incorrect gateway on remote network
Hi
I put my ADSL modem into bridge mode and started using the Mikrotik as the pppoe client. Disabled DHCP on the router and then created the DHCP server on the Mikrotik. All good so far. What I didn’t realise was that the IP address of the PBX was set to a static IP address and now the problem that I have is that I can no longer manage the PBX remotely since the gateway is still set to that of the ADSL modem. What can I do to simulate being on the network so that I can log into the PBX and change the default gateway?
Regards
Can’t you just add the old gateway address as an additional IP address from the Mikrotik Router, then connect to the PBX?
