Incoming connection with two wan interfaces.
I have one main Internet breakout and have now added a second wan interface to Napa.
With this enabled, my incoming connections, Rdp, pptp etc, come in in my main breakout but leave on the napa connection.
I have enabled the following to try and force them out the connection they came in on, but it is not working. Can anyone help?
0 ;;; neo internet routing
chain=prerouting action=mark-connection new-connection-mark=neoint-conn
passthrough=yes in-interface=bridge1 neo internet log=no log-prefix=“”
1 ;;; napa routing
chain=prerouting action=mark-connection new-connection-mark=napa-conn
passthrough=yes in-interface=ether4 log=no log-prefix=“”
2 ;;; neoint in rote
chain=prerouting action=mark-routing new-routing-mark=neoint-route
passthrough=yes connection-mark=neoint-conn log=no log-prefix=“”
3 chain=prerouting action=mark-routing new-routing-mark=napa-route
passthrough=yes connection-mark=napa-conn log=no log-prefix=“”
4 ;;; Neoint - output
chain=output action=mark-routing new-routing-mark=neoint-route
5 chain=output action=mark-routing new-routing-mark=napa-route
If “bridge1 neo internet” and “ether4” are your two WAN interfaces, and you have corresponding routes with “neoint-route” and “napa-route” routing marks, and you don’t have other connection marking rules that could overwrite connection marks, then it should work.
Thank you Sob,
I have other mangle rules using Layer7 strings voice prioritization and pop3 traffic.
But these are on chain post routing. My full mange rules are listed below.
0 D chain=forward action=change-mss new-mss=1410 tcp-flags=syn protocol=tcp
out-interface=all-ppp tcp-mss=1411-65535
1 D chain=forward action=change-mss new-mss=1410 tcp-flags=syn protocol=tcp
in-interface=all-ppp tcp-mss=1411-65535
2 ;;; neo internet routing
3 ;;; napa routing
4 ;;; neoint in rote
5 chain=prerouting action=mark-routing new-routing-mark=napa-route
6 ;;; Neoint - output
7 chain=output action=mark-routing new-routing-mark=napa-route
8 chain=forward action=accept src-address=10.50.0.4 log=no log-prefix=“”
9 chain=forward action=accept src-address=10.50.0.5 log=no log-prefix=“”
10 ;;; POP3 Traffic
chain=prerouting action=mark-connection new-connection-mark=pop3-conn
passthrough=yes protocol=tcp dst-port=110 log=no log-prefix=“”
11 chain=prerouting action=mark-packet new-packet-mark=pop3-packet
passthrough=yes connection-mark=pop3-conn log=no log-prefix=“”
12 chain=prerouting action=mark-routing new-routing-mark=pop3-route
passthrough=yes protocol=tcp port=110 log=no log-prefix=“”
13 ;;; DSCP - 7 - Skype, HTTPS
chain=postrouting action=change-dscp new-dscp=7 passthrough=yes
protocol=tcp dst-port=443 log=no log-prefix=“”
14 ;;; DSCP - 7 - VOIP
protocol=udp port=1167,1719,1720,8010 log=no log-prefix=“”
15 ;;; DSCP - 7 - VOIP
protocol=tcp port=1719,1720,8008,8009 log=no log-prefix=“”
16 ;;; DSCP - 7 - SIP
protocol=tcp port=5060 log=no log-prefix=“”
17 ;;; DSCP - 7 - SIP
protocol=udp port=5060,5061 log=no log-prefix=“”
18 ;;; DSCP - 7 - IAX
protocol=udp port=4569 log=no log-prefix=“”
19 ;;; DSCP - 7 - SIP 5004
protocol=udp port=5004 log=no log-prefix=“”
20 ;;; Priority - 7 - Ventrilo VOIP
chain=postrouting action=change-dscp new-dscp=0 passthrough=yes
protocol=tcp port=3784 log=no log-prefix=“”
21 ;;; Priority - 7 - Ventrilo VOIP
protocol=udp port=3784,3785 log=no log-prefix=“”
22 ;;; Priority - 7 - Windows Live Messenger Voice
protocol=tcp port=6901 log=no log-prefix=“”
23 ;;; Priority - 7 - Windows Live Messenger Voice
protocol=udp port=6901 log=no log-prefix=“”
24 ;;; Section Break
chain=output action=accept log=no log-prefix=“”
25 ;;; Priority - 0 - VOIP - h323
chain=forward action=set-priority new-priority=7 passthrough=yes
layer7-protocol=h323 log=no log-prefix=“”
26 ;;; Priority - 0 - VOIP - SIP
layer7-protocol=sip log=no log-prefix=“”
27 ;;; Priority - 0 - VOIP - IAX
28 ;;; Priority - 0 - VOIP - Skypeout
layer7-protocol=skypeout log=no log-prefix=“”
29 ;;; Priority - 0 - VOIP - skypetoskype
layer7-protocol=skypetoskype log=no log-prefix=“”
30 ;;; Priority - 0 - VOIP - STUN
layer7-protocol=stun log=no log-prefix=“”
31 ;;; Priority - 0 - VOIP - Teamspeak
layer7-protocol=teamspeak log=no log-prefix=“”
32 chain=prerouting action=mark-routing new-routing-mark=electrocom
passthrough=yes src-address=10.5.0.0/16 src-address-list=!electrocom
Possibly conflicting rules are #10 and #12 (but they can affect only tcp/110 connections) and #32 (if the internal server is in 10.5.0.0/16). Other than this, I don’t see any problem. What about routes, is everything there correct?
I disabled those rules, just in-case, but when I enable both the routes with the routing mark, all internet traffic dies. With only the Neointernet out route enabled, Napa traffic is OK but the Neo internet outbound connections are affected. I have posted my default routes below, although the ones with routing tags are disabled as is my routing to Napa.
check-gateway=ping disabled=yes distance=1 gateway=41.162.6.1 routing-mark=neoint-route
check-gateway=ping disabled=yes distance=1 gateway=169.239.44.17 routing-mark=napa-route
Interesting. How does the rest of your routing table look (/ip route print detail)?
Here it is…
0 X S dst-address=0.0.0.0/0 gateway=41.162.6.1
gateway-status=41.162.6.1 inactive check-gateway=ping distance=1
scope=30 target-scope=10 routing-mark=neoint-route
1 X S dst-address=0.0.0.0/0 gateway=169.239.44.17
gateway-status=169.239.44.17 inactive check-gateway=ping distance=1
scope=30 target-scope=10 routing-mark=napa-route
2 A S dst-address=0.0.0.0/0 gateway=41.162.6.1
gateway-status=41.162.6.1 reachable via bridge1 neo internet
distance=1 scope=30 target-scope=10
3 ADo dst-address=1.1.1.0/24 gateway=10.250.21.1
gateway-status=10.250.21.1 reachable via ether8 distance=110 scope=20
target-scope=10 ospf-metric=29 ospf-type=external-type-1
4 ADo dst-address=2.2.2.2/32 gateway=10.250.21.1
5 A S dst-address=4.3.2.0/30 gateway=10.250.74.2
gateway-status=10.250.74.2 reachable via ether2 distance=1 scope=30
target-scope=10
6 X S dst-address=8.8.4.4/32 gateway=169.239.44.17
gateway-status=169.239.44.17 inactive distance=1 scope=30
target-scope=10
7 X S dst-address=8.8.8.8/32 gateway=169.239.44.17
target-scope=10
8 ADo dst-address=10.0.0.0/30 gateway=10.250.48.2
gateway-status=10.250.48.2 reachable via sfp1 distance=110 scope=20
target-scope=10 ospf-metric=50 ospf-type=external-type-1
9 ADo dst-address=10.0.6.0/24 gateway=10.250.21.1
10 ADo dst-address=10.0.250.0/24 gateway=10.252.2.2
gateway-status=10.252.2.2 reachable via ether5 distance=110 scope=20
target-scope=10 ospf-metric=30 ospf-type=external-type-1
11 A S dst-address=10.1.3.5/32 gateway=10.250.74.2
target-scope=10
12 ADC dst-address=10.2.1.0/30 pref-src=10.2.1.1 gateway=vlan1-electrocom
gateway-status=vlan1-electrocom reachable distance=0 scope=10
13 ADo dst-address=10.3.3.0/24 gateway=10.250.21.1
14 X S dst-address=10.5.0.0/16 gateway=10.250.74.2
gateway-status=10.250.74.2 inactive distance=1 scope=30 target-scope=10
15 A S dst-address=10.5.1.10/32 gateway=10.250.74.2
gateway-status=10.250.74.2 reachable via ether2 distance=111 scope=30
target-scope=10
16 A S dst-address=10.5.2.98/32 gateway=10.250.74.2
target-scope=10
