I wanted to update snmp settings on the whole lot of routers.
This is my old snmp settings which i easly could export on one router and import on another.
/snmp
set contact=mail@company.net enabled=yes engine-id="" location=somewhere trap-target=0.0.0.0 trap-version=1
/snmp community
set passcode address=0.0.0.0/0 authentication-password="" authentication-protocol=MD5 encryption-password="" encryption-protocol=DES name=passcode \
read-access=yes security=none write-access=no
But the new settings export nicely, but the import failes. Setting the same settings from winbox workes, but from cli i get an error message.
/snmp
set contact="Someone" enabled=yes engine-id="" location=Somewhere trap-community=public-company.net trap-target=0.0.0.0 trap-version=3
/snmp community
set public-company.net address=0.0.0.0/0 authentication-password=passcode authentication-protocol=SHA1 \
encryption-password=passcode encryption-protocol=DES name=public-company.net read-access=yes security=private \
write-access=no
/snmp
set contact="someone" enabled=yes engine-id="" location=somewhere trap-community=public-company.net trap-target=0.0.0.0 trap-version=3
The error message i get when importing the snmp.rsc file is.
Opening script file snmp.rsc
Script file loaded successfully
input does not match any value of trap-community
interrupted
When passing in the values manually I get this error.
[admin@router34] /snmp> set contact="Someone" enabled=yes engine-id="" location=Somewhere trap-community=public-company.net trap-target=0.0.0.0 trap-version=3
And when i try to manualy add the comunity
[admin@router34] /snmp community> /snmp community
[admin@router34] /snmp community> set public-company.net address=0.0.0.0/0 authentication-password=passcode authentication-protocol=SHA1 \
\... encryption-password=passcode encryption-protocol=DES name=public-company.net read-access=yes security=private \
\... write-access=no
no such item
All routers are running RouterOS 5.4. If I add the same data from winbox it works nicely.
Is there any clear error here?? Names, Locations and passcodes replaced for security reasons.
