Hello I’m configuring a RB493 and when I started working in ip firewall filter I saw that counter was extremelly strange. It had count millon of packet!!
So I restarted the RB and is the same, its start with the counter with littel number!! And not only start with big number also start with NEGATIVE number!!!
I tried with RO v3.30 and v3.28
Look the image
Well if someone know why happen it I’ll apreciate your help!
Rafael Lore
Well looking the problem I saw that when I disable the bridge, the problem disapear, but I have to use a bridge!!!
Normis do you what could happen?
Thank
Rafael Lore
I upgraded to RO v4.2 and is the same, later I downgraded to 3,24 and continuous equal! Is something with the bridge, just enable it and the counters jump! if work without the bridge is no problem! but I need the bridge, is to do QOS totally transparent! That it could be?
Thanks again
Rafael Lore
JAJAJAJA seguro Maxi, trate de tirarle agua bendita y salio humo, nose si sera porque la estoy exorsizando o se me quemo!!! jajaja
YEs I think that is a bug!!
Rafael Lor