17 A S dst-address=10.5.14.1/32 gateway=10.250.74.2
target-scope=10
18 A S dst-address=10.5.38.0/24 gateway=10.250.74.2
target-scope=10
19 A S dst-address=10.5.39.0/24 gateway=10.250.74.2
target-scope=10
20 X S dst-address=10.5.130.29/32 gateway=10.250.74.2
gateway-status=10.250.74.2 inactive distance=111 scope=30
target-scope=10
21 ADo dst-address=10.6.6.0/24 gateway=10.252.2.2
22 ADo dst-address=10.10.1.0/24 gateway=10.250.21.1
23 ADo dst-address=10.10.10.0/24 gateway=10.250.48.2
target-scope=10 ospf-metric=60 ospf-type=external-type-1
24 ADo dst-address=10.11.11.0/24 gateway=10.250.21.1
25 ADo dst-address=10.11.14.0/24 gateway=10.250.48.2
26 ADo dst-address=10.20.30.0/24 gateway=10.250.21.1
27 ADo dst-address=10.25.0.0/16 gateway=10.250.48.2
28 ADo dst-address=10.30.15.0/24 gateway=10.250.21.1
29 ADo dst-address=10.30.26.0/24 gateway=10.250.21.1
30 ADo dst-address=10.30.28.0/24 gateway=10.250.21.1
31 ADo dst-address=10.30.31.0/24 gateway=10.250.21.1
32 ADo dst-address=10.30.34.0/24 gateway=10.250.21.1
33 ADo dst-address=10.30.35.0/24 gateway=10.250.21.1
34 ADo dst-address=10.30.37.0/24 gateway=10.250.21.1
35 ADo dst-address=10.30.40.0/24 gateway=10.250.48.2
target-scope=10 ospf-metric=70 ospf-type=external-type-1
36 ADo dst-address=10.30.44.0/24 gateway=10.250.21.1
37 ADo dst-address=10.30.46.0/24 gateway=10.250.21.1
38 ADo dst-address=10.40.1.0/24 gateway=10.99.0.1
gateway-status=10.99.0.1 reachable via vlan3 distance=110 scope=20
39 ADo dst-address=10.40.1.247/32 gateway=10.99.0.1
target-scope=10 ospf-metric=40 ospf-type=external-type-1
40 ADo dst-address=10.44.1.104/29 gateway=10.99.0.1
41 A S dst-address=10.50.0.0/24 gateway=10.250.21.1
gateway-status=10.250.21.1 reachable via ether8 distance=1 scope=30
target-scope=10
42 ADo dst-address=10.50.1.0/24 gateway=10.250.21.1
43 ADo dst-address=10.50.2.0/24 gateway=10.250.21.1
44 ADo dst-address=10.50.4.0/24 gateway=10.250.21.1
45 ADo dst-address=10.50.6.0/24 gateway=10.250.21.1
46 ADo dst-address=10.50.8.0/24 gateway=10.250.21.1
47 ADo dst-address=10.50.10.0/24 gateway=10.250.21.1
48 ADo dst-address=10.50.11.0/24 gateway=10.250.21.1
49 A S dst-address=10.50.20.0/24 gateway=10.250.21.1
gateway-status=10.250.21.1 reachable via ether8 distance=111 scope=30
target-scope=10
50 ADo dst-address=10.50.50.0/24 gateway=10.250.21.1
51 ADo dst-address=10.51.0.0/24 gateway=10.250.21.1
52 ADo dst-address=10.70.0.0/24 gateway=10.99.0.1
53 ADo dst-address=10.71.0.0/24 gateway=10.250.21.1
54 ADo dst-address=10.84.0.0/24 gateway=10.252.2.2
55 ADo dst-address=10.85.2.0/24 gateway=10.98.0.2
gateway-status=10.98.0.2 reachable via vlan1492 NPP distance=110
scope=20 target-scope=10 ospf-metric=50 ospf-type=external-type-1
56 ADo dst-address=10.85.2.3/32 gateway=10.98.0.2
57 ADo dst-address=10.85.2.4/32 gateway=10.98.0.2
58 ADo dst-address=10.85.2.5/32 gateway=10.98.0.2
59 ADo dst-address=10.85.2.6/32 gateway=10.98.0.2
60 ADo dst-address=10.85.2.8/32 gateway=10.98.0.2
61 ADo dst-address=10.85.2.9/32 gateway=10.98.0.2
62 ADo dst-address=10.85.2.11/32 gateway=10.98.0.2
63 ADo dst-address=10.85.2.12/32 gateway=10.98.0.2
scope=20 target-scope=10 ospf-metric=45 ospf-type=external-type-1
64 ADo dst-address=10.85.2.13/32 gateway=10.98.0.2
65 ADo dst-address=10.85.2.14/32 gateway=10.98.0.2
66 ADo dst-address=10.85.2.15/32 gateway=10.98.0.2
67 ADo dst-address=10.85.2.16/32 gateway=10.98.0.2
68 ADo dst-address=10.85.2.18/32 gateway=10.98.0.2
69 ADo dst-address=10.85.2.20/32 gateway=10.98.0.2
70 ADo dst-address=10.85.2.21/32 gateway=10.98.0.2
71 ADo dst-address=10.85.2.22/32 gateway=10.98.0.2
72 ADo dst-address=10.85.2.26/32 gateway=10.98.0.2
73 ADo dst-address=10.85.2.29/32 gateway=10.98.0.2
74 ADo dst-address=10.85.2.30/32 gateway=10.98.0.2
75 ADo dst-address=10.85.2.31/32 gateway=10.98.0.2
76 ADo dst-address=10.85.2.32/32 gateway=10.98.0.2
77 ADo dst-address=10.85.2.33/32 gateway=10.98.0.2
78 ADo dst-address=10.85.2.34/32 gateway=10.98.0.2
79 ADo dst-address=10.85.2.35/32 gateway=10.98.0.2
80 ADo dst-address=10.85.2.36/32 gateway=10.98.0.2
81 ADo dst-address=10.85.2.222/32 gateway=10.98.0.2
82 ADo dst-address=10.85.3.0/24 gateway=10.98.0.2
83 ADo dst-address=10.85.3.2/32 gateway=10.98.0.2
84 ADo dst-address=10.85.3.4/32 gateway=10.98.0.2
85 ADo dst-address=10.85.3.5/32 gateway=10.98.0.2
86 ADo dst-address=10.85.3.6/32 gateway=10.98.0.2
87 ADo dst-address=10.85.3.7/32 gateway=10.98.0.2
88 ADo dst-address=10.85.3.12/32 gateway=10.98.0.2
89 ADo dst-address=10.85.3.13/32 gateway=10.98.0.2
90 ADo dst-address=10.85.3.14/32 gateway=10.98.0.2
91 ADo dst-address=10.85.3.15/32 gateway=10.98.0.2
92 ADo dst-address=10.85.3.33/32 gateway=10.98.0.2
93 ADo dst-address=10.85.3.34/32 gateway=10.98.0.2
94 ADo dst-address=10.85.3.35/32 gateway=10.98.0.2
95 ADo dst-address=10.85.3.37/32 gateway=10.98.0.2
96 ADo dst-address=10.85.3.38/32 gateway=10.98.0.2
97 ADo dst-address=10.85.3.39/32 gateway=10.98.0.2
98 ADo dst-address=10.85.3.40/32 gateway=10.98.0.2
99 ADo dst-address=10.85.3.41/32 gateway=10.98.0.2
100 ADo dst-address=10.85.3.42/32 gateway=10.98.0.2
101 ADo dst-address=10.85.3.43/32 gateway=10.98.0.2
102 ADo dst-address=10.85.3.101/32 gateway=10.98.0.2
103 ADo dst-address=10.85.3.200/32 gateway=10.98.0.2
104 ADo dst-address=10.85.4.0/24 gateway=10.98.0.2
105 ADo dst-address=10.85.4.224/32 gateway=10.98.0.2
106 ADo dst-address=10.85.5.0/24 gateway=10.98.0.2
107 ADo dst-address=10.85.6.0/24 gateway=10.98.0.2
108 ADo dst-address=10.85.8.0/24 gateway=10.98.0.2
scope=20 target-scope=10 ospf-metric=30 ospf-type=external-type-1
109 ADo dst-address=10.85.11.0/24 gateway=10.98.0.2
110 ADo dst-address=10.86.1.0/24 gateway=10.98.0.2
scope=20 target-scope=10 ospf-metric=40 ospf-type=external-type-1
111 ADo dst-address=10.86.2.0/24 gateway=10.98.0.2
112 ADo dst-address=10.86.254.0/24 gateway=10.98.0.2
scope=20 target-scope=10 ospf-metric=60 ospf-type=external-type-1
113 ADo dst-address=10.87.1.0/24 gateway=10.98.0.2
114 ADo dst-address=10.87.2.0/24 gateway=10.98.0.2
115 ADo dst-address=10.87.3.0/24 gateway=10.98.0.2
scope=20 target-scope=10 ospf-metric=70 ospf-type=external-type-1
116 ADo dst-address=10.87.3.3/32 gateway=10.98.0.2
117 ADo dst-address=10.87.3.4/32 gateway=10.98.0.2
118 ADo dst-address=10.87.3.5/32 gateway=10.98.0.2
119 ADo dst-address=10.87.4.0/24 gateway=10.98.0.2
120 ADo dst-address=10.87.4.3/32 gateway=10.98.0.2
121 ADo dst-address=10.87.4.4/32 gateway=10.98.0.2
122 ADo dst-address=10.87.5.0/24 gateway=10.98.0.2
123 ADo dst-address=10.87.5.2/32 gateway=10.98.0.2
124 ADo dst-address=10.87.5.4/32 gateway=10.98.0.2
125 ADo dst-address=10.87.6.0/24 gateway=10.98.0.2
126 ADo dst-address=10.87.7.0/24 gateway=10.98.0.2
127 ADo dst-address=10.87.8.0/24 gateway=10.98.0.2
128 ADo dst-address=10.87.8.2/32 gateway=10.98.0.2
129 ADo dst-address=10.87.9.0/24 gateway=10.98.0.2
130 ADo dst-address=10.87.9.2/32 gateway=10.98.0.2
131 ADo dst-address=10.87.9.3/32 gateway=10.98.0.2
132 ADo dst-address=10.87.10.0/24 gateway=10.98.0.2
133 ADo dst-address=10.87.12.0/24 gateway=10.98.0.2
134 ADo dst-address=10.87.12.5/32 gateway=10.98.0.2
135 ADo dst-address=10.87.12.6/32 gateway=10.98.0.2
136 ADo dst-address=10.87.12.7/32 gateway=10.98.0.2
137 ADo dst-address=10.87.12.8/32 gateway=10.98.0.2
138 ADo dst-address=10.87.12.9/32 gateway=10.98.0.2
