Incorrect / Wrong Session time in Userman
I have a hotspot all set to go. Doing some testing I notice that the session time is 6 hours ahead (When viewing from HTTP userman).
Apr/05/2010 14:38:55 should be Apr/05/2010 10:38:55
I have NTP client setup and system time is correct. Any ideas ?
RADIUS and userman are on same box.
Only two other things come to mind, hope they don’t sound silly.
After configuring NTP client in your router:
-Did you set a manual time zone (e.g +06:00) or did you choose from the list of preset time zones?
-Also, have you confirmed that the time in your routerboard clock is correct?
I did set time zone and system time is correct. I will however double check just to be sure.
