Import OVPN file error
no end tag found for tls-auth
Anyone can help me with this error on my mykrotik, I am trying to import an OVPN file, and it is not working
This means that your OVPN file contains the tag but not the tag. If you need more help you will need to provide a redacted (i.e.: sensitive information removed) copy of the OVPN file you’re having trouble with.
Backups are your friend. Always make a backup!
/system backup save encryption=aes-sha256 name=MyBackup
Please, export and attach your current config to your post if you want help with a config issue:
/export hide-sensitive file=MyConfig/export file=MyConfig
