I can not import the devices the dude 3 to 6:34.
I tried to export to XML and import via command line.
Already I deleted the old logs.I still fail.
The Dude is blank.
Portuguese
Não consegui importar os devices do dude 3 para o 6.34.
Eu tentei exportar para xml e importar via linha de comando.
Já deletei os logs antigos. Não obtive sucesso.
O Dude permanece em branco.
For when this is fixed, can someone clarify the steps for importing the backup.tgx file into another server?
“save backup to version 4.03 file with backup.tgz and then import this file to version 6.34 backup.xml I had same problem now work fine”
…is not very clear, since there seems to be a few different ways to do this from the CLI according to the options. I do not see any options related to xml.
I´m a Brazillian as well. i Use to have the same problem as you on 6.34 builds. Today i update to the latest 6.35RC4 and imported the XML file from Dude 3.6 using the command :
