remote side is Strongswan armed by Letsencrypt certificate and in order to verify it I install on RouterOS the intermediate certificate “Let’s Encrypt Authority X3 (IdenTrust cross-signed)” from https://letsencrypt.org/certificates/ :
And then, I tried to add one level upper certificate (IdentTrust’s) which used to sign Letsencrypt, from there - https://www.identrust.com/support/downloads (Base64 Root Certificate), finally having the following certificate configuration:
[admin@MikroTik] /certificate> print detail
Flags: K - private-key, L - crl, C - smart-card-key, A - authority, I - issued, R - revoked, E - expired, T - trusted
0 L T name="lets-encrypt-x3-cross-signed.pem.txt_0" issuer=O=Digital Signature Trust Co.,CN=DST Root CA X3 digest-algorithm=sha256 key-type=rsa country="US" organization="Let's Encrypt" common-name="Let's Encrypt Authority X3" key-size=2048 subject-alt-name="" days-valid=1826 trusted=yes key-usage=digital-signature,key-cert-sign,crl-sign
serial-number="0A0141420000015385736A0B85ECA708" fingerprint="25847d668eb4f04fdd40b12b6b0740c567da7d024308eb6c2c96fe41d9de218d" invalid-before=mar/17/2016 19:40:46 invalid-after=mar/17/2021 19:40:46 expires-after=76w5d6h41m19s
1 T name="ident-trust-dst-root-ca-x3.txt_0" issuer=O=Digital Signature Trust Co.,CN=DST Root CA X3 digest-algorithm=sha1 key-type=rsa organization="Digital Signature Trust Co." common-name="DST Root CA X3" key-size=2048 subject-alt-name="" days-valid=7669 trusted=yes key-usage=key-cert-sign,crl-sign serial-number="44AFB080D6A327BA893039862EF8406B"
fingerprint="0687260331a72403d909f105e69bcf0d32e1bd2493ffc6d9206d11bcd6770739" invalid-before=oct/01/2000 00:12:19 invalid-after=sep/30/2021 17:01:15 expires-after=104w6d4h1m48s
but without success.
Does Mikrotik check for key-usage and rejects inappropriate offers? Let’s Encrypt’s key-usage is:
X509v3 extensions:
X509v3 Key Usage: critical
Digital Signature, Key Encipherment
X509v3 Extended Key Usage:
TLS Web Server Authentication, TLS Web Client Authentication
X509v3 Basic Constraints: critical
CA:FALSE
and there are no either data-encipherment, ipsec-end-system, ipsec-tunnel and ipsec-user usages. Is it issue or something else? If it is - whether it’s possible to ignore key-usage and setup IPSec connection?
seems problem not in certificates itself. For test purposes, I generated certificates according to https://wiki.archlinux.org/index.php/StrongSwan and checked host certificate. While output says:
Subject: C = CH, O = strongSwan, CN = my.vpn.fqdn
X509v3 extensions:
X509v3 Authority Key Identifier:
keyid:1A:34:B7:53:47:C1:21:92:7C:D8:86:45:FD:BD:7C:6C:B6:50:58:B3
X509v3 Subject Alternative Name:
DNS:my.vpn.fqdn
TLS Web Server Authentication, 1.3.6.1.5.5.8.2.2
where 1.3.6.1.5.5.8.2.2 (“iKEIntermediate”) declares this certificate will be used for an intermediate node with IPsec and IKE. An “intermediate node” is defined to be an IPsec device that offers IPsec services on behalf of other devices e.g. using tunnel mode and IP forwarding (https://tools.ietf.org/id/draft-ietf-ipsec-pki-req-02.txt), Mikrotik refuses this certificate as well, saying the same:
16:41:15 ipsec,info new ike2 SA (I): 10.10.10.25[4500]-x.x.x.x[4500] spi:8e6080ac5321ea31:e9c36f4115786af4
16:41:15 ipsec,error digital signature verification failed
16:41:15 ipsec,info,account peer failed to authorize: 10.10.10.25[4500]-x.x.x.x[4500] spi:8e6080ac5321ea31:e9c36f4115786af4
16:41:15 ipsec,info killing ike2 SA: 10.10.10.25[4500]-x.x.x.x[4500] spi:8e6080ac5321ea31:e9c36f4115786af4
I kindly ask to point me on what I’m missing. Thank you.
Try setting the “remote-certificate” parameter to “none”. Since the certificates does not have private key, the certificate verification fails. Since they essentially are CA certificates, you do not need to specify them, just installed in the certificate store.
I am one of those who found this topic googling. Just wanted to say thanks, and also confirm that the solution posted by the topicstarter was what actually worked for me.
did you switch to put the Letsencrypt certificate at the “certificate” field or stay the same at “remote-certificate”? can you “ip ipsec export” your settings for my reference, i’m trying but my windows 10 pc can’t connect