139 ADo dst-address=10.87.12.11/32 gateway=10.98.0.2
140 ADo dst-address=10.87.13.0/24 gateway=10.98.0.2
141 ADo dst-address=10.87.15.0/24 gateway=10.98.0.2
142 ADo dst-address=10.87.18.0/24 gateway=10.98.0.2
143 ADo dst-address=10.87.19.0/24 gateway=10.98.0.2
scope=20 target-scope=10 ospf-metric=90 ospf-type=external-type-1
144 ADo dst-address=10.87.19.5/32 gateway=10.98.0.2
145 ADo dst-address=10.87.20.0/24 gateway=10.98.0.2
146 ADo dst-address=10.87.100.0/24 gateway=10.98.0.2
147 ADo dst-address=10.87.101.0/24 gateway=10.98.0.2
148 ADo dst-address=10.87.101.2/32 gateway=10.98.0.2
149 ADo dst-address=10.87.101.4/32 gateway=10.98.0.2
150 ADo dst-address=10.87.101.11/32 gateway=10.98.0.2
151 ADo dst-address=10.87.101.12/32 gateway=10.98.0.2
152 ADo dst-address=10.87.102.0/24 gateway=10.98.0.2
153 ADo dst-address=10.88.2.0/24 gateway=10.98.0.2
154 ADo dst-address=10.88.2.8/32 gateway=10.98.0.2
155 ADo dst-address=10.88.2.9/32 gateway=10.98.0.2
156 ADo dst-address=10.88.2.11/32 gateway=10.98.0.2
157 ADo dst-address=10.88.2.12/32 gateway=10.98.0.2
158 ADo dst-address=10.88.2.20/32 gateway=10.98.0.2
159 ADo dst-address=10.88.2.21/32 gateway=10.98.0.2
160 ADo dst-address=10.88.2.24/32 gateway=10.98.0.2
161 ADo dst-address=10.88.2.25/32 gateway=10.98.0.2
162 ADo dst-address=10.88.3.0/24 gateway=10.98.0.2
163 ADo dst-address=10.88.4.0/24 gateway=10.98.0.2
164 ADo dst-address=10.88.5.0/24 gateway=10.98.0.2
165 ADo dst-address=10.88.6.0/24 gateway=10.98.0.2
166 ADo dst-address=10.88.6.2/32 gateway=10.98.0.2
167 ADo dst-address=10.88.7.0/24 gateway=10.98.0.2
168 ADo dst-address=10.88.9.0/24 gateway=10.98.0.2
169 ADo dst-address=10.88.10.0/24 gateway=10.98.0.2
170 ADo dst-address=10.88.11.0/24 gateway=10.98.0.2
171 ADo dst-address=10.88.11.3/32 gateway=10.98.0.2
172 ADo dst-address=10.88.13.0/24 gateway=10.98.0.2
173 ADo dst-address=10.88.20.0/24 gateway=10.98.0.2
scope=20 target-scope=10 ospf-metric=25 ospf-type=external-type-1
174 ADo dst-address=10.88.21.0/24 gateway=10.98.0.2
175 ADo dst-address=10.88.21.3/32 gateway=10.98.0.2
176 ADo dst-address=10.88.21.11/32 gateway=10.98.0.2
177 ADo dst-address=10.88.21.15/32 gateway=10.98.0.2
178 ADo dst-address=10.88.22.0/24 gateway=10.98.0.2
179 ADo dst-address=10.88.25.1/32 gateway=10.98.0.2
180 ADo dst-address=10.89.0.0/16 gateway=10.98.0.2
181 ADo dst-address=10.89.1.0/24 gateway=10.98.0.2
182 ADo dst-address=10.89.2.0/24 gateway=10.98.0.2
183 ADo dst-address=10.89.2.2/32 gateway=10.98.0.2
184 ADo dst-address=10.89.3.0/24 gateway=10.98.0.2
185 ADo dst-address=10.89.3.2/32 gateway=10.98.0.2
186 ADo dst-address=10.89.3.3/32 gateway=10.98.0.2
187 ADo dst-address=10.89.4.0/24 gateway=10.98.0.2
188 ADo dst-address=10.89.5.0/24 gateway=10.98.0.2
189 ADo dst-address=10.89.6.0/24 gateway=10.98.0.2
190 ADo dst-address=10.90.1.0/24 gateway=10.98.0.2
191 ADo dst-address=10.90.2.2/32 gateway=10.98.0.2
192 ADo dst-address=10.90.2.3/32 gateway=10.98.0.2
193 ADo dst-address=10.90.2.4/32 gateway=10.98.0.2
194 ADo dst-address=10.90.2.8/32 gateway=10.98.0.2
195 ADo dst-address=10.90.3.0/24 gateway=10.98.0.2
196 ADo dst-address=10.90.4.3/32 gateway=10.98.0.2
197 ADo dst-address=10.90.4.200/32 gateway=10.98.0.2
198 ADo dst-address=10.90.6.0/24 gateway=10.98.0.2
199 ADo dst-address=10.91.1.0/24 gateway=10.98.0.2
200 ADo dst-address=10.91.2.0/24 gateway=10.98.0.2
scope=20 target-scope=10 ospf-metric=80 ospf-type=external-type-1
201 ADo dst-address=10.91.2.2/32 gateway=10.98.0.2
202 ADo dst-address=10.91.2.3/32 gateway=10.98.0.2
203 ADo dst-address=10.91.2.4/32 gateway=10.98.0.2
204 ADo dst-address=10.91.2.5/32 gateway=10.98.0.2
205 ADo dst-address=10.91.2.7/32 gateway=10.98.0.2
206 ADo dst-address=10.91.3.0/24 gateway=10.98.0.2
207 ADo dst-address=10.91.3.2/32 gateway=10.98.0.2
208 ADo dst-address=10.91.3.3/32 gateway=10.98.0.2
209 ADo dst-address=10.91.3.7/32 gateway=10.98.0.2
210 ADo dst-address=10.91.4.0/24 gateway=10.98.0.2
211 ADo dst-address=10.91.6.0/24 gateway=10.98.0.2
212 ADo dst-address=10.92.0.0/24 gateway=10.252.2.2
213 ADo dst-address=10.92.1.0/24 gateway=10.98.0.2
214 ADo dst-address=10.92.10.0/24 gateway=10.98.0.2
215 ADo dst-address=10.92.11.0/24 gateway=10.98.0.2
216 ADo dst-address=10.92.11.11/32 gateway=10.98.0.2
217 ADo dst-address=10.96.0.0/24 gateway=10.98.0.2
218 ADo dst-address=10.96.1.0/24 gateway=10.98.0.2
219 ADo dst-address=10.96.2.0/24 gateway=10.98.0.2
220 ADo dst-address=10.96.3.0/24 gateway=10.98.0.2
221 ADo dst-address=10.96.3.3/32 gateway=10.98.0.2
222 ADo dst-address=10.96.4.0/24 gateway=10.98.0.2
223 ADo dst-address=10.97.1.0/24 gateway=10.98.0.2
224 ADo dst-address=10.97.2.0/24 gateway=10.98.0.2
225 ADo dst-address=10.97.2.4/32 gateway=10.98.0.2
226 ADo dst-address=10.97.2.5/32 gateway=10.98.0.2
227 ADo dst-address=10.97.2.6/32 gateway=10.98.0.2
228 ADo dst-address=10.97.2.7/32 gateway=10.98.0.2
229 ADo dst-address=10.97.2.9/32 gateway=10.98.0.2
230 ADo dst-address=10.97.2.11/32 gateway=10.98.0.2
231 ADo dst-address=10.97.2.12/32 gateway=10.98.0.2
232 ADo dst-address=10.97.2.13/32 gateway=10.98.0.2
233 ADo dst-address=10.97.2.14/32 gateway=10.98.0.2
234 ADo dst-address=10.97.2.15/32 gateway=10.98.0.2
235 ADo dst-address=10.97.2.16/32 gateway=10.98.0.2
236 ADo dst-address=10.97.2.18/32 gateway=10.98.0.2
237 ADo dst-address=10.97.2.19/32 gateway=10.98.0.2
238 ADo dst-address=10.97.2.20/32 gateway=10.98.0.2
239 ADo dst-address=10.97.2.23/32 gateway=10.98.0.2
240 ADo dst-address=10.97.2.24/32 gateway=10.98.0.2
241 ADo dst-address=10.97.2.27/32 gateway=10.98.0.2
242 ADo dst-address=10.97.2.28/32 gateway=10.98.0.2
243 ADo dst-address=10.97.2.29/32 gateway=10.98.0.2
244 ADo dst-address=10.97.2.30/32 gateway=10.98.0.2
245 ADo dst-address=10.97.2.31/32 gateway=10.98.0.2
246 ADo dst-address=10.97.2.32/32 gateway=10.98.0.2
247 ADo dst-address=10.97.2.33/32 gateway=10.98.0.2
248 ADo dst-address=10.97.2.34/32 gateway=10.98.0.2
249 ADo dst-address=10.97.2.35/32 gateway=10.98.0.2
250 ADo dst-address=10.97.2.36/32 gateway=10.98.0.2
251 ADo dst-address=10.97.2.37/32 gateway=10.98.0.2
252 ADo dst-address=10.97.2.38/32 gateway=10.98.0.2
253 ADo dst-address=10.97.2.39/32 gateway=10.98.0.2
254 ADo dst-address=10.97.2.40/32 gateway=10.98.0.2
255 ADo dst-address=10.97.2.41/32 gateway=10.98.0.2
256 ADo dst-address=10.97.2.42/32 gateway=10.98.0.2
257 ADo dst-address=10.97.2.43/32 gateway=10.98.0.2
258 ADo dst-address=10.97.3.0/24 gateway=10.98.0.2
259 ADo dst-address=10.97.3.2/32 gateway=10.98.0.2
260 ADo dst-address=10.97.3.3/32 gateway=10.98.0.2
261 ADo dst-address=10.97.3.31/32 gateway=10.98.0.2
262 ADo dst-address=10.97.4.0/24 gateway=10.98.0.2
263 ADo dst-address=10.97.4.7/32 gateway=10.98.0.2
264 ADo dst-address=10.97.4.8/32 gateway=10.98.0.2
265 ADo dst-address=10.97.5.0/24 gateway=10.98.0.2
266 ADo dst-address=10.97.6.0/24 gateway=10.98.0.2
267 ADo dst-address=10.97.6.2/32 gateway=10.98.0.2
268 ADo dst-address=10.97.6.3/32 gateway=10.98.0.2
269 ADo dst-address=10.97.6.8/32 gateway=10.98.0.2
270 ADo dst-address=10.97.6.9/32 gateway=10.98.0.2
271 ADo dst-address=10.97.6.10/32 gateway=10.98.0.2
272 ADo dst-address=10.97.6.11/32 gateway=10.98.0.2
273 ADo dst-address=10.97.6.13/32 gateway=10.98.0.2
274 ADo dst-address=10.97.6.14/32 gateway=10.98.0.2
275 ADo dst-address=10.97.6.15/32 gateway=10.98.0.2
