Import Export configuration - Mikrobits vs CCR
Dear Expert,
I have new Mikrotik CCR 1036 with v6.4 software. I plan to export my Mikrobits’s (v6.7 software) configuration to this new CCR.
After backup the config then restore it to CCR, suddenly the CCR cannot boot, the LCD turn OFF… Then I have to reset the CCR.
Any idea howto migrate my Mikrobits’s configuration to CCR?
Regards,
Daniel
First, upgrade both units to v6.15. It is preferred that both units run the same software when migrating config.
I can’t see how Export could have done this, maybe the device not booting is a coincidence. Try to hook up a serial cable and check what is the output.
HI, thank you for the advise… I’ll upgrade both to the same OS
