Incorrect speed interface on Zabbix
I’m trying to monitor some RBs on Zabbix and the value showed in Speed related to the Interfaces VPLS are wrong.
The value exhibited is 10 Mbps, but the real value is 1 Gbps. (In the “ether” interfaces the value showed is 1 Gbps and VLANs interfaces is 100 Mbps)
Is there a way to change this parameter in the RB, or some Zabbix template that collect the right value?
Thank you.
