First of all, Great program! But if I can’t restore I’m afraid it stops here.
I’m having trouble importing xml file. I wanted to install a Beta so I first exported my config then removed 2.2 then installed latest Beta. Tried import which gave “connection to local server failed” error. Then I removed the Beta, reinstalled 2.2, tried import with same problem “connection to local server failed”. I can’t import my old config. I’m running the dude locally. I hope this is solvable because I had a lot of work creating this layout.
Regards, Patrick