276 ADo dst-address=10.97.6.200/32 gateway=10.98.0.2
277 ADo dst-address=10.97.7.0/24 gateway=10.98.0.2
278 ADo dst-address=10.97.11.0/24 gateway=10.98.0.2
279 ADo dst-address=10.97.20.0/24 gateway=10.98.0.2
280 ADC dst-address=10.98.0.0/24 pref-src=10.98.0.1 gateway=vlan1492 NPP
gateway-status=vlan1492 NPP reachable distance=0 scope=10
281 ADo dst-address=10.98.1.0/24 gateway=10.98.0.2
282 ADo dst-address=10.98.2.0/24 gateway=10.98.0.2
283 ADo dst-address=10.98.3.0/24 gateway=10.98.0.2
284 ADo dst-address=10.98.8.0/24 gateway=10.98.0.2
285 ADo dst-address=10.98.100.0/24 gateway=10.98.0.2
286 X S dst-address=10.99.0.0/16 gateway=10.252.2.2
gateway-status=10.252.2.2 inactive distance=1 scope=30 target-scope=10
287 ADC dst-address=10.99.0.0/24 pref-src=10.99.0.2 gateway=vlan3
gateway-status=vlan3 reachable distance=0 scope=10
288 ADo dst-address=10.99.1.0/24 gateway=10.99.0.1
289 ADo dst-address=10.99.5.0/24 gateway=10.99.0.1
290 ADo dst-address=10.99.6.0/24 gateway=10.99.0.1
291 ADo dst-address=10.99.8.0/24 gateway=10.99.0.1
292 ADo dst-address=10.99.8.2/32 gateway=10.99.0.1
293 ADo dst-address=10.99.8.3/32 gateway=10.99.0.1
294 ADo dst-address=10.99.12.0/24 gateway=10.99.0.1
295 ADo dst-address=10.99.13.0/24 gateway=10.99.0.1
296 ADo dst-address=10.99.15.0/24 gateway=10.99.0.1
297 ADo dst-address=10.99.17.0/24 gateway=10.99.0.1
298 ADo dst-address=10.99.18.0/24 gateway=10.99.0.1
299 ADo dst-address=10.99.18.3/32 gateway=10.99.0.1
300 ADo dst-address=10.99.19.0/29 gateway=10.99.0.1
301 ADo dst-address=10.99.21.0/24 gateway=10.99.0.1
302 ADo dst-address=10.99.22.0/24 gateway=10.99.0.1
303 ADo dst-address=10.99.22.11/32 gateway=10.99.0.1
304 ADo dst-address=10.99.23.0/24 gateway=10.99.0.1
305 ADo dst-address=10.99.24.0/24 gateway=10.99.0.1
306 ADo dst-address=10.99.26.0/24 gateway=10.99.0.1
307 ADo dst-address=10.99.27.0/24 gateway=10.99.0.1
308 ADo dst-address=10.99.28.0/24 gateway=10.99.0.1
309 ADo dst-address=10.99.32.0/24 gateway=10.99.0.1
310 ADo dst-address=10.99.34.0/24 gateway=10.99.0.1
311 ADo dst-address=10.99.34.15/32 gateway=10.99.0.1
312 ADo dst-address=10.99.34.24/32 gateway=10.99.0.1
313 ADo dst-address=10.99.35.0/24 gateway=10.99.0.1
314 ADo dst-address=10.99.35.2/32 gateway=10.250.48.2
315 ADo dst-address=10.99.37.0/24 gateway=10.99.0.1
316 ADo dst-address=10.99.40.0/24 gateway=10.99.0.1
317 X S dst-address=10.99.40.0/24 gateway=10.99.0.1
gateway-status=10.99.0.1 inactive distance=111 scope=30 target-scope=10
318 ADo dst-address=10.99.41.0/24 gateway=10.99.0.1
319 ADo dst-address=10.99.42.0/24 gateway=10.99.0.1
320 ADo dst-address=10.99.43.0/24 gateway=10.99.0.1
321 ADo dst-address=10.99.50.0/24 gateway=10.99.0.1
322 ADo dst-address=10.99.52.0/24 gateway=10.99.0.1
323 ADo dst-address=10.99.55.0/24 gateway=10.99.0.1
324 ADo dst-address=10.99.56.0/24 gateway=10.99.0.1
325 ADo dst-address=10.99.57.0/24 gateway=10.99.0.1
326 ADo dst-address=10.100.0.0/22 gateway=10.99.0.1
327 ADo dst-address=10.100.10.12/32 gateway=10.99.0.1
328 ADo dst-address=10.100.17.0/24 gateway=10.99.0.1
329 ADo dst-address=10.100.18.0/24 gateway=10.99.0.1
330 ADo dst-address=10.100.19.0/24 gateway=10.99.0.1
331 ADo dst-address=10.100.21.0/24 gateway=10.99.0.1
332 ADo dst-address=10.100.21.3/32 gateway=10.99.0.1
333 ADo dst-address=10.100.21.5/32 gateway=10.99.0.1
334 ADo dst-address=10.100.22.0/24 gateway=10.99.0.1
335 ADo dst-address=10.100.22.8/32 gateway=10.99.0.1
336 ADo dst-address=10.100.23.0/24 gateway=10.99.0.1
337 ADo dst-address=10.100.24.0/24 gateway=10.99.0.1
target-scope=10 ospf-metric=230 ospf-type=external-type-1
338 ADo dst-address=10.100.24.2/32 gateway=10.99.0.1
339 ADo dst-address=10.100.25.0/24 gateway=10.99.0.1
340 ADo dst-address=10.100.26.0/24 gateway=10.99.0.1
341 ADo dst-address=10.100.27.0/24 gateway=10.99.0.1
342 ADo dst-address=10.100.30.3/32 gateway=10.99.0.1
343 ADo dst-address=10.100.30.4/32 gateway=10.99.0.1
344 ADo dst-address=10.100.30.8/32 gateway=10.99.0.1
345 ADo dst-address=10.100.30.10/32 gateway=10.99.0.1
346 ADo dst-address=10.100.30.12/32 gateway=10.99.0.1
347 ADo dst-address=10.100.32.0/24 gateway=10.99.0.1
348 ADo dst-address=10.100.52.0/24 gateway=10.99.0.1
349 ADo dst-address=10.100.52.3/32 gateway=10.99.0.1
350 ADo dst-address=10.100.52.4/32 gateway=10.99.0.1
351 ADo dst-address=10.100.52.5/32 gateway=10.99.0.1
352 ADo dst-address=10.100.53.0/24 gateway=10.99.0.1
353 ADo dst-address=10.100.55.0/24 gateway=10.99.0.1
354 ADo dst-address=10.100.60.0/24 gateway=10.99.0.1
355 ADo dst-address=10.100.60.2/32 gateway=10.99.0.1
356 ADo dst-address=10.100.60.3/32 gateway=10.99.0.1
357 ADo dst-address=10.100.60.4/32 gateway=10.99.0.1
358 ADo dst-address=10.100.60.15/32 gateway=10.99.0.1
359 ADo dst-address=10.100.120.0/24 gateway=10.99.0.1
360 ADo dst-address=10.100.130.0/24 gateway=10.99.0.1
361 ADo dst-address=10.100.220.0/24 gateway=10.99.0.1
362 ADo dst-address=10.101.1.0/24 gateway=10.99.0.1
363 ADo dst-address=10.101.2.0/24 gateway=10.99.0.1
364 ADo dst-address=10.101.6.0/24 gateway=10.99.0.1
365 ADo dst-address=10.101.7.0/24 gateway=10.99.0.1
366 ADo dst-address=10.101.8.0/24 gateway=10.99.0.1
367 ADo dst-address=10.101.9.0/24 gateway=10.99.0.1
368 ADo dst-address=10.101.12.0/24 gateway=10.99.0.1
target-scope=10 ospf-metric=520 ospf-type=external-type-1
369 ADo dst-address=10.101.12.3/32 gateway=10.99.0.1
target-scope=10 ospf-metric=540 ospf-type=external-type-1
370 ADo dst-address=10.101.13.6/32 gateway=10.99.0.1
target-scope=10 ospf-metric=550 ospf-type=external-type-1
371 ADo dst-address=10.101.13.10/32 gateway=10.99.0.1
372 ADo dst-address=10.101.13.14/32 gateway=10.99.0.1
373 ADo dst-address=10.101.13.15/32 gateway=10.99.0.1
374 ADo dst-address=10.101.14.6/32 gateway=10.99.0.1
375 ADo dst-address=10.101.14.11/32 gateway=10.99.0.1
376 ADo dst-address=10.101.16.15/32 gateway=10.99.0.1
377 ADo dst-address=10.101.22.0/24 gateway=10.99.0.1
378 ADo dst-address=10.101.23.0/24 gateway=10.99.0.1
379 ADo dst-address=10.101.25.0/24 gateway=10.99.0.1
380 ADo dst-address=10.101.25.5/32 gateway=10.99.0.1
381 ADo dst-address=10.101.27.0/24 gateway=10.99.0.1
382 ADo dst-address=10.101.32.0/24 gateway=10.99.0.1
383 ADo dst-address=10.101.32.3/32 gateway=10.99.0.1
384 ADo dst-address=10.101.35.0/24 gateway=10.99.0.1
385 ADo dst-address=10.101.41.0/24 gateway=10.99.0.1
386 ADo dst-address=10.101.44.0/24 gateway=10.99.0.1
387 ADo dst-address=10.101.44.3/32 gateway=10.99.0.1
388 ADo dst-address=10.101.44.6/32 gateway=10.99.0.1
389 ADo dst-address=10.101.46.0/24 gateway=10.99.0.1
390 ADo dst-address=10.101.47.0/24 gateway=10.99.0.1
391 ADo dst-address=10.101.49.0/24 gateway=10.99.0.1
392 ADo dst-address=10.101.51.0/24 gateway=10.99.0.1
393 ADo dst-address=10.101.51.6/32 gateway=10.99.0.1
394 ADo dst-address=10.101.52.3/32 gateway=10.99.0.1
395 ADo dst-address=10.101.52.6/32 gateway=10.99.0.1
396 ADo dst-address=10.101.52.7/32 gateway=10.99.0.1
397 ADo dst-address=10.101.52.11/32 gateway=10.99.0.1
398 ADo dst-address=10.101.52.14/32 gateway=10.99.0.1
399 ADo dst-address=10.101.52.16/32 gateway=10.99.0.1
400 ADo dst-address=10.101.52.19/32 gateway=10.99.0.1
401 ADo dst-address=10.101.52.20/32 gateway=10.99.0.1
402 ADo dst-address=10.101.52.21/32 gateway=10.99.0.1
403 ADo dst-address=10.101.54.0/24 gateway=10.99.0.1
