I have successfully got an IPv4 tunnel running through an IPv6 connection, and this works successfully (for the record, the config is below).
Does RouterOS support an IPv6 tunnel running through an IPv6 connection?
If so, what must the policy look like to make this work?
/ip ipsec mode-config
add address-pool=default-dhcp name=roadwarrior split-include=192.168.195.0/24
/ip ipsec peer profile
add dh-group=ecp256,modp2048,modp1536,modp1024 enc-algorithm=aes-256 hash-algorithm=sha256 name=roadwarrior
add dh-group=ecp256,modp2048,modp1536,modp1024 enc-algorithm=aes-256 hash-algorithm=sha256 name=rwipv6
/ip ipsec policy group
add name=roadwarrior
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=blowfish pfs-group=modp4096
add auth-algorithms=sha256,sha1 enc-algorithms=aes-256-cbc lifetime=8h name=roadwarrior pfs-group=none
/ip ipsec peer
add address=0.0.0.0/0 auth-method=eap-radius certificate=my-cert exchange-mode=ike2 \
generate-policy=port-strict mode-config=roadwarrior passive=yes policy-template-group=roadwarrior profile=roadwarrior send-initial-contact=\
no
add auth-method=eap-radius certificate=my-cert exchange-mode=ike2 generate-policy=\
port-strict mode-config=roadwarrior passive=yes policy-template-group=roadwarrior profile=rwipv6 send-initial-contact=no
/ip ipsec policy
set 0 disabled=yes
add dst-address=192.168.200.0/24 group=roadwarrior proposal=roadwarrior src-address=0.0.0.0/0 template=yes
