IKEv2 VPN | LAN connectivity issues
First of all - Hi Everyone!
So, this is my first post here. I have my MT hAP ac3 since few months. Recently I have decided to use protonVPN and followed the proton’s configuration guide:
https://protonvpn.com/support/vpn-mikrotik-router/
Now, what I don’t get is how to get rid of connectivity issues that appear as soon as I enable VLANs to be a part of VPN:
 SEQ HOST                                     SIZE TTL TIME       STATUS
   20 10.0.0.47                                  56 255 2ms522us
   21 10.0.0.47                                  56 255 2ms834us
   22 10.0.0.47                                  56 255 2ms553us
   23 10.0.0.47                                  56 255 2ms672us
   24 10.0.0.47                                  56 255 4ms900us
   25 10.0.0.47                                  56 255 6ms611us
   26 10.0.0.47                                  56 255 2ms977us
   27 10.0.0.47                                  56 255 4ms269us
   28 10.0.0.47                                  56 255 2ms500us
—> at this point I’m enabling concerned VLANs to fall under “under_protonvpn” address list in IP → Firewall → Address Lists
   29 10.0.0.47                                                    timeout
   30 10.0.0.47                                                    timeout
   31 10.0.0.47                                                    timeout
   32 10.0.0.47                                                    timeout
   33 10.0.0.47                                                    timeout
   34 10.0.0.47                                                    timeout
    sent=35 received=21 packet-loss=40% min-rtt=2ms340us avg-rtt=3ms120us
   max-rtt=6ms611us
As you can see, even traffic from gateway to endpoint won’t work. I was testing end hosts connectivity between different VLANs, behaviour is always the same. I was trying to find the root cause, but it looks I’m lacking experience to figure it out.
Routing before and after enablement of VPN seems to be the same. If I understand correctly, enabling particular VLAN on the mentioned “under_protonvpn” address list is adding specific packet marking as per proton’s configuration guide:
5. Mark ALL traffic that you want to route through VPN server
/ip firewall address-list add address=192.168.88.0/24 list=under_protonvpn
/ip firewall mangle add action=mark-connection chain=prerouting src-address-list=under_protonvpn new-connection-mark=under_protonvpn passthrough=yes
My aim is to have VPN enabled on all needed VLANs and keep the communication between VLANs and gateway or other VLANs based on firewall rules I’ll define. For example right now I cannot even reach my printer in PRINTER VLAN from PC VLAN, so every time when I want to print something, I need to disable entries in address lists to have the job done.
Any ideas?
Regards!
read this to get some ideas:
http://forum.mikrotik.com/t/mikrotik-wireguard-setup-for-protone-vpn/159161/10