404 ADo dst-address=10.101.55.0/24 gateway=10.99.0.1
405 ADo dst-address=10.101.55.2/32 gateway=10.99.0.1
406 ADo dst-address=10.101.55.3/32 gateway=10.99.0.1
407 ADo dst-address=10.101.56.0/24 gateway=10.99.0.1
408 ADo dst-address=10.101.57.0/24 gateway=10.99.0.1
409 ADo dst-address=10.101.58.0/24 gateway=10.99.0.1
410 ADo dst-address=10.101.59.0/24 gateway=10.99.0.1
target-scope=10 ospf-metric=530 ospf-type=external-type-1
411 ADo dst-address=10.101.62.0/24 gateway=10.99.0.1
412 ADo dst-address=10.101.63.0/24 gateway=10.99.0.1
413 ADo dst-address=10.101.64.0/24 gateway=10.99.0.1
414 ADo dst-address=10.101.64.3/32 gateway=10.99.0.1
415 ADo dst-address=10.101.65.0/24 gateway=10.99.0.1
416 ADo dst-address=10.101.67.0/24 gateway=10.99.0.1
417 ADo dst-address=10.101.68.0/24 gateway=10.99.0.1
418 ADo dst-address=10.101.69.0/24 gateway=10.99.0.1
419 ADo dst-address=10.101.72.0/24 gateway=10.99.0.1
420 ADo dst-address=10.101.73.0/24 gateway=10.99.0.1
421 ADo dst-address=10.101.74.0/24 gateway=10.99.0.1
422 ADo dst-address=10.101.75.0/24 gateway=10.99.0.1
423 ADo dst-address=10.101.76.0/24 gateway=10.99.0.1
424 ADo dst-address=10.101.78.0/24 gateway=10.99.0.1
425 ADo dst-address=10.101.79.0/24 gateway=10.99.0.1
426 ADo dst-address=10.101.81.0/24 gateway=10.99.0.1
427 ADo dst-address=10.101.82.0/24 gateway=10.99.0.1
428 ADo dst-address=10.101.82.34/32 gateway=10.99.0.1
429 ADo dst-address=10.101.82.35/32 gateway=10.99.0.1
430 ADo dst-address=10.101.82.38/32 gateway=10.99.0.1
431 ADo dst-address=10.101.83.0/24 gateway=10.99.0.1
432 ADo dst-address=10.101.84.0/24 gateway=10.99.0.1
433 ADo dst-address=10.101.85.0/24 gateway=10.99.0.1
434 ADo dst-address=10.101.86.0/24 gateway=10.99.0.1
435 ADo dst-address=10.101.86.3/32 gateway=10.99.0.1
436 ADo dst-address=10.101.87.1/32 gateway=10.99.0.1
437 ADo dst-address=10.101.88.1/32 gateway=10.99.0.1
438 ADo dst-address=10.101.89.0/24 gateway=10.99.0.1
439 ADo dst-address=10.101.90.0/24 gateway=10.99.0.1
440 ADo dst-address=10.101.90.2/32 gateway=10.99.0.1
441 ADo dst-address=10.101.90.3/32 gateway=10.99.0.1
442 ADo dst-address=10.101.90.4/32 gateway=10.99.0.1
443 ADo dst-address=10.101.90.5/32 gateway=10.99.0.1
444 ADo dst-address=10.101.91.0/24 gateway=10.99.0.1
445 ADo dst-address=10.101.92.1/32 gateway=10.99.0.1
446 ADo dst-address=10.101.93.0/24 gateway=10.99.0.1
target-scope=10 ospf-metric=31 ospf-type=external-type-1
447 ADo dst-address=10.101.94.0/24 gateway=10.99.0.1
448 ADo dst-address=10.101.95.0/24 gateway=10.99.0.1
449 ADo dst-address=10.101.96.0/24 gateway=10.99.0.1
450 ADo dst-address=10.101.97.0/24 gateway=10.99.0.1
451 ADo dst-address=10.101.98.0/24 gateway=10.99.0.1
452 ADo dst-address=10.101.98.3/32 gateway=10.99.0.1
453 ADo dst-address=10.101.98.4/32 gateway=10.99.0.1
454 ADo dst-address=10.101.98.5/32 gateway=10.99.0.1
455 ADo dst-address=10.101.99.0/24 gateway=10.99.0.1
456 ADo dst-address=10.101.100.0/24 gateway=10.99.0.1
457 ADo dst-address=10.101.100.3/32 gateway=10.99.0.1
458 ADo dst-address=10.101.100.5/32 gateway=10.99.0.1
459 ADo dst-address=10.101.100.6/32 gateway=10.99.0.1
460 ADo dst-address=10.101.101.0/24 gateway=10.99.0.1
461 ADo dst-address=10.101.102.0/24 gateway=10.99.0.1
462 ADo dst-address=10.101.103.0/24 gateway=10.99.0.1
463 ADo dst-address=10.101.104.0/24 gateway=10.99.0.1
464 ADo dst-address=10.101.104.3/32 gateway=10.99.0.1
465 ADo dst-address=10.101.104.4/32 gateway=10.99.0.1
466 ADo dst-address=10.101.105.0/24 gateway=10.99.0.1
467 ADo dst-address=10.101.106.0/24 gateway=10.99.0.1
468 ADo dst-address=10.101.107.0/24 gateway=10.99.0.1
469 ADo dst-address=10.101.108.0/24 gateway=10.99.0.1
470 ADo dst-address=10.101.110.0/24 gateway=10.99.0.1
471 ADo dst-address=10.101.111.0/24 gateway=10.99.0.1
472 ADo dst-address=10.101.112.0/24 gateway=10.99.0.1
473 ADo dst-address=10.101.113.0/24 gateway=10.99.0.1
474 ADo dst-address=10.101.114.0/24 gateway=10.99.0.1
475 ADo dst-address=10.101.115.0/24 gateway=10.99.0.1
476 ADo dst-address=10.101.116.0/24 gateway=10.99.0.1
477 ADo dst-address=10.101.117.0/24 gateway=10.99.0.1
478 ADo dst-address=10.101.118.0/24 gateway=10.99.0.1
479 ADo dst-address=10.101.118.5/32 gateway=10.99.0.1
480 ADo dst-address=10.101.119.0/24 gateway=10.99.0.1
481 ADo dst-address=10.101.120.0/24 gateway=10.99.0.1
482 ADo dst-address=10.101.121.0/24 gateway=10.99.0.1
483 ADo dst-address=10.101.251.0/24 gateway=10.99.0.1
484 ADo dst-address=10.103.1.0/24 gateway=10.99.0.1
485 ADo dst-address=10.103.1.5/32 gateway=10.99.0.1
486 ADo dst-address=10.103.1.7/32 gateway=10.99.0.1
487 ADo dst-address=10.103.1.8/32 gateway=10.99.0.1
488 ADo dst-address=10.103.2.0/24 gateway=10.99.0.1
489 ADo dst-address=10.104.1.0/24 gateway=10.99.0.1
490 ADo dst-address=10.104.1.2/32 gateway=10.99.0.1
491 ADo dst-address=10.104.1.3/32 gateway=10.99.0.1
492 ADo dst-address=10.104.1.4/32 gateway=10.99.0.1
493 ADo dst-address=10.104.1.5/32 gateway=10.99.0.1
494 ADo dst-address=10.104.1.9/32 gateway=10.99.0.1
495 ADo dst-address=10.104.1.13/32 gateway=10.99.0.1
496 ADo dst-address=10.104.2.0/24 gateway=10.99.0.1
497 ADo dst-address=10.104.2.29/32 gateway=10.99.0.1
498 ADo dst-address=10.104.3.0/24 gateway=10.99.0.1
499 ADo dst-address=10.104.3.5/32 gateway=10.99.0.1
500 ADo dst-address=10.104.3.6/32 gateway=10.99.0.1
501 ADo dst-address=10.104.3.8/32 gateway=10.99.0.1
502 ADo dst-address=10.104.3.9/32 gateway=10.99.0.1
503 ADo dst-address=10.104.4.0/24 gateway=10.99.0.1
504 ADo dst-address=10.104.4.2/32 gateway=10.99.0.1
505 ADo dst-address=10.104.6.0/24 gateway=10.99.0.1
506 ADo dst-address=10.104.7.0/24 gateway=10.99.0.1
507 ADo dst-address=10.104.7.6/32 gateway=10.99.0.1
508 ADo dst-address=10.104.7.10/32 gateway=10.99.0.1
509 ADo dst-address=10.104.7.18/32 gateway=10.99.0.1
510 ADo dst-address=10.104.7.19/32 gateway=10.99.0.1
511 ADo dst-address=10.104.7.21/32 gateway=10.99.0.1
512 ADo dst-address=10.104.7.29/32 gateway=10.99.0.1
513 ADo dst-address=10.104.7.34/32 gateway=10.99.0.1
514 ADo dst-address=10.104.7.37/32 gateway=10.99.0.1
515 ADo dst-address=10.104.7.40/32 gateway=10.99.0.1
516 ADo dst-address=10.104.7.47/32 gateway=10.99.0.1
517 ADo dst-address=10.104.7.53/32 gateway=10.99.0.1
518 ADo dst-address=10.104.7.54/32 gateway=10.99.0.1
519 ADo dst-address=10.104.8.0/24 gateway=10.99.0.1
520 ADo dst-address=10.104.9.0/24 gateway=10.99.0.1
521 ADo dst-address=10.104.9.6/32 gateway=10.99.0.1
522 ADo dst-address=10.104.10.0/24 gateway=10.99.0.1
523 ADo dst-address=10.104.13.0/24 gateway=10.99.0.1
524 ADo dst-address=10.104.14.1/32 gateway=10.99.0.1
525 ADo dst-address=10.105.0.0/16 gateway=10.99.0.1
526 ADo dst-address=10.111.10.0/24 gateway=10.99.0.1
527 ADo dst-address=10.111.10.2/32 gateway=10.99.0.1
528 ADo dst-address=10.111.11.0/24 gateway=10.99.0.1
529 ADo dst-address=10.111.12.0/24 gateway=10.99.0.1
530 ADo dst-address=10.111.19.0/24 gateway=10.99.0.1
531 ADo dst-address=10.111.20.0/24 gateway=10.99.0.1
532 ADo dst-address=10.111.20.3/32 gateway=10.99.0.1
533 ADo dst-address=10.111.20.5/32 gateway=10.99.0.1
534 ADo dst-address=10.111.22.0/24 gateway=10.99.0.1
535 ADo dst-address=10.111.51.3/32 gateway=10.99.0.1
536 ADo dst-address=10.111.51.4/32 gateway=10.99.0.1
537 ADo dst-address=10.111.56.2/32 gateway=10.99.0.1
538 ADo dst-address=10.111.60.0/24 gateway=10.99.0.1
