I managed to configure ikev2 user to server vpn. But I noticed that download speed goes from 100 Mbps to around 20 Mbps when I connect to vpn.
When I configured openvpn this decrease in download speed did not happen.
I have mikrotik hap Lite TC
Most likely, MTU issue. Adjust it using mangle rules, as this is not automatic (PDMTU) like in other protocols.
Kind regards.
Ok, but why in openvpn with default firewall config speed is fine? What changes in ikev2 regarding MTU? Firewall rules are the default one. I just added rules to allow input in ports 4500,500
Tried to disable firewall rule fasttrack but still same
Same situation after adding:
chain=forward action=change-mss new-mss=1360 passthrough=yes tcp-flags=syn
protocol=tcp tcp-mss=!0-1360 log=no log-prefix=“” ipsec-policy=in,ipsec
I also noticed the CPU speed of mikrotik goes to 90% or more when I test internet speed
What do you spect from this hardware? It is very limited. If MTU is adjusted properly, next bottleneck will be CPU.
Regards.
Can you please help me on how to adjust MTU, I am a newbie and maybe I am not doing it properly. I tried to add the mangle rule described above and also disablde fasttrack but CPU usage ad download speed is always same.
Check if your router model supports hardware acceleration for AES (IPSec). If not, encryption will be performed using software and the maximum throughput
will be limited to the CPU power.
https://help.mikrotik.com/docs/display/ROS/IPsec#IPsec-Hardwareacceleration
Model is mikrotik hap Lite TC ad it does not support HW acceleration
Okay, that’s probably the main reason for the bottleneck.
If possible, give WireGuard a try as it tends to be a bit more lenient when it comes to software encryption.
Wireguard is not an option in this model
Okay, why is that? As far as i know, WireGuard is supported on all platforms using ROS v7.
My mikrotik device goes to 6.49.12 when I update it from Check For Updates.
According to Mikrotik’s product page for hAP lite TC, it supports the latest version ROS v7.13.2 if you want to try upgrading. There’s some information on their website and various posts in the forum on how to upgrade. Remember to first make a backup if you would like to go back to v6.
https://help.mikrotik.com/docs/display/ROS/Upgrading+and+installation
You need to switch from “stable” to a special channel called “upgrade”, which is available in the latest v6 version installed on your router. Then hit Check for Updates again and you’ll see the latest stable v7.
On v7 it will be unusable
