IKEv2 w/ iOS and macOS: an unexpected error occurred
Has anyone recently tried to set up an IKEv2 connection for roadwarrior setups for iOS/macOS?
I’m getting an odd error, almost immediately after trying to turn on the connection, an error on the device pops up “an unexpected error occurred.” Not very informative, but seeing almost no logs on the router, I have to point to the client/profile instead. The only difference between this and something like my previous pfsense set up was the certificates, one set generated previously via pfsense, and these being generated on RouterOS.
I turned on debug logging and do see a single packet being received then sent, consistently every time. Perhaps this is a RouterOS issue, but not sure what steps I can take to see if this is a bug or misconfiguration.
Curious if anyone has encountered a similar situation and what the solutions are, if anyone has any.
RSA or ECDSA certificates? I am currently struggling to get ECDSA auth to work on Apple devices and getting the same error. RSA auth seems to work fine though.