539 ADo dst-address=10.111.60.5/32 gateway=10.99.0.1
540 ADo dst-address=10.111.60.8/32 gateway=10.99.0.1
541 ADo dst-address=10.111.62.0/24 gateway=10.99.0.1
542 ADo dst-address=10.111.63.0/24 gateway=10.99.0.1
543 ADo dst-address=10.111.124.0/24 gateway=10.99.0.1
544 ADo dst-address=10.116.0.0/24 gateway=10.99.0.1
545 ADo dst-address=10.116.2.3/32 gateway=10.99.0.1
546 ADo dst-address=10.116.2.12/32 gateway=10.99.0.1
547 ADo dst-address=10.116.2.14/32 gateway=10.99.0.1
548 ADo dst-address=10.116.2.15/32 gateway=10.99.0.1
549 ADo dst-address=10.116.2.19/32 gateway=10.99.0.1
550 ADo dst-address=10.116.2.20/32 gateway=10.99.0.1
551 ADo dst-address=10.116.3.0/24 gateway=10.99.0.1
552 ADo dst-address=10.116.3.10/32 gateway=10.99.0.1
553 ADo dst-address=10.116.3.11/32 gateway=10.99.0.1
554 ADo dst-address=10.116.3.12/32 gateway=10.99.0.1
555 ADo dst-address=10.116.3.13/32 gateway=10.99.0.1
556 ADo dst-address=10.116.3.14/32 gateway=10.99.0.1
557 ADo dst-address=10.116.5.0/24 gateway=10.99.0.1
558 ADo dst-address=10.116.6.0/24 gateway=10.99.0.1
559 ADo dst-address=10.116.7.0/24 gateway=10.99.0.1
560 ADo dst-address=10.116.7.3/32 gateway=10.99.0.1
561 ADo dst-address=10.116.8.0/24 gateway=10.99.0.1
562 ADo dst-address=10.116.8.11/32 gateway=10.99.0.1
563 ADo dst-address=10.116.10.0/24 gateway=10.99.0.1
564 ADo dst-address=10.116.12.0/24 gateway=10.99.0.1
565 ADo dst-address=10.116.13.0/24 gateway=10.99.0.1
566 ADo dst-address=10.116.14.0/24 gateway=10.99.0.1
567 ADo dst-address=10.116.15.0/24 gateway=10.99.0.1
568 ADo dst-address=10.116.16.0/24 gateway=10.99.0.1
569 ADo dst-address=10.116.17.0/24 gateway=10.99.0.1
570 ADo dst-address=10.116.17.2/32 gateway=10.99.0.1
571 ADo dst-address=10.116.17.3/32 gateway=10.99.0.1
572 ADo dst-address=10.116.17.4/32 gateway=10.99.0.1
573 ADo dst-address=10.116.17.5/32 gateway=10.99.0.1
574 ADo dst-address=10.116.17.6/32 gateway=10.99.0.1
575 ADo dst-address=10.116.17.9/32 gateway=10.99.0.1
576 ADo dst-address=10.116.17.10/32 gateway=10.99.0.1
577 ADo dst-address=10.116.17.11/32 gateway=10.99.0.1
578 ADo dst-address=10.116.17.22/32 gateway=10.99.0.1
579 ADo dst-address=10.116.17.25/32 gateway=10.99.0.1
580 ADo dst-address=10.116.17.26/32 gateway=10.99.0.1
581 ADo dst-address=10.116.17.28/32 gateway=10.99.0.1
582 ADo dst-address=10.116.18.0/24 gateway=10.99.0.1
583 ADo dst-address=10.116.19.0/24 gateway=10.99.0.1
584 ADo dst-address=10.116.20.0/24 gateway=10.99.0.1
585 ADo dst-address=10.116.21.0/24 gateway=10.99.0.1
586 ADo dst-address=10.116.21.2/32 gateway=10.99.0.1
587 ADo dst-address=10.116.21.7/32 gateway=10.99.0.1
588 ADo dst-address=10.116.21.9/32 gateway=10.99.0.1
589 ADo dst-address=10.116.21.11/32 gateway=10.99.0.1
590 ADo dst-address=10.116.22.0/24 gateway=10.99.0.1
591 ADo dst-address=10.116.30.0/24 gateway=10.99.0.1
592 ADo dst-address=10.117.1.0/24 gateway=10.99.0.1
593 ADo dst-address=10.117.1.8/32 gateway=10.99.0.1
594 ADo dst-address=10.117.1.12/32 gateway=10.99.0.1
595 ADo dst-address=10.117.1.18/32 gateway=10.99.0.1
596 ADo dst-address=10.117.1.23/32 gateway=10.99.0.1
597 ADo dst-address=10.117.1.25/32 gateway=10.99.0.1
598 ADo dst-address=10.117.1.26/32 gateway=10.99.0.1
599 ADo dst-address=10.117.2.0/24 gateway=10.99.0.1
600 ADo dst-address=10.117.3.0/24 gateway=10.99.0.1
601 ADo dst-address=10.117.4.0/24 gateway=10.99.0.1
602 ADo dst-address=10.117.4.4/32 gateway=10.99.0.1
603 ADo dst-address=10.117.5.0/24 gateway=10.99.0.1
604 ADo dst-address=10.117.7.0/24 gateway=10.99.0.1
605 ADo dst-address=10.119.5.1/32 gateway=10.99.0.1
606 ADo dst-address=10.120.1.0/24 gateway=10.99.0.1
607 Do dst-address=10.120.1.0/24 gateway=10.250.48.2
608 ADo dst-address=10.120.1.2/32 gateway=10.99.0.1
609 ADo dst-address=10.120.3.0/24 gateway=10.250.48.2
target-scope=10 ospf-metric=40 ospf-type=intra-area
610 ADo dst-address=10.120.4.0/24 gateway=10.250.48.2
611 ADo dst-address=10.120.10.0/24 gateway=10.250.48.2
612 ADo dst-address=10.120.11.0/24 gateway=10.250.48.2
613 ADo dst-address=10.120.12.0/24 gateway=10.250.48.2
614 ADo dst-address=10.120.12.2/32 gateway=10.250.48.2
615 ADo dst-address=10.120.12.3/32 gateway=10.250.48.2
616 ADo dst-address=10.120.12.248/32 gateway=10.250.48.2
617 ADo dst-address=10.120.12.250/32 gateway=10.250.48.2
618 ADo dst-address=10.120.13.1/32 gateway=10.250.48.2
619 ADo dst-address=10.121.1.0/24 gateway=10.250.48.2
620 ADo dst-address=10.121.1.5/32 gateway=10.250.48.2
621 ADo dst-address=10.122.1.0/24 gateway=10.250.48.2
622 ADo dst-address=10.122.1.7/32 gateway=10.250.48.2
623 ADo dst-address=10.122.2.0/24 gateway=10.250.48.2
624 ADo dst-address=10.122.4.0/24 gateway=10.250.48.2
625 ADo dst-address=10.122.5.0/24 gateway=10.250.48.2
626 ADo dst-address=10.122.6.0/24 gateway=10.250.48.2
target-scope=10 ospf-metric=40 ospf-type=inter-area
627 ADo dst-address=10.122.7.0/24 gateway=10.250.48.2
628 ADo dst-address=10.122.8.0/24 gateway=10.250.48.2
629 ADo dst-address=10.122.9.0/24 gateway=10.250.48.2
630 ADo dst-address=10.122.10.0/24 gateway=10.250.48.2
631 ADo dst-address=10.123.0.0/24 gateway=10.250.48.2
632 ADo dst-address=10.130.0.0/16 gateway=10.250.48.2
633 ADo dst-address=10.130.1.0/24 gateway=10.250.48.2
634 ADo dst-address=10.131.1.0/24 gateway=10.99.0.1
635 ADo dst-address=10.131.2.0/24 gateway=10.99.0.1
636 ADo dst-address=10.132.1.0/24 gateway=10.250.21.1
637 ADo dst-address=10.133.1.0/24 gateway=10.99.0.1
638 ADo dst-address=10.133.2.0/24 gateway=10.99.0.1
639 ADo dst-address=10.133.3.0/24 gateway=10.99.0.1
640 ADo dst-address=10.133.3.2/32 gateway=10.99.0.1
641 ADo dst-address=10.133.3.3/32 gateway=10.99.0.1
642 ADo dst-address=10.133.4.0/24 gateway=10.99.0.1
643 A S dst-address=10.195.255.254/32 gateway=10.250.74.2
target-scope=10
644 ADo dst-address=10.199.0.0/24 gateway=10.99.0.1
645 ADo dst-address=10.199.1.0/24 gateway=10.99.0.1
646 ADo dst-address=10.199.3.0/24 gateway=10.99.0.1
647 ADo dst-address=10.199.4.0/24 gateway=10.99.0.1
648 ADo dst-address=10.200.0.0/24 gateway=10.99.0.1
649 ADo dst-address=10.200.10.5/32 gateway=10.99.0.1
650 ADo dst-address=10.201.1.0/24 gateway=10.99.0.1
651 ADo dst-address=10.201.3.0/24 gateway=10.99.0.1
652 ADo dst-address=10.201.4.0/24 gateway=10.99.0.1
653 ADo dst-address=10.201.5.0/24 gateway=10.99.0.1
654 ADo dst-address=10.201.6.0/24 gateway=10.99.0.1
655 ADo dst-address=10.201.6.3/32 gateway=10.99.0.1
656 ADo dst-address=10.201.7.0/24 gateway=10.99.0.1
657 ADo dst-address=10.201.8.0/24 gateway=10.99.0.1
658 ADo dst-address=10.201.9.0/24 gateway=10.99.0.1
659 ADo dst-address=10.201.13.0/24 gateway=10.99.0.1
660 ADo dst-address=10.201.14.0/24 gateway=10.99.0.1
661 ADo dst-address=10.201.15.0/24 gateway=10.99.0.1
662 ADo dst-address=10.201.15.4/32 gateway=10.99.0.1
663 ADo dst-address=10.201.16.0/24 gateway=10.99.0.1
664 ADo dst-address=10.201.20.0/24 gateway=10.99.0.1
665 ADo dst-address=10.201.21.0/24 gateway=10.99.0.1
666 ADo dst-address=10.201.22.0/24 gateway=10.99.0.1
667 ADo dst-address=10.201.22.2/32 gateway=10.99.0.1
668 ADo dst-address=10.201.23.0/24 gateway=10.99.0.1
669 ADo dst-address=10.201.24.0/24 gateway=10.99.0.1
670 ADo dst-address=10.201.26.0/24 gateway=10.99.0.1
671 ADo dst-address=10.201.30.0/24 gateway=10.99.0.1
672 ADo dst-address=10.201.40.0/24 gateway=10.99.0.1
