Hi guys here are mine oppinion about Mikrotik future release and products for OS and what should they improve in their RB line immediately
1)First and foremost concerning addons packages
**a)**OPEN VPN PACKAGES community edition improvements versus UBUQUiTY ROUTERS which has all features
-lzo compression
-udp support
-username authentification none
-tls check
-graph monitoring and web site configure
EDGE ROUTERS HAS THIS ABBILITY
Make some agreement with OPEN VPN programmers or make new line of routerboard with hardware acceleration chip for OPEN VPN PROTOCOLS just like IPSEC protocols
**b)**UPS package support beside APC they should add other protocols like blazer EATON and other just like NUT package or make some collaboration with them so they can make UPS monitoring even further also add SNMP protocol inside basic router flash,
EDGE routers has the abillity to install NUT UPS monitor tools
**c)**DITCH L2TP/IPSEC PROTOCOL or make some improvements in terms of:
-problems with NAT which you must use separate address pool for user behind PUBLIC same IP ADDRESS
-cannot use PURE/IPSEC and l2TP parallel on one router problem and conflict with username and password ppp and ipsec
-use ceritfikates and preshared key parallel in IKEv2 and IPSEC conflict solution and more programming bug fixes
-develope and fix IKEV2 with username and password radius authentification
also developed their VPN own programs to connect to router on WINDOWS and MAC MACHINE must have which can help hassle and trouble
i down know about ANDROID and IOS devices but they work good with routers,
**d)**Make routers with at least 128 MB flash and give more seminars or MUM conference about using OPEN WRT or some other software for META ROUTERS
or some other Possibility for METAROUTERS development like ASTERISK VOIP or something beneficial stuff
**e)**Make agreement with some company which can support PROXY IDS IP FILTERING and ANTI VIRUS as option so the router and IDS platform can work in parallel
and make MUM about using IDS UTM together with the routers and finally ditch old HTTP proxy for basic filtering
f)****]HARDWARE IMPROVEMENTS
-improve USB chip dc converters on some routerboard like LSP5523 which they burn when there is overvoltage ratio
-put flash card on every router to get benefits of METAROUTER or DUDE package
-make every router dual core chip at least 800MHZ
-improve USB transfer rate 3.0 in every router
-BETTER WIFI UNITS SPEED and DUAL BAND technology
g)Graphing software and ANALITICS in the ROUTEROS
-think they can make separate software for this like controller so users can have better understanding what is going on with users on the network
-insted of using WEBFIG web site
-make some android and ios application
UBQUITY HAS this feature
MORE SEMINARS ABOUT
-LOAD BALANCING HARDWARE AND SOFTWARE PCC balancing
-VOIP and MIKROTIK QOS
-USING mikrotik with other devices
Here you can write free every other improvement and also write about EDGE router what is actually worse or better in terms of routing protocols
HERE are mine oppinions what Mikrotik is best
1)They have their own PUBLIC DYN DNS
2)They have power redundancy
3)The have good scripts and are good at failover routers much easier to create and configure versus UBIQUITY or PFSENSE
4)They can be access as bridge layer 2 or layer IP protocol
5)CAPS MAN and winbox from one location in parallel
6)CHEAP QUALITY BOARDS and very fast booting
7)MANUALS FOR REPAIRING the ROUTERS AND WIFI POINTS
Regards
