Important problem with bandwith
Hi All.
I have setup a router os in a old pc (PII 333).
I also have 3 wlan 80211.b ifaces and one lan iface.
The problem is that , when I have traffic over 1 Mibit in someone wlan iface , i can’t pass almost nothing to the other ifaces.
In one of them I pass my internet connection and is dead when interchange data by using an other iface.
What is look that? Is maybe a low cpu problem?
you probably have an interference problem with the WLAN, you can only use 3 non-overlapping channels with 802.11b these are 1,6,11 make sure your cards are set to these.
It’s sure that the 80211.b overlaping so much channels?
Us I know the 80211.g overlaping 3 channels but the 80211.b is working in a single channel. My setup is use 2,5 and 8 channels
I have to informe you also that some times when the traffic is very heavy the one interface is loosing the connection.
It might be a 5 V problem in cocnlusion?
I am very sure about the channels overlapping so much, this is one reason so many WISPs are moving to 802.11a (5GHz) where there is a little more space.
You may have a power problem too but it is easy to try different channels first.
Thank you so much. Problem solved…