673 ADo dst-address=10.201.50.0/24 gateway=10.99.0.1
674 ADo dst-address=10.229.0.0/21 gateway=10.250.21.1
675 ADo dst-address=10.249.1.0/24 gateway=10.250.48.2
676 ADo dst-address=10.250.0.0/24 gateway=10.250.48.2
677 X S dst-address=10.250.0.0/24 gateway=ether8 gateway-status=ether8 inactive
678 ADo dst-address=10.250.0.2/32 gateway=10.99.0.1
679 ADo dst-address=10.250.0.4/32 gateway=10.250.48.2
680 ADo dst-address=10.250.0.6/32 gateway=10.250.48.2
681 ADo dst-address=10.250.0.30/32 gateway=10.250.48.2
682 ADo dst-address=10.250.0.31/32 gateway=10.99.0.1
683 ADo dst-address=10.250.0.39/32 gateway=10.99.0.1
684 ADo dst-address=10.250.4.0/24 gateway=10.250.48.2
685 ADo dst-address=10.250.5.0/24 gateway=10.250.48.2
686 ADo dst-address=10.250.7.0/24 gateway=10.250.48.2
687 ADo dst-address=10.250.8.0/24 gateway=10.250.48.2
688 ADo dst-address=10.250.9.0/24 gateway=10.250.48.2
689 ADo dst-address=10.250.10.0/29 gateway=10.250.48.2
690 ADo dst-address=10.250.12.2/32 gateway=10.250.48.2
691 ADo dst-address=10.250.14.0/24 gateway=10.250.48.2
692 ADo dst-address=10.250.15.0/24 gateway=10.99.0.1
693 Do dst-address=10.250.15.0/24 gateway=10.250.48.2
target-scope=10 ospf-metric=140 ospf-type=inter-area
694 ADo dst-address=10.250.17.0/24 gateway=10.250.48.2
target-scope=10 ospf-metric=20 ospf-type=intra-area
695 ADo dst-address=10.250.18.0/24 gateway=10.250.48.2
target-scope=10 ospf-metric=30 ospf-type=intra-area
696 ADo dst-address=10.250.18.3/32 gateway=10.250.48.2
697 ADo dst-address=10.250.19.0/24 gateway=10.250.48.2
698 ADo dst-address=10.250.20.0/24 gateway=10.250.48.2
699 ADo dst-address=10.250.20.3/32 gateway=10.250.48.2
700 ADC dst-address=10.250.21.0/24 pref-src=10.250.21.2 gateway=ether8
gateway-status=ether8 reachable distance=0 scope=10
701 ADo dst-address=10.250.22.0/24 gateway=10.250.48.2
702 ADo dst-address=10.250.24.0/24 gateway=10.250.48.2
703 ADo dst-address=10.250.26.0/24 gateway=10.250.48.2
704 ADo dst-address=10.250.27.0/24 gateway=10.250.48.2
705 ADo dst-address=10.250.28.0/24 gateway=10.250.48.2
706 ADo dst-address=10.250.29.0/24 gateway=10.250.48.2
707 ADo dst-address=10.250.29.3/32 gateway=10.250.48.2
708 ADo dst-address=10.250.30.0/24 gateway=10.250.48.2
709 ADo dst-address=10.250.31.0/24 gateway=10.250.48.2
710 ADo dst-address=10.250.32.0/24 gateway=10.250.48.2
711 ADo dst-address=10.250.32.6/32 gateway=10.250.48.2
712 ADo dst-address=10.250.33.0/24 gateway=10.99.0.1
713 ADo dst-address=10.250.34.0/24 gateway=10.250.48.2
714 ADo dst-address=10.250.35.0/24 gateway=10.250.48.2
715 ADo dst-address=10.250.36.0/24 gateway=10.250.48.2
716 ADo dst-address=10.250.37.0/24 gateway=10.250.48.2
717 ADo dst-address=10.250.39.0/24 gateway=10.250.48.2
718 ADo dst-address=10.250.40.0/24 gateway=10.250.48.2
719 ADo dst-address=10.250.41.0/24 gateway=10.250.21.1
720 ADo dst-address=10.250.42.2/32 gateway=10.250.48.2
721 ADo dst-address=10.250.42.3/32 gateway=10.250.48.2
722 ADo dst-address=10.250.43.0/24 gateway=10.250.48.2
723 ADo dst-address=10.250.44.0/24 gateway=10.250.48.2
724 ADo dst-address=10.250.45.0/24 gateway=10.250.48.2
725 ADo dst-address=10.250.46.0/24 gateway=10.250.48.2
726 ADo dst-address=10.250.47.0/24 gateway=10.250.48.2
727 ADC dst-address=10.250.48.0/24 pref-src=10.250.48.1 gateway=sfp1
gateway-status=sfp1 reachable distance=0 scope=10
728 ADo dst-address=10.250.49.0/24 gateway=10.250.48.2
729 ADo dst-address=10.250.50.0/24 gateway=10.250.48.2
730 ADo dst-address=10.250.51.0/24 gateway=10.250.48.2
731 ADo dst-address=10.250.52.0/24 gateway=10.250.48.2
732 ADo dst-address=10.250.52.7/32 gateway=10.250.48.2
733 ADo dst-address=10.250.53.0/24 gateway=10.250.48.2
734 ADo dst-address=10.250.54.0/24 gateway=10.250.48.2
735 ADo dst-address=10.250.55.0/24 gateway=10.99.0.1
736 ADo dst-address=10.250.56.0/24 gateway=10.250.48.2
737 ADo dst-address=10.250.57.0/24 gateway=10.250.48.2
738 ADo dst-address=10.250.60.0/24 gateway=10.250.48.2
739 ADo dst-address=10.250.61.0/24 gateway=10.250.48.2
740 ADo dst-address=10.250.62.0/24 gateway=10.250.48.2
741 ADo dst-address=10.250.63.0/24 gateway=10.250.48.2
742 ADo dst-address=10.250.66.0/24 gateway=10.250.48.2
743 ADo dst-address=10.250.67.0/24 gateway=10.250.48.2
744 ADo dst-address=10.250.67.3/32 gateway=10.250.48.2
745 ADo dst-address=10.250.69.0/24 gateway=10.250.48.2
746 ADo dst-address=10.250.69.3/32 gateway=10.250.48.2
747 ADo dst-address=10.250.70.0/24 gateway=10.99.0.1
748 ADo dst-address=10.250.71.0/24 gateway=10.250.48.2
749 ADo dst-address=10.250.72.0/24 gateway=10.250.48.2
750 ADo dst-address=10.250.73.0/24 gateway=10.250.48.2
751 ADo dst-address=10.250.73.2/32 gateway=10.250.48.2
752 ADC dst-address=10.250.74.0/30 pref-src=10.250.74.1 gateway=ether2
gateway-status=ether2 reachable distance=0 scope=10
753 ADo dst-address=10.250.76.0/24 gateway=10.250.48.2
754 ADo dst-address=10.250.77.0/24 gateway=10.250.48.2
755 ADo dst-address=10.250.78.0/24 gateway=10.250.48.2
756 ADC dst-address=10.250.79.0/24 pref-src=10.250.79.1
gateway=bridge3 - Loopback gateway-status=bridge3 - Loopback reachable
distance=0 scope=10
757 ADC dst-address=10.250.79.6/32 pref-src=10.250.79.1
gateway= gateway-status= reachable
distance=0 scope=10
758 ADC dst-address=10.250.79.8/32 pref-src=10.250.79.1
distance=0 scope=10
759 ADo dst-address=10.250.80.0/24 gateway=10.99.0.1
760 ADo dst-address=10.250.81.0/24 gateway=10.99.0.1
761 X S dst-address=10.250.81.0/24 gateway=10.250.48.2
gateway-status=10.250.48.2 inactive distance=1 scope=30 target-scope=10
762 X S dst-address=10.250.81.4/32 gateway=10.99.0.1
gateway-status=10.99.0.1 inactive distance=1 scope=30 target-scope=10
763 ADo dst-address=10.250.82.0/24 gateway=10.99.0.1
764 ADo dst-address=10.250.83.0/24 gateway=10.250.48.2
765 ADo dst-address=10.250.84.0/24 gateway=10.99.0.1
766 X S dst-address=10.250.84.0/24 gateway=10.250.48.2
767 ADo dst-address=10.250.85.0/24 gateway=10.250.48.2
768 ADo dst-address=10.250.86.0/24 gateway=10.250.48.2
769 ADo dst-address=10.250.87.0/24 gateway=10.250.48.2
770 ADo dst-address=10.250.88.0/24 gateway=10.250.48.2
771 ADo dst-address=10.250.89.0/24 gateway=10.250.48.2
772 ADo dst-address=10.250.90.0/24 gateway=10.250.48.2
773 ADo dst-address=10.250.91.0/24 gateway=10.250.48.2
774 ADo dst-address=10.250.92.0/24 gateway=10.250.48.2
775 ADo dst-address=10.250.92.4/32 gateway=10.250.48.2
776 ADo dst-address=10.250.92.5/32 gateway=10.250.48.2
777 ADo dst-address=10.250.92.6/32 gateway=10.250.48.2
778 ADo dst-address=10.250.93.0/24 gateway=10.250.48.2
779 ADo dst-address=10.250.97.0/24 gateway=10.250.48.2
780 ADC dst-address=10.250.200.0/24 pref-src=10.250.200.1
gateway=bridge4 - Coastlands for Saint 1099
gateway-status=bridge4 - Coastlands for Saint 1099 reachable distance=0
scope=10
781 A S dst-address=10.251.0.0/16 gateway=10.251.254.2
gateway-status=10.251.254.2 reachable via vlan1274 distance=111
782 ADC dst-address=10.251.254.0/30 pref-src=10.251.254.1 gateway=vlan1274
gateway-status=vlan1274 reachable distance=0 scope=10
783 ADo dst-address=10.252.1.0/24 gateway=10.252.2.2
784 ADo dst-address=10.252.2.0/24 gateway=10.99.0.1
785 ADC dst-address=10.252.2.0/30 pref-src=10.252.2.1 gateway=ether5
gateway-status=ether5 reachable distance=0 scope=10
786 ADo dst-address=10.252.3.0/24 gateway=10.252.2.2
