I finally get 4G signal being behind a mountain with a LHG LTE.
But the signal is low, and the connexion not perfectly stable. I have a signal strengh between -115 and -119db.
I wonder if I could improve it in putting the LHG LTE module on a LHG XL antenna. Is someone here tried this ?
and what about a LDF LTE module like with a satellite 80cm parabolic antenna ?
Do you have another solution to improve the connexion ?
Thank you
