I am trying to create a backup script from CCR-1009-8G-1S from one machine to another, so i can have it running, should the primary router fail. I have been using Mikrotik for several years and understand a little more than the basics, so i am not a complete newby.
The import/export is simply horrible when trying to create standard configs to be used across several routers.
In the case above, it is exactly the same everything, exact MAC address.
When i import, the first error i get is:
expected end of command (line 17 column 26)
***There is no wireless setup on a CCR, so i tried to edit the supplicant identity and couldnt figure out how to, as the identity is supposed to be the same as system->identity, but isnt.
I removed the following from the script:
I reloaded the file, reset the configuration, and imported the file again, without the two lines above.
I get the same error:
I really like Mikrotik, but i am so fed up with this importing/exporting. I have had this problem for years, and never written to the forum before. I have broken it down into small scripts, but there is issue with that as well, if they arent imported in the right order.
I can see that the script was partially imported, but that is it.
Can someone please alleviate this ongoing searing headache that Mikrotrik is causing me in this situation.
