implementing wpa2
I have working wireless network with two nodes and one backbone link. I want to encrypt the backbone wireless link as I noticed that my passwords are constantly being stolen (I guess someone is catching the packets on the link).
So how do I do that? Create security profile with only WPA2 enabled and Pre-shared key ?
What mode should be used? I am looking for simplest method.
Just tell me what I need to do on both sides so the link continues to work.
Is the wireless link between two mikrotik routers using WDS?
no everything is working fine right now. I just want to encrypt the data traveling across.
It is a simple setup currently - AP bridge on one side and AP client on the other side… no WDS no anything else
basically yes - create profile with WPA2 and preshared key, and set it up as security profile for interface, do not forget to add that on all ends of wifi links.
