impossible to log in using old account
to get logged in to this forum is a complete mess…
I have already a MikroTik account - cannot login
I have to register a second time - not possible, account exists
I cannot use my account to login
I reset password and set a username - cannot login
After some 10 to 20 times it somehow worked now…
Is it a need to make things that complicated???
Best option is to contact support@mikrotik.com, they should be able to get your message to someone able to check what’s happening behind the scenes.
I don’t want to confuse anyone… :wink:
Like @holvoetn said. Contact with support - i had similar problems with ‘old’ forum account etc. If you know your login or email address used in forum acoount- they will definitely help you. Let me know.
If I had known which troubles are waiting for me, I’d made a video capture of my screen while trying to login for half an hour… :wink:
“Useless” for me as someone who’s last possible help is a vendor-related forum, is a login procedure that at first delivers even more problems.
Nice, if in your world everything works out of the box :wink:
NOW we are off topic. I try to delete the thread.
There are two problems:
The first is that nowhere in the forum is there “something” with which you can contact the administrators,
everything left to itself or you deduce to contact support@mikrotik.com
The second, that a title like “impossible” it doesn’t help anyone, on the contrary it creates spam in the search results in the forum.
#2 title changed
#1 nothing I can do about that.
“old account”?
everything left to itself or you deduce to contact > support@mikrotik.com
