip ipsec mode-config
add address-pool=ike2-pool address-prefix-length=32 name=ike2-conf split-include=192.168.1.0/24,192.168.2.0/24,192.168.3.0/24,192.168.4.0/24,192.168.19.0/24,192.168.20.0/24,192.168.21.0/24
add address-pool=vpn name=vpnpool split-include=192.168.1.0/24,192.168.2.0/24,192.168.3.0/24,192.168.4.0/24,192.168.19.0/24,192.168.20.0/24,192.168.21.0/24 static-dns=192.168.1.1 system-dns=no
/ppp profile
add bridge=bridge1-cap-lan change-tcp-mss=yes dns-server=192.168.1.1 name=sstp-tunnel use-compression=yes use-encryption=yes wins-server=192.168.1.1
add address-list=vpn-admin,vpn-clients bridge=bridge1-cap-lan change-tcp-mss=yes local-address=admin name=admin remote-address=admin use-encryption=yes
set *FFFFFFFE address-list=vpn-clients bridge=bridge1-cap-lan dns-server=192.168.1.1 local-address=vpn remote-address=vpn use-compression=yes wins-server=192.168.1.1
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes package-path=/ upgrade-policy=suggest-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge1-cap-lan
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=2ghz-eap name-format=prefix-identity name-prefix=2.4GHZ- slave-configurations=2ghz-contoso,2ghz-guest
add bridge=bridge1-cap-lan comment=defconf interface=ether2
add bridge=bridge1-cap-lan comment=defconf interface=ether3
add bridge=bridge1-cap-lan comment=defconf interface=ether4
add bridge=bridge1-cap-lan comment=defconf interface=ether5
add bridge=bridge1-cap-lan interface=eoip-tunnel1
set icmp-timeout=2s
/ip settings
set rp-filter=strict
/interface l2tp-server server
set authentication=chap,mschap2 enabled=yes ipsec-secret=******************** keepalive-timeout=60
add interface=bridge1-cap-lan list=LAN
add interface=ether1-wan list=WAN
add interface=ether2 list=LAN
add interface=ether5 list=LAN
/interface sstp-server server
set authentication=mschap2 certificate=contoso_vpn default-profile=default-encryption enabled=yes force-aes=yes tls-version=only-1.2
add address=192.168.1.254/24 interface=bridge1-cap-lan network=192.168.1.0
add address=xxx.xxx.xxx.xx2/29 interface=ether1-wan network=xxx.xxx.xxx.xx0
add address=xxx.xxx.xxx.xx3/29 interface=ether1-wan network=xxx.xxx.xxx.xx0
add address=192.168.1.254/24 interface=ether2 network=192.168.1.0
add address=172.16.0.1/24 interface=bridge2-guest network=172.16.0.0
add address=10.0.0.1/24 interface=bridge1-cap-lan network=10.0.0.0
add address=10.0.0.1/24 interface=ether2 network=10.0.0.0
/ip dhcp-client
add comment=defconf interface=ether1-wan
/ip dhcp-server lease
# list of static hosts
add address=10.0.0.0/24 caps-manager=10.0.0.1 comment="Admin LAN" dns-server=9.9.9.9 gateway=10.0.0.1 netmask=24
add address=172.16.0.0/24 comment="guest WiFi" dns-server=9.9.9.9 gateway=172.16.0.1 netmask=24
add address=192.168.1.0/24 caps-manager=192.168.1.254 dns-server=192.168.1.1,192.168.1.254 domain=contoso.com gateway=192.168.1.254 netmask=24 ntp-server=194.146.251.100,194.146.251.101 wins-server=192.168.1.1
set allow-remote-requests=yes cache-max-ttl=1d servers=192.168.1.1,9.9.9.9
/ip dns static
# some static addresses
/ip firewall address-list
# some servers added to list "servers"
add address=192.168.3.0/24 list=internal-networks
add address=192.168.1.0/24 list=internal-networks
add address=192.168.10.0/24 list=internal-networks
add address=192.168.4.0/24 list=internal-networks
add address=192.168.2.0/24 list=internal-networks
add address=10.0.0.0/24 list=admin
add address=192.168.99.0/24 list=internal-networks
add action=accept chain=input comment=branch3 src-address=aa.aa.aa.aa
add action=accept chain=input comment=branch1 src-address=bb.bb.bb.bb
