Incoming port 123 connection refused
I am allowing certain incoming ports and forwarding to an internal server IP.
However despite allowing and forwarding 123 in both UDP and TCP, its being blocked by the router.
I know you can install the NTP server, but I already have a GPS locked NTP server on my LAN which the router takes time from.
But I want my external servers to use my NTP server. Everything else I forward works like a charm. I think its some internal block as you can install the NTP server on the router.
Thanks!
