in hotspot binding of ip address with username is not work
i am using mikrotik 2.9.27 .
i have hotspot installed and also created user, and also asign ip address to user but i can login from any ip .
as example :-
i have creat user DEMO ;then asign it ip 10.1.1.2
but when i change my computer ip to 10.1.1.5 till demo is able to login .
can anybody tell me that why is that happen ?
simply in hotspot
binding of ip address with username is not work.
kindly try it on your router then reply
thanx
IP-address in ‘ip hotspot user’ does not bind the IP address to particular client.
‘IP-address’ is changed for this client, when user is connected to HotSpot (old client ip address is substituted with IP address configured in ‘ip hotspot user’).
thanx for reply but can you tell me any method that how to bind ip address with user.
so user can only connect with their own ip which has been provided by us.
here is a problem of ip-conflict my one user reinstall his system and then gave ip ! that was different from my provided ip . so at morning my other client have problem of ip-conflict .
Hi tambula
I don’t know how is your network looks like, or topology , I think you are using static ip address, why you are not using DHCP, for more secure you can attached MAC address to the user when you open account on HP.
Just a thought.
thx selim
There is no such option to bind the particular address for the client, the one way to force configuration of the address on the client.
DHCP can do it, but client can easily put static address.
PPPoE is the solution for this case, but it asks reconfiguration of all system.