add action=accept chain=input comment=branch2 src-address=cc.cc.cc.cc
add action=drop chain=input protocol=tcp src-port=0
add action=drop chain=input dst-port=0 protocol=tcp
add action=drop chain=input protocol=udp src-port=0
add action=drop chain=input dst-port=0 protocol=udp
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=input comment="accept WinBox" dst-port=8291 protocol=tcp
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=accept chain=input comment="accept IGMP" protocol=igmp
add action=accept chain=input comment="accept SNMP<-LAN" dst-port=161 in-interface-list=LAN protocol=udp
add action=accept chain=input comment="accpet IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="accept NAT-T" dst-port=4500 protocol=udp
add action=accept chain=input comment="accept IPSec ESP" protocol=ipsec-esp
add action=accept chain=input comment=VPN dst-port=1101,1701 protocol=udp
add action=accept chain=input comment="accept SSTP" dst-port=443 protocol=tcp
add action=accept chain=input comment="accept SSTP" dst-port=443 protocol=udp
add action=accept chain=input comment="accept WWW" dst-port=80 protocol=tcp
add action=drop chain=input comment="drop all not coming from LAN" in-interface-list=WAN
add action=drop chain=forward dst-address-list=admin src-address-list=internal-networks
add action=drop chain=forward dst-address-list=internal-networks src-address-list=admin
add action=drop chain=forward comment="filter GUEST to LAN" log-prefix="GUEST DROP" out-interface-list=!WAN src-address=172.16.0.0/24
add action=drop chain=forward comment=NETBIOS out-interface=ether1-wan port=137-139 protocol=tcp
add action=drop chain=forward comment=NETBIOS out-interface=ether1-wan port=137-139 protocol=udp
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=accept chain=forward comment="accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=fasttrack connection-state=established,related
add action=accept chain=forward comment="accept established,related, untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu passthrough=yes protocol=tcp tcp-flags=syn
add action=accept chain=srcnat comment="IPSec: acme" dst-address=192.168.19.0/24 src-address=192.168.1.0/24
add action=accept chain=srcnat comment="IPSec: acme" dst-address=192.168.20.0/24 src-address=192.168.1.0/24
add action=accept chain=srcnat comment="IPSec: acme" dst-address=192.168.21.0/24 src-address=192.168.1.0/24
add action=src-nat chain=srcnat comment="IKEv2 masquerade" disabled=yes dst-address=192.168.21.18 log=yes log-prefix="VPN MASQ" src-address=192.168.99.0/24 to-addresses=192.168.1.254
add action=masquerade chain=srcnat comment="IKEv2 masquerade" log-prefix="VPN MASQ" src-address=192.168.99.0/24
add action=masquerade chain=srcnat comment="SSTP masquerade" src-address-list=vpn-clients
add action=src-nat chain=srcnat dst-address-list=admin src-address-list=vpn-admin to-addresses=10.0.0.1
add action=src-nat chain=srcnat comment="traffic to EOIP router" dst-address=10.10.10.2 to-addresses=10.10.10.1
add action=src-nat chain=srcnat comment="GUEST WiFi outbound -> xxx.xxx.xxx.xx3" ipsec-policy=out,none out-interface=ether1-wan src-address=172.16.0.0/24 to-addresses=xxx.xxx.xxx.xx3
add action=src-nat chain=srcnat comment="servers outbound -> xxx.xxx.xxx.xx2" out-interface=ether1-wan src-address-list=servers to-addresses=xxx.xxx.xxx.xx2
add action=src-nat chain=srcnat comment="LAN outbound -> xxx.xxx.xxx.xx3" ipsec-policy=out,none out-interface=ether1-wan to-addresses=xxx.xxx.xxx.xx3
# some inbound dst-nat rules
/ip firewall raw
