earlier using 5.0b9 this worked and after upgrading to 5.0 release I experience problems with respecting routing marks while choosing the gateway.
[admin@MikroTik] > ip firewall filter print
0 ;;; default configuration
chain=input action=accept protocol=icmp
1 ;;; default configuration
chain=input action=accept connection-state=related
in-interface=ether1-gateway
2 ;;; default configuration
chain=input action=accept connection-state=established
3 X ;;; default configuration
chain=input action=drop in-interface=ether1-gateway
4 chain=input action=accept connection-state=established
in-interface=pppoe-out1
5 chain=input action=accept connection-state=related in-interface=pppoe-out1
[admin@MikroTik] > ip firewall nat print
chain=srcnat action=masquerade out-interface=ether1-gateway
1 chain=srcnat action=masquerade out-interface=pppoe-out1
[admin@MikroTik] > ip firewall mangle print
0 chain=prerouting action=mark-routing new-routing-mark=smtp passthrough=no protocol=tcp
in-interface=ether2-local-master dst-port=25
1 chain=postrouting action=log routing-mark=smtp routing-table=main out-interface=pppoe-out1
log-prefix=""
2 chain=postrouting action=log routing-mark=smtp routing-table=main out-interface=ether1-gateway
log-prefix=""
[admin@MikroTik] > ip route print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 81.231.248.129 1
1 DS 0.0.0.0/0 146.172.65.24 1
2 ADC 81.231.248.128/25 81.231.248.177 ether1-gateway 0
3 ADC 146.172.65.24/32 84.218.23.142 pppoe-out1 0
4 ADC 192.168.10.0/24 192.168.10.1 ether2-local-ma... 0
[admin@MikroTik] > ip route rule print
Flags: X - disabled, I - inactive
0 routing-mark=smtp interface=pppoe-out1 action=lookup table=main
…and anyway the correctly marked package leaves the router on ether1-gateway and not on pppoe-out1.
Any help would be appreciated.
Thank you in advance.
Regards,
Z
