Implementing a VLAN solution
Any chance you can tag Tutorial: Home VLAN configuration (RB5009, cAP ACs, multiple SSIDs) so it shows up in the useful articles section? I don't see any bad advice, although I know nothing about capsman, so can't comment on that portion.
No public access to network devices so plugging holes not needed.
Sorry B, I’m not familiar with the forum and how to accomplish what you ask. My trust level is basic user. I’ve turned over stones and haven’t found the tag option.
I was requesting that a moderator ( @BartoszP ) tag the tutorial as a useful article because it is a semi-complete example of a home router with 4 vlans.
Shows you how little I know. I am happy the content has some value. The feedback from this community has helped me a great deal since I started using MikroTik. I wanted to give something back.
Sure, I was just joking a little bit. :slightly_smiling_face:
Though, for a few cents each, rubber ethernet anti-dust plugs are (IMHO) a good idea.
For normally mounted devices dust is not such a big problem, but I have a few (ISP) routers that are mounted on the wall vertically, with the RJ45 sockets on the upper side, so I started using them, plugging a few of them also in some unused ports of "normally mounted" devices and they do a good work also there.
The operation is a seed plant. They invented dust:) I can;t recall the last time I installed a device with the hole pointing up. I’ve had to pick out a few flies so I try to avoid it.
Tagged
Maybe they invented it, but I can guarantee you that in batch (concrete mix) plants (making use of fly ash), the idea has been further improved :wink:
... especially due to its capability of solidifying after becoming wet.
On January 26 a milestone was achieved. I implemented a VLAN solution in the company network. Starting with four VLAN’s, I was able to move from the existing network to a VLAN network. During the same exercise the fiber network was installed and made operational.
The future plan is to cull the network and expand the VLANs. For now the network is operational on VLAN’s and that is something six months ago was just a dream.
The assistance provided by the members in this forum was invaluable to achieving that milestone. Thank you to all those that chimed in to share their insight.
