My RouterBOARD 3011UiAS
s.n. 689A05F53506
Lost ~1,5 seconds each 1 minute!!!
The time and date are always bad, also using SNTP or NTP client do not still syncronized,
i cant’ use any time-based service with this problem
Factory / Current Firmware 3.27
RouterOS 6.34.3
janisk
2
check on 6.35rc29 or newer.
also, search would have helped you.
Thanks for the reply but:
on all 10 results, all posts about time are mine…:
Search found 10 matches : 3011UiAS
Next time I search generic “3011” than the only 3011 model actually exist…
Thanks for works
