I believe the 5 GHz country-info frequencies for New Zealand are wrong and contain frequencies not allocated for WiFi.
I leave my 802.11ac 2x2 router on auto frequency selection and often I’ll find my 5 GHz SSID is missing completely from Windows and Android. I believe this is because the allocated frequency is outside the New Zealand regulatory domain.
If I set channel width to ‘20/40/80MHz eeeC’ RouterOS will quite happily choose the frequency ‘5850/20-eeeC/ac’
According to Radio Spectrum Management NZ (page 2) this is satellite earth transmit allocation (assuming 5250MHz is centre of 20MHz width channel):
https://www.rsm.govt.nz/consumers/pdf-and-documents-library/Wi-Fi%20Devices%20using%20the%205%20GHz%20Band.pdf
I believe the 5760-5870 MHz range needs to be deleted from New Zealand country-info.
RouterOS shows country-info “new zealand”:
ranges: 5170-5250/a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(23dBm)/indoor
5250-5330/a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(27dBm)/dfs,passive
5490-5730/a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(27dBm)/dfs,passive
5735-5835/a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(30dBm)/outdoor
5760-5870/a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(36dBm)/outdoor
Linux regulatory database lacks the last frequency range for example:
https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/tree/db.txt
country NZ: DFS-ETSI
(5170 - 5250 @ 80), (17), AUTO-BW
(5250 - 5330 @ 80), (24), DFS, AUTO-BW
(5490 - 5730 @ 160), (24), DFS
(5735 - 5835 @ 80), (30)
Regards,
James Grant.
