Wake on Lan (wol) feature now sends a Layer 2 magic packet
Many devices expect a UDP magic packet like below:
Please update tool to support version 2 of the magic packet for wol.
It would be great also if you could add a WOL tool in webfig also (define devices with MAC and just click on button to wake-up or even schedule a wake-up time).
esimotas:
this is a good idea, you should send this to support@mikrotik.com
Here is a PHP script which does Wake on Lan Version 2.
This should clear the air on this.
php_wol.zip (3.53 KB)
Your assumptions are not correct. There is no “version 2” of WOL, see http://en.wikipedia.org/wiki/Wake-on-LAN .
RouterOS already supports sending both types of WOL packets, either as Layer2 or as UDP, see the manual:
http://wiki.mikrotik.com/wiki/Manual:Tools/Wake_on_lan
To send as UDP, specify the interface name.
Correct links to the images from esimotas post:
see post above, specify interface and correct type of magic packet will be sent
It sounds quite good! It would be nice.
Òscar
grg
February 24, 2013, 4:03pm
9
I would prefer if there was something like send WoL packet option when you right click on DHCP lease and bring up the menu in WinBox.
