IKEv2 with mode-config address on wrong interface
Hello everybody,
I have a number of Mikrotik devices connected via IPSEC/IKEv2. This works just fine in general, but looks like I have a wired issue with NAT. First devices behind NAT connects without any issues. If I connect a second device behind the same NAT the connection is established, but mode-config address is assigned to a wrong (random?) interface:
[admin@milkrotik] > / ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   10.1.1.1/24        10.1.1.0        br-intern
 1   192.168.1.1/24     192.168.1.0     br-guest
 2 D 10.1.2.18/24       10.1.2.0        en
 3 D 172.31.255.250/24  172.31.255.0    wl-intern
[admin@mikrotik] > / ip route print where dst-address=0.0.0.0/0 dynamic
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  0.0.0.0/0                          10.1.2.1                  1
As you can see the default gateway is available via interface “en”. The mode-config address (172.31.255.250/24) is assigned to “wl-intern” (which does not have any other addresses but is bridged to “br-intern”), though. Anything I can do to fix this? Or can anybody confirm this is an issue in RouterOS?
Please send supout.rif file to support@mikrotik.com and I will look into it.
I opened Ticket#2018012322003459.
Fixed in 6.42rc28 with
*) ipsec - properly detect interface for "mode-config" client IP address assignment;
Thanks a lot, Mikrotik!
I am testing some roadwarrior setups with mode-config sending an IP for the remote end to use. At the remote end though the IP address is then assigned to a ‘random’ interface without rhyme or reason. How can I tell IPSEC to take the assigned address and bind it to whatever interface I need it to go to?
For example, in testing this I manually assigned 192.168.99.2 to a GRE interface and when I joined the VPN IPSEC decided to dynamically bind 192.168.99.2 (sent by the remote mode-config) to VLAN200 (one of my other interfaces). So the address list has 192.168.99.2 on GRE and VLAN200. This seems broken!? Using Long Term 6.45.8.
You have the same address inside and outside the GRE tunnel?
Looks like your havoc originates there.
Anyway, this issue is resolved, please one a new topic with details on your topic.
Well 2 problems, but getting back to the interface issue, seeing as you can assign which interface gets the address, how does the router make a good choice? Today it decided one of my VLAN interfaces would do.
