I have problem with my IKEv2 because I have very slow transfer to hosts behind MT (RB2011UiAS with 6.46.7).
My configuration is:
ip ipsec profile add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256 name=vpn_profile
ip ipsec peer add exchange-mode=ike2 local-address=public_ip name=vpn_peer passive=yes profile=vpn_profile send-initial-contact=no
ip ipsec proposal add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=8h name=vpn_proposal pfs-group=none
ip pool add name=vpn_pool ranges=192.168.0.2-192.168.0.10
ip ipsec mode-config add address-pool=vpn_pool address-prefix-length=32 name=vpn_config split-include=0.0.0.0/0 static-dns=8.8.8.8 system-dns=no
ip ipsec identity add auth-method=digital-signature certificate=router generate-policy=port-strict match-by=certificate mode-config=vpn_config peer=vpn_peer remote-certificate=user1 remote-id=fqdn:user1@domain.com
ip ipsec policy set proposal=vpn_proposal template=yes action=encrypt ipsec-protocols=esp
Connection is established from Mac OS based on native IKEv2 built in client.
Results (iperf3):
[ 4] 0.00-1.00 sec 623 KBytes 5.08 Mbits/sec
[ 4] 1.00-2.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 2.00-3.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 3.00-4.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 4.00-5.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 5.00-6.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 6.00-7.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 7.00-8.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 8.00-9.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 9.00-10.00 sec 0.00 Bytes 0.00 bits/sec
And all remote web panels are loading very slow through the vpn.
Who can help me? Thanks in advance.
Mike
