Hello, I’ve found in my logs incoming connections from 1.1.1.1 or 1.0.0.1 port 53 UDP:
X.X.X.X is my static IP
2025-12-24 13:07:04 firewall,info INPUT WAN 53 UDP input: in:pppoe-out-openfiber out:(unknown 0), connection-state:new src-mac A.B.C.D:E:F, proto UDP, 1.0.0.1:53->X.X.X.X:41033, len 88
2025-12-25 00:17:37 firewall,info INPUT WAN 53 UDP input: in:pppoe-out-openfiber out:(unknown 0), connection-state:new src-mac A.B.C.D:E:F, proto UDP, 1.1.1.1:53->X.X.X.X:41673, len 112
2025-12-25 03:58:02 firewall,info INPUT WAN 53 UDP input: in:pppoe-out-openfiber out:(unknown 0), connection-state:new src-mac A.B.C.D:E:F, proto UDP, 1.1.1.1:53->X.X.X.X:41354, len 112
2025-12-25 13:10:27 firewall,info INPUT WAN 53 UDP input: in:pppoe-out-openfiber out:(unknown 0), connection-state:new src-mac A.B.C.D:E:F, proto UDP, 1.0.0.1:53->X.X.X.X:41306, len 88
I registered a domain on Cloudflare, is it possible that they are trying to reach my IP?
Or is it a DNS amplification attack?
I drop those connections in a following rule, should I allow them?
Thank you!
Giorgio
