¿Impossible run metarouter openwrt on RB1100 AHx2 ?
Hi Friends…
Recently got this RB and when i try import template file ( openwrt ) i cant!, not enough resources…¿its normal? :open_mouth:
EDIT: OMG! Dont know why not supported… OMG! :open_mouth: FaiL
http://forum.mikrotik.com/t/metarouter-and-1100ah-on-ros-5-8-not-working/51609/1:frowning:
¿Never will supported?
unfortunately MetaROUTER is not yet supported on RB1100AHx2. No ETA yet when this will be resolved.
Hi
What about metarouter on rb1100ah (P2010 cpu )?
Regards
Ali
it works on new RB1100AH. In previous versions there where problem that you could get message - not enough resources, in that case, update to latest version (5.12 at the time of writing) downgrade to 5.11 and upgrade back, or use netinstall tool to reinstall RouterOS.
Hello Are there any progress in the launch function metarouter on rb1100ahx2? I have installed version 6.20.
/ metarouter> add
failure: not enough resources
