Inaccuracy in IPSec / Win10 documentation?
https://help.mikrotik.com/docs/spaces/ROS/pages/11993097/IPsec#IPsec-Windowsclientconfiguration
The following link states that for Windows 10:
  1. The only supported DH is modp1024 (group 2) which is not secure enough (i.e Cisco marks it as AVOID: https://sec.cloudapps.cisco.com/security/center/resources/next_generation_cryptography)
  2. Child SAs do not support AES-GCM (those are AEAD ciphers: they do not use hash, but require PRF). Instead, it suggests either AES-CBS with sha1 hmac (not so secure hash) or DES which is deprecated for a long time.
  3. Child SAs do not support PFS (which is quite important!)
However, all three claims are not true.
Windows supports all these things, but one has to do the following:
1.Enable modp2048 (aka Group 14) NegotiateDH2048_AES256, for example:
reg add HKLM\SYSTEM\CurrentControlSet\Services\RasMan\Parameters /t REG_DWORD /v NegotiateDH2048_AES256 /d 0x2 /f
  1. Configure VPN connection explicitly using Set-VpnConnectionIPsecConfiguration (there is no UI, sorry).
Here is my configuration:
Profile: hash, prf – sha256, enc aes256, dh modp2048.
Proposal: Auth: nothing (we do need them for AEAD). enc aes-256 gcm, pfs modp2048.
Set-VpnConnectionIPsecConfiguration -Name $ConnName -AuthenticationTransformConstants GCMAES256 -EncryptionMethod GCMAES256  -CipherTransformConstants GCMAES256  -IntegrityCheckMethod SHA256  -PfsGroup PFS2048 -DHGroup Group14 -force
So, I asked for: modp2048 PFS, DH 14 (which is also modp2048) and AES-256 CGM.
VOILÀ:
[foo@bar] /ip/ipsec/installed-sa> print proplist=enc-algorithm,enc-algorithm,enc-key-size,hw-aead
Flags: S - SEEN-TRAFFIC; H - HW-AEAD; E - ESP
Columns: ENC-ALGORITHM, ENC-ALGORITHM, ENC-KEY-SIZE, HW-AEAD
#     ENC-ALGORITHM  ENC-ALGORITHM  ENC-KEY-SIZE  HW-AEAD
0 SHE aes-gcm        aes-gcm                 288  yes
1 SHE aes-gcm        aes-gcm                 288  yes
2 SHE aes-gcm        aes-gcm                 288  yes
3 SHE aes-gcm        aes-gcm                 288  yes
(why does it show 288 key size? Seems like a bug: http://forum.mikrotik.com/t/ipsec-proposal-invalid-key-length-when-using-gcm/112976/1 , but Windows seems to accept it)
I enjoy hardware accelerated GCM AES.
And from the Windows side:
PS C:\> Get-NetIPsecMainModeSA | select -Property CipherAlgorithm, HashAlgorithm, GroupId, KeyModule
CipherAlgorithm HashAlgorithm GroupId KeyModule
         AES256        SHA256    DH14     IkeV2
PS C:\> Get-NetIPsecQuickModeSA | select -Property FirstIntegrityAlgorithm,FirstTransformType,FirstCipherAlgorithm
FirstIntegrityAlgorithm FirstTransformType FirstCipherAlgorithm
             AESGMAC256   EspAuthAndCipher            AESGCM256
For the Phase1 and I have DH14 (modp2048) and for the second phase it is AES-256-GCM.
AES-CBC 256 also works, and it supports SHA256 hmac:
Mikrotik:
4 SHE aes-cbc        aes-cbc                 256  yes
Windows:
Should we fix documentation to help people configure Windows clients in a more secure manner?
Just found this piece of well documented information, and tried it with Windows 11 (including the registry entry). Unfortunetely it does not work. I have still the problem, that if the VpnConnectionIPsecConfiguration is configured to AES-GCM, Windows don’t care and proposes AES-CBC to the Server.
I suspect, that it can be solved with a proper registry entry, but I can’t find anything about that. Any ideas?