787 ADo dst-address=10.252.251.0/30 gateway=10.252.2.2
788 ADo dst-address=10.252.252.0/24 gateway=10.252.2.2
789 ADo dst-address=10.254.1.0/24 gateway=10.99.0.1
790 S dst-address=23.214.130.96/32 gateway=41.162.7.177
gateway-status=41.162.7.177 unreachable distance=1 scope=30
target-scope=10
791 ADC dst-address=41.162.6.0/27 pref-src=41.162.6.2
gateway=bridge1 neo internet
gateway-status=bridge1 neo internet reachable distance=0 scope=10
792 ADC dst-address=41.162.6.32/27 pref-src=41.162.6.36
793 ADo dst-address=41.162.7.176/29 gateway=10.99.0.1
794 ADo dst-address=41.162.19.0/24 gateway=10.98.0.2
795 ADo dst-address=41.162.100.136/29 gateway=10.99.0.1
796 ADo dst-address=41.189.75.64/26 gateway=10.252.2.2
797 ADo dst-address=41.189.77.228/30 gateway=10.252.2.2
798 A S dst-address=104.126.83.73/32 gateway=10.99.0.1
gateway-status=10.99.0.1 reachable via vlan3 distance=1 scope=30
target-scope=10
799 A S dst-address=104.126.103.69/32 gateway=10.99.0.1
target-scope=10
800 ADo dst-address=154.68.184.0/28 gateway=10.250.21.1
801 ADo dst-address=154.70.136.0/21 gateway=10.250.48.2
802 ADo dst-address=154.70.136.244/30 gateway=10.250.48.2
803 ADo dst-address=154.70.137.144/28 gateway=10.250.48.2
804 ADo dst-address=154.118.244.32/29 gateway=10.250.21.1
805 ADo dst-address=154.118.244.112/28 gateway=10.250.21.1
806 ADo dst-address=154.118.244.117/32 gateway=10.250.21.1
807 ADo dst-address=154.118.244.120/32 gateway=10.250.21.1
808 ADo dst-address=154.118.244.121/32 gateway=10.250.21.1
809 ADo dst-address=154.118.244.126/32 gateway=10.250.21.1
810 ADo dst-address=154.118.244.134/32 gateway=10.250.21.1
811 ADo dst-address=154.118.244.135/32 gateway=10.250.21.1
812 ADo dst-address=154.118.244.138/32 gateway=10.250.21.1
813 ADo dst-address=154.118.244.142/32 gateway=10.250.21.1
814 ADo dst-address=154.118.244.144/28 gateway=10.250.21.1
815 ADo dst-address=154.118.244.160/27 gateway=10.250.21.1
816 ADo dst-address=154.118.244.204/30 gateway=10.250.21.1
817 ADo dst-address=154.118.244.208/30 gateway=10.250.21.1
818 ADo dst-address=154.118.244.224/30 gateway=10.250.21.1
819 ADo dst-address=154.118.244.244/30 gateway=10.250.21.1
820 ADo dst-address=154.118.245.128/27 gateway=10.250.21.1
821 ADo dst-address=154.118.245.176/28 gateway=10.250.21.1
822 ADo dst-address=154.118.246.32/30 gateway=10.250.21.1
823 ADo dst-address=154.118.247.66/32 gateway=10.250.21.1
824 ADo dst-address=154.118.247.67/32 gateway=10.250.21.1
825 ADo dst-address=154.118.247.68/32 gateway=10.250.21.1
826 ADo dst-address=154.118.247.69/32 gateway=10.250.21.1
827 ADo dst-address=154.118.247.72/32 gateway=10.250.21.1
828 ADo dst-address=154.118.247.73/32 gateway=10.250.21.1
829 ADo dst-address=154.118.247.74/32 gateway=10.250.21.1
830 ADo dst-address=154.118.247.75/32 gateway=10.250.21.1
831 ADo dst-address=154.118.247.77/32 gateway=10.250.21.1
832 ADo dst-address=154.118.247.78/32 gateway=10.250.21.1
833 ADo dst-address=154.118.247.81/32 gateway=10.250.21.1
834 ADo dst-address=154.118.247.82/32 gateway=10.250.21.1
835 ADo dst-address=154.118.247.84/32 gateway=10.250.21.1
836 ADo dst-address=154.118.247.85/32 gateway=10.250.21.1
837 ADo dst-address=154.118.247.88/32 gateway=10.250.21.1
838 ADo dst-address=154.118.247.93/32 gateway=10.250.21.1
839 ADo dst-address=154.118.247.94/32 gateway=10.250.21.1
840 ADo dst-address=154.118.247.98/32 gateway=10.250.21.1
841 ADo dst-address=154.118.247.100/32 gateway=10.250.21.1
842 ADo dst-address=154.118.247.102/32 gateway=10.250.21.1
843 ADo dst-address=154.118.247.103/32 gateway=10.250.21.1
844 ADo dst-address=154.118.247.104/32 gateway=10.250.21.1
845 ADo dst-address=154.118.247.105/32 gateway=10.250.21.1
846 ADo dst-address=154.118.247.106/32 gateway=10.250.21.1
847 ADo dst-address=154.118.247.107/32 gateway=10.250.21.1
848 ADo dst-address=154.118.247.109/32 gateway=10.250.21.1
849 ADo dst-address=154.118.247.112/32 gateway=10.250.21.1
850 ADo dst-address=154.118.247.114/32 gateway=10.250.21.1
851 ADo dst-address=154.118.247.115/32 gateway=10.250.21.1
852 ADo dst-address=154.118.247.116/32 gateway=10.250.21.1
853 ADo dst-address=154.118.247.117/32 gateway=10.250.21.1
854 A S dst-address=169.239.8.61/32 gateway=41.162.6.1
855 ADC dst-address=169.239.44.16/29 pref-src=169.239.44.18 gateway=ether4
gateway-status=ether4 reachable distance=0 scope=10
856 ADo dst-address=172.16.3.0/30 gateway=10.250.21.1
857 ADo dst-address=172.16.8.0/24 gateway=10.99.0.1
858 ADo dst-address=172.16.20.0/24 gateway=10.250.21.1
859 ADo dst-address=172.16.22.4/30 gateway=10.250.21.1
860 ADo dst-address=172.16.200.3/32 gateway=10.250.21.1
861 ADo dst-address=172.20.0.0/24 gateway=10.250.21.1
862 ADo dst-address=172.20.1.0/24 gateway=10.250.48.2
863 ADo dst-address=172.22.1.0/24 gateway=10.250.21.1
864 ADo dst-address=172.168.2.0/24 gateway=10.250.48.2
865 ADo dst-address=172.168.7.0/24 gateway=10.250.48.2
866 X S dst-address=192.168.0.0/24 gateway=10.251.254.2
gateway-status=10.251.254.2 inactive distance=1 scope=30
target-scope=10
867 ADo dst-address=192.168.1.0/24 gateway=10.99.0.1
868 ADo dst-address=192.168.3.0/24 gateway=10.250.21.1
869 ADo dst-address=192.168.10.0/24 gateway=10.250.48.2
870 ADo dst-address=192.168.14.0/24 gateway=10.252.2.2
871 ADo dst-address=192.168.15.0/24 gateway=10.252.2.2
872 ADo dst-address=192.168.16.0/24 gateway=10.252.2.2
873 ADo dst-address=192.168.17.0/24 gateway=10.99.0.1
874 Do dst-address=192.168.17.0/24 gateway=10.252.2.2
875 ADo dst-address=192.168.18.0/24 gateway=10.252.2.2
876 ADo dst-address=192.168.21.0/24 gateway=10.99.0.1
877 ADo dst-address=192.168.45.0/24 gateway=10.252.2.2
878 ADo dst-address=192.168.50.250/32 gateway=10.99.0.1
879 ADo dst-address=192.168.80.0/24 gateway=10.250.48.2
880 ADo dst-address=192.168.108.0/24 gateway=10.99.0.1
881 ADo dst-address=192.168.110.0/24 gateway=10.99.0.1
882 ADC dst-address=192.168.246.0/24 pref-src=192.168.246.250
gateway=bridge vlan for saint ptalk
gateway-status=bridge vlan for saint ptalk reachable distance=0
scope=10
883 ADo dst-address=196.35.150.0/24 gateway=10.250.48.2
884 X S dst-address=216.58.233.0/24 gateway=169.239.44.17
target-scope=10
I have proxy-arp enabled on my main Neointernet break out. Could this affect it?
Wow, not exactly what I expected. That deserved a warning or at least
 tag. I guess I didn't pay enough attention to phrase "main internet breakout".
Anyway, I did try to have a look and your new routes (currently disabled) are the only ones not in main table. So just enabling them can't break anything. But actually marking routing for them can, because it's currently unconditional, based just on incoming interface. So anything that comes from there, even though it was previously outgoing connection, gets marked. And once it happens, it only tries to use given routing table and not the main one anymore.
You need to limit what gets marked (connection mark). Add connection-state=new to you connection marking rules, that should probably do the trick.
Other way would be to use routing rules to look up internal subnets only in main routing table. But it doesn't look like you could do that easily, there are too many subnets and not just 10.x.x.x.
Sob, Thank you for all you time. Much appreciated.
I will implement that in the early hrs of tomorrow morning and will update you.
