Incompatibility with ps4?
Has anyone gotten this to work. I been trying to connect my XBOX one up and have try UPnP, forwarding ports, and changing DNS. My NAT settings are always strict. My old netgear router had no problem connecting open. Is there anything else left to try?
Has there been any solution for this yet? I have been trying to connect my XBOX one up with no luck. The NAT is always strict no matter what I do. I have try UPnP, forwarding ports, changing DNS, etc and nothing works.
Any body solved this? From what i gather this is because of double natting or because a client does not have a public ip. Sure public ip would resolve this, but this means you would have to have few 100 publick ip’s.
switching to another UPnP implementation at cost of security can solve that problem, but hardly many customers welcome such move, IMO.
as you noticed, its PSN-specific issues, not UPnP itself, related to PSN(not only SOE but Microsoft too, if you interested)lunacy to gain Direct connect to device. so its more make sense to request at PSN resources.
I’ve been trying to figure this problem out for the last week. Funny that switching to OpenDNS server resolves the issues but my external traffic is routed incorrectly because of it.
It looks like the IPv6 package that is causing problems. The PS4 seems to be very active in using IPv6 if supported on RouterOS but my ISP does not support it yet so its causing issues.
If IPv6 is found on the network the PS4 will not map the uPnP ports for IPv4
I’ve disabled the IPv6 package and its currently working again. Ill update if any further problems.
UPDATE:
Problem has come back, so not IPv6.
Problem has been found to be something to do with DNS-proxy. Changing local DNS of PS4 to point to my ISP DNS Server and not my RouterOS DNS Server solves the issues without having to use OpenDNS servers. Its been working for days now.
