Is possible configure the MRRU for receive the different packet size?
I don’t know really the function of MRRU.
If i configure MRRU to 65535, is possible navigate correctly to every webpage’s?
Thank you,
Thank you,
The MTU or MRU size on LNS side i don’t know because is DSL connection, and i don’t know how ISP works with this configurations.
If I check ping on 1700 i don’t receive any response, time out.
Always, the router must be fragmented the packets, is this the problem, in this case, the router don’t fragmented any packets.
Thank you,
I have the same situation. My L2TP server has MaxMRU/MaxMTU 1462/1462. Profile has Change TCP MSS set to yes. When my aDSL users connect through Telco LAC, in their status tab I see MTU 1462 and MRU 1492. It breaks my dynamic Mangle rule for out-interface all-ppp.
I’ve tried to connect on L2TP server with another MT router even with MaxMRU/MaxMTU 1500/1500 (as client) and on the server side in status tab I see MTU 1462 and MRU 1462 as it supposed to be.
Have you solved this problem and if yes, how?
Thanks!
I’ve figured out where was the problem.
As LAC is not MT, it has different config.