add action=drop chain=prerouting comment="DNS from outside" dst-port=53 in-interface=ether1-wan log-prefix="DNS DROP" protocol=udp src-address-list=!internal-networks
add action=drop chain=prerouting comment="DNS from outside" dst-port=53 in-interface=ether1-wan log-prefix="DNS DROP" protocol=tcp src-address-list=!internal-networks
add action=drop chain=prerouting comment=NETBIOS in-interface=ether1-wan port=137-139 protocol=udp
add action=drop chain=prerouting comment=NETBIOS in-interface=ether1-wan port=137-139 protocol=tcp
add action=drop chain=output comment=NETBIOS out-interface=ether1-wan port=137-139 protocol=udp
add action=drop chain=output comment=NETBIOS out-interface=ether1-wan port=137-139 protocol=tcp
add action=drop chain=prerouting disabled=yes dst-address-list=admin src-address-list=internal-networks
add action=drop chain=prerouting disabled=yes dst-address-list=internal-networks src-address-list=admin
/ip ipsec identity
add peer=acme secret=********************
add auth-method=eap-radius certificate=contoso_vpn generate-policy=port-strict mode-config=vpnpool peer=ike2 policy-template-group=ike2-policies
/ip ipsec policy
set 0 protocol=ipsec-esp
add dst-address=192.168.19.0/24 level=unique peer=acme proposal=acme sa-dst-address=aa.cc.mm.ee sa-src-address=xxx.xxx.xxx.xx3 src-address=192.168.1.0/24 tunnel=yes
add dst-address=192.168.20.0/24 level=unique peer=acme proposal=acme sa-dst-address=aa.cc.mm.ee sa-src-address=xxx.xxx.xxx.xx3 src-address=192.168.1.0/24 tunnel=yes
add dst-address=192.168.21.0/24 level=unique peer=acme proposal=acme sa-dst-address=aa.cc.mm.ee sa-src-address=xxx.xxx.xxx.xx3 src-address=192.168.1.0/24 tunnel=yes
add dst-address=192.168.99.0/24 group=ike2-policies proposal=ike2 src-address=0.0.0.0/0 template=yes
add dst-address=192.168.1.0/24 group=ike2-policies proposal=ike2 src-address=0.0.0.0/0 template=yes
add distance=1 gateway=xxx.xxx.xxx.xx1
add distance=1 dst-address=xxx.xxx.xxx.xx1/29 gateway=ether1-wan pref-src=xxx.xxx.xxx.xx2 scope=10
add distance=1 dst-address=xxx.xxx.xxx.xx1/29 gateway=ether1-wan pref-src=xxx.xxx.xxx.xx3 scope=10
add distance=1 dst-address=192.168.2.0/24 gateway=10.0.2.2
add distance=1 dst-address=192.168.3.0/24 gateway=10.0.3.2
add distance=1 dst-address=192.168.4.0/24 gateway=10.0.4.2
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set www-ssl disabled=no port=444
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes
/ppp aaa
set use-radius=yes
/ppp secret
add comment=admin name=admin password=******************** profile=admin service=sstp
add comment=acme name=acme_l2tp password=******************** profile=default-encryption service=l2tp
add comment="remote EOiP access" local-address=10.10.10.1 name=contoso-eoip1 password=******************** profile=default-encryption remote-address=10.10.10.2
add comment="tunel VPN" local-address=10.0.3.1 name=sstp-branch1 password=******************** profile=sstp-tunnel remote-address=10.0.3.2 service=sstp
add comment="tunel VPN" local-address=10.0.4.1 name=sstp-branch3 password=******************** profile=sstp-tunnel remote-address=10.0.4.2 service=sstp
add comment="tunel VPN" local-address=10.0.2.1 name=sstp-branch2 password=******************** profile=sstp-tunnel remote-address=10.0.2.2 service=sstp
/radius
add address=192.168.1.1 secret=******************** service=ppp,wireless,ipsec src-address=192.168.1.254 timeout=3s
/snmp
set enabled=yes trap-version=2
/system ntp client
set enabled=yes server-dns-names=tempus1.gum.gov.pl,tempus2.gum.gov.pl
/tool bandwidth-server
set authenticate=no enabled=no
/tool graphing interface
/tool mac-server
/tool mac-server mac-winbox
please advise
