I have a firewall running Router OS and want to connect a Android Phone over Internet using the IKEv2/IPSEC
Plain simple…
Is there any method online defining the process in the most simple way?
Plain simple…
Thank you so much for the directions.
Will have a look into it and also try to see what difference are there in both!
Thanking you again,
Regards,
-Siddharth
You’re welcome.
