Importation script file from RB1000 to RB1100 or another....
Is it possible to import the script file (.rsc) from a RB1000 (4 ethernet ports) to RB1100 AH (13 ethernet ports) without doing any modification or changing?
I need a very detailed answer.
Thank you all…
Yes, it should be possible. Since RB1000 has only 4 ethernets all config on RB1100 will be added to first four ethernets.
I recommend you to make that RSC file from the latest version of RouterOS, because it has the “compact” setting. Compact Export files will import better.
/export compact file=name
Thank u all
I try to backup use the command /export compact
but this command not found on my router
export compact file=test-compact
bad argument name compact (line 1 column :sunglasses:
information about my router:
RB 1000
routerboard: yes
model: “1000”
current-firmware: “2.14”
upgrade-firmware: “2.15”
