I have exported a list of leases from Router A and I need to import this list into Router B. What is the easiest way to do this?
Thank you
Thank you
I am assuming you are talking about static leases.
If it’s Mikrotik to Mikrotik:
you should be able to export from /ip/dhcp-server/lease and then paste straight away in terminal on new router.
Foreign router/server to Mikrotik:
How I did it last year (did it as part of decommissioning a Windows DHCP server for an RB5009):
Yes; MK to MK.
I made them all static for simplicity. I exported to txt file, but I can copy and paste. Where do I paste? \ip\dhcp-server\lease ???
The same place they were exported from … /ip/dhcp-server/lease/ seems a sensible place.
Got it; I didn’t realize it exported as a command.
Sincerely,
Captain Observant
It did work, by the way. Thank you for the help.
